The locationof pcv valve on 2004 Acura tl - Computers & Internet
  • 88 Answers
SOURCE: AC Not blowing inside of 2004 Acura TL
check the fuse and the relays for the fan motors.if thats ok check to see if it is vacuum operated controls and that none of the pipes are off or split.
Posted on Oct 14, 2008
blueextc3221
  • 15935 Answers
SOURCE: PCV valve for 2004 Hona CRV
PCV Valve Operation: 0900823d80049deb.jpgA vacuum-controlled metering device that regulates the flow of crankcase fumes in the positive crankcase ventilation system by allowing more flow at high speed than at low speed, and acts as a system shutoff in case of engine backfire to prevent an explosion in the crankcase.
Depending on your engine size, the PCV is a different style and slightly different location.
Usually they are mounted in a hole on your valve cover.... connected by a vacuum tube.
Some are mounted with threads into the engine block (usually by the oil filter)
On the '04 Crv - it is nearly inaccessible behind the AC compressor and beneath what looks like an old vacuum advance. Most PCV valves today do not need to be replaced, unless there is actual valve failure, which I have not seen happen. I would not be concerned about replacing it.
Thanks for using FixYa - a FixYa rating is appreciated!!
Posted on Feb 21, 2009
TDISLine
  • 1874 Answers
SOURCE: How difficult is it to change the PCV valve. 2004
PCV is an acronym for positive crankcase ventilation.
The PCV Valve is a very common replacement item on many engines today. It's called the PCV valve for short but it stands for Positive Crankcase Ventilation. When your engine spins it many times collects pressure in the crankcase area, and it has to escape to relieve pressure on the motors bearings and seals. The PCV valve and PCV system is typically located near the intake manifold, and many times comes right off of the valve cover. It is very simple to replace the PCV valve, and you can do so by simply unscrewing it, and screwing in the new valve. We recommend using a little bit of teflon tape or paste to make sure you do not get any oil leaks.
Example (see picture below): 2,4 ltr. Audi V6 engine (BDV, AMM)
b0e80b6.png It's not difficult to replace PCV valve!
Posted on Sep 24, 2009
  • 105 Answers
SOURCE: what does the service code B23 on my 2004 acura tl
B is oil and filter change with brake inspection and clean, lube , adjust
1 would be tire rotation
2 is replace engine and cabin air filters
3 is replace transmission fluid
Posted on Oct 30, 2009
co7196
  • 3433 Answers
SOURCE: 2004 Mazda MPV vacuum line from pcv valve and
You have the wrong type hose on the pcv valvle. It isn't vacuum hose.
Posted on Nov 12, 2009
Testimonial: "thank you you have been very helpful i understand now but the hose that is on the new pcv valve is a vacuum hose "
I have an 2004 Acura tl n it hesitates to turn on
acura tl starter problem? - YouTube
? 1:09
www.youtube.com/watch?v=g8pkyOz1EaE
Oct 3, 2012 - Uploaded by MrFung1980
I has that same problem with my Acura and it was the ignitionswitch, at least ... 2004 Acura TL Review - In 3 minutes you'll be an expert on the ...
Sep 10, 2015 | Acura Cars & Trucks
Any problems with acura 2004 ?
According to repairpal: "Honda and Acura Recall Multiple Vehicles Due to Excessive Air Bag Inflator Pressure RepairPal Expert Overview: Honda has recalled 2001-2003 Civic, 2002-2003 Civic SI, 2001-2002 Accord, 2002 CR-V, 2002 Odyssey, 2003 Pilot, 2002-2003 Acura TL, and 2003 Acura CL vehicles because the driver's side air bag inflator may produce excessive internal pressure. This could cause the inflator to rupture if the air bag deploys. Metal fragments may pass through the air bag material and cause injury to vehicle occupants. Dealers will replace the driver's side air bag inflator.
Models: Acura CL, Acura TL, Honda Accord, Honda CR-V, Honda Civic, Honda Civic Si, Honda Odyssey, Honda Pilot Body, Interior & Misc., February 26, 2010 Honda Recalls 2001-2003 Vehicles Due to Excessive Air Bag Pressure RepairPal Expert Overview: Honda has recalled 2001-2002 Civic, Civic SI, and Accord vehicles and 2002-2003 Acura TL vehicles because the driver's side air bag inflator could produce excessive internal pressure. This may cause the inflator to rupture if the air bag deploys. Metal fragments may pass through the air bag material and cause injury to vehicle occupants. Dealers will replace the driver's side air bag inflator.
Models: Acura TL, Honda Accord, Honda Civic, Honda Civic Si Body, Interior & Misc., August 31, 2009 Acura Recalls 2004-2007 TL Models Due to Power Steering Hose Leaks RepairPal Expert Overview: Acura has recalled certain 2004-2007 TL models because the power steering hose may leak onto the extremely hot catalytic converter, which may cause a fire hazard. Dealers will replace the power steering hose with a new heat-resistant design.
