Question about Toshiba Computers & Internet
New laptop C650, how to install OS ? - Toshiba Computers & Internet
  • Toshiba Master
  • 4,924 Answers
You need a boot-able disk with the operation system ..and you need to go to Bios and change the boot priority to boot from Cd first (first boot device ) ..than insert the cd ..and restart ..when it shows "press any key to boot from cd " just press a key ..than will start to load files until they are all initial files loaded..and will restart and pretty much will show you all you have to do ..
Pay attention when you make the partitions if you want more than one ..
here are some instructions for XP...
http://www.buildeasypc.com/sw/windows_xp.htm
some steps like installing the 3rd party driver are only needed for raid drivers on sata ..
the rest are pretty clear there ..
http://support.microsoft.com/kb/313348
here are some info about how to partition-ate the hard disk for the first time ..or even if it contains information ..
Here is about how to install vista ..
and for windows 7 the procedure is almost the same ..
http://windows.microsoft.com/en-US/windows-vista/Installing-and-reinstalling-Windows-Vista
Posted on Sep 29, 2010
  • Toshiba Master
  • 32,281 Answers
If you are installing Windows, you need the Windows installation CD and the product installation code.
Boot up the Toshiba with this installation CD in the DVD/CD drive and follow the on screen instructions.
After Windows is installed you need to install the Toshiba's devices.
You may need to download these Toshiba drivers using another computer.
These instructions are just the basic details.
If you need further instructions, please get back to me and tell me at what stage you are having troubles.
My toshiba Satellite C650 . DVD drive will not recogise any bootable disks. works ok on other disks
If the OS installed is newer than your discs, it is probably trying to protect itself. Windows does this sort of thing.
Jan 20, 2014 | Toshiba Satellite Computers & Internet
How to restore factory setting of toshiba satellite pro c650.note that laptop bought without os preinstalled and oem os has been installed.pressing zero key does not work.i can not select bios option as my...
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
Jun 15, 2012 | Toshiba Satellite Pro C650-Z2510T Notebook
Toshiba satellite c655 hinge replace
If you don't have the experience on disassembly the Toshiba Satellite c650 c655 laptop, we suggest you refer to the official maintenance manual firstly if you have. Here we provide a universal instruction for the reference, some steps may be not the same. If you need a detailed guide or manual, please contact us, we will email you if we have.
1. Please turn off your Toshiba Satellite c650 c655 laptop, disconnect the power adapter and remove the toshiba satellite c650 c655 battery.
2. Turn the laptop over. Remove the screws (may not exist) that hold the Toshiba Satellite c650 c655 hinges on the back of the computer.
3. Remove all the screws (may not exist) that hold the keyboard and keyboard bezel in place, then gently pry keyboard bezel using a flat head screwdriver. Lift the keyboard and unplug the keyboard cable from the motherboard to remove the keyboard. Now, you will see the toshiba c650 c655 laptop fan
4. Detach both hinge covers using your fingers. Unscrew the screws securing the Toshiba Satellite c650 c655 hinges to the laptop base.
5. Locate the screws on the LCD, pry the rubber screw seals using a flat-head screwdriver. Unscrew the screws attached under the seals. Remove the screen bezel.
6. Remove the screws securing the hinges d to the Toshiba Satellite c650 c655 LCD.
7. Now, you can remove the old Toshiba Satellite c650 c655 Hinges by sliding them out. Insert the new hinges in their correct place. Reverse the above procedure to assemble the laptop.
Mar 11, 2012 | Toshiba Satellite C655-S5068 Notebook
Toshiba satellite pro c650,Built in web cam working satisfactorily till yesterday. now giving message 'unable to find pc camera'. kindly help.
A couple of things to try.
1) Go into your BIOS and ensure that the webcam isn't somehow turned off in the BIOS. 2) Go into Device Manager in Windows, find the webcam. Right click on it and remove it. Then reboot the computer and let Windows find it, and reinstall the drivers again.
3) You may also want to reinstall the Toshiba specific drivers and software which likely includes drivers for the webcam. You may have a CD that came with the laptop, otherwise you can go to
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=2769587&rpn=PSC13U&modelFilter=C650-Z2510T&selCategory=2756709&selFamily=1073768667
and reinstall the webcam application for your laptop.
Hope this helps!!
Jun 20, 2011 | Toshiba Satellite Pro C650-Z2510T Notebook
Pls inform me how down load free eathernet controller drive software & how to install (toshiba satelite c650 1 kj,laptop,win7) thank you,
There is more to that model number than you gave... it should be c650-something else
You can go here http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp and punch in the right info and there you will find any and all driver you will need for it.
Apr 08, 2011 | Computers & Internet
Having had my sons laptop crash with the message bootmng missing he installed windows vista for a medion laptop on his toshiba C650 laptop but now i have read that we could have it with original software...
if you have the windows vista dvd then put it in, boot from it but when it comes to install step , check for the REPAIR SYSTEM option at the bottom,
select that option and choose -> startup repair.
follow onscreen steps and wait for system reboot.
if everything goes fine it will start but if this doesn't work then you'll be needed to reinstall the whole OS..
Mar 01, 2011 | Computers & Internet
I want all the drivers of Toshiba Satellite Pro c650. Please its urgent. Thanks.
Please visit http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=Communicate
Select the Downloads
This is how you need to select your model number and then select the operating system you have in your system.
Then you will get a list of drivers for your laptop.
Regards
Anand Sachan
Nov 02, 2010 | Toshiba Satellite Pro C650EZ1521 Notebook
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. nboulikas@gmail.com for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
Computers & Internet Logo
55 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