Models: Acura TL Suspension & Steering, April 28, 2008 Acura Recalls 2004-2005 TL Vehicles Due to Corrosion in the Wiper Motor Housing RepairPal Expert Overview: Acura has recalled 2004-2005 TL vehicles because the wiper motor may stop working. Water may enter the wiper motor breather port and cause corrosion, which may cause the electrical circuit in the wiper motor to fail. Dealers will replace corroded wiper motors and modifications will be made to prevent water from entering the existing or new wiper motor.
Models: Acura TL Body, Interior & Misc., April 28, 2008 Honda Recalls 2005-2006 Models Due to Faulty Fuel Pump Relay RepairPal Expert Overview: Honda has recalled 2005 Accord, Odyssey, Acura RL, TL, TSX, and 2006 Ridgeline models because the fuel pump relay may fail. This can prevent the fuel pump from operating, which may cause the engine to stall or not start. Dealers will replace the fuel pump relay.
Models: Acura RL, Acura TL, Acura TSX, Honda Accord, Honda Accord Hybrid, Honda Odyssey, Honda Ridgeline Engine, April 2, 2007 Honda Recalls 2006-2007 Models Due to Incorrect NHTSA Contact Information in Owner's Manual RepairPal Expert Overview: Honda has recalled 2006 Accord, Civic, CR-V, Element, Insight, Odyssey, Pilot, Ridgeline, Acura MDX, RL, RSX, TL, TSX, and 2007 Honda Fit vehicles because the contact information for the National Highway Traffic Safety Administration (NHTSA) is listed incorrectly in the owner's manual. Honda is contacting dealers and customers to provide them with a postcard containing the correct information.
Models: Acura MDX, Acura RL, Acura RSX, Acura TL, Acura TSX, Honda Accord, Honda CR-V, Honda Civic, Honda Element, Honda Fit, Honda Insight, Honda Odyssey, Honda Pilot, Honda Ridgeline Body, Interior & Misc., August 2, 2006 Acura Recalls 2006 TL Vehicles Due to Loose Front Air Bag External I"mpact Sensor Bolts RepairPal Expert Overview: Acura has recalled 2006 TL vehicles because the bolts that mount the front air bag external impact sensors may be loose. If the sensor bolts fall out, the sensor may not function properly, which may prevent air bag deployment in the event of an accident. Dealers will inspect and re-torque the front air bag external impact sensor bolts.
May 07, 2015 | Health & Beauty
I just bought my 2004 Acura TL 2 weeks ago. It
What you describe is consistant with a lifter not pumping up except at a little higher rpm, which would make sense. You have overhead cams, with hydrolic lifters. They pump up with oil. If you have one that is not fully "pumped", it will make a clicking noise when the camlobe moves it and it strikes the valve. This is not the only thing it could be...and maybe it is the tensioner, but if it is coming from the valve area....Also, your dealer should have a special stethescope so the mechanic can listen in spots, and move the pick-up to where the noise gets louder and make a better diagnosis.
Oct 20, 2009 | 2004 Acura TL
I need help setting the clock of my 2004 Acura TL
you need correct security code 1st
May 07, 2009 | 2004 Acura TL
Code P0505 on 1999 Acura TL
this code make reference to low idle engine,maybe the throttle body is dirty , air filter clogged, vacumm leak , pcv valve clogged, check for thoses
Apr 23, 2009 | 1999 Acura TL
2003 Acura TL Heater Control
Hi,welcome to fix ya.
there is a motor under the dash on the passenger side called the "air mix motor" by acura that goes out on these and causes this it is just under the carpet under the radio .you can reach it from the passenger side . change this and you adjustment will return
Mar 31, 2009 | 2004 Acura TL
04 acura tl serpentine belt diagram
there should be a belt diagram from a label either on underside of hood or on radiator support. That should help if you can do it yourself.
Jan 24, 2009 | 2004 Acura TL
I have 2006 Acura TL V6. How do I change the cabin air filter?
To change cabin air filter on Acura TL firs time you need to open the glove box and then remove the arm that holds the glovebox. Press the 2 sides of the glovebox to take this out like in picture bellow.
acura-tl-2004-2010-cabin-air-filter-location.jpgAcura TL 2004-2010 cabin air filter location
After do this you can see and locate the cabin air filter housing cover.
acura-tl-2004-2010-cabin-air-filter-housing-cover.jpgAcura TL 2004-2010 cabin air filter housing cover
Push the 2 tabs from the filter frame to unhooking from the housing cover. Take the frame out and replace the old cabin air filter with the new one with the air flow indicating arrow pointing down.
acura-tl-2004-2010-reinstal-the-air-cabin-filter.jpgAcura TL 2004-2010 reinstal the air cabin filter
Nov 26, 2008 | 2006 Honda Accord
Computers & Internet Logo
211 people viewed this question
David Payne
David Payne
