PC Start up issue
My PC won't boot properly when my external hard drive (LaCie) is turned on. I think it's trying to boot from the external drive, which doesn't work since Windows is not installed on it. When I turn off the drive and press Crtl+Alt+Delete, it boots fine. so my question is how do I stop the computer from doing this? Thanks.
  • susiehk May 27, 2008
    Thanks...getting into BIOS did the trick...my DVD drive was set as the primary boot device, with my hard drive and secondary hard drive next. Oddly, my external drive didn't show up on the list. But when I put my hard drive first in line, the problem disappeared. Much appreciated!
    President:
  • 2,712 Answers
When booting up your PC, press F8 (in most PC's..sometimes F2 or F11, depending on what BIOS you have) to go into BIOS and select first boot device as the internal HDD. That should work.
Posted on May 25, 2008
  • Swilin Sampson
    Swilin Sampson May 27, 2008
    And just a helpful rating? Solved the problem..should have been a Fixya :)
Won't turn on
If this is an external drive you can try buying a new external enclosure and pull the drive out of the LaCie and putting it in the new enclosure. If it still doesn't work then the drive is bad and needs to be replaced.
Dec 22, 2012 | LaCie (300770) 250 GB Hard Drive
My LaCie hard drive is listed in preferences but it does not boot. Your suggestions?
Have you ensured the Lacie HDD is bootable? IMC, external drives that does not contain boot files or not-formatted in bootable mode cannot boot your device.
Try formatting your Lacie drive into bootable mode. Right click -> Format -> Check "make device bootable" and click start. THis shoudl help.
Mar 05, 2011 | LaCie Computers & Internet
When my lacie external hard drive is connected,my
Check your BIOS > StartUp sequence
Maybe the USB boot option has much higher priority that HDD boot. Try exchanging their priority and then reboot, with your external HD connected to pc.
Jan 03, 2010 | LaCie (300951U) 500 GB Hard Drive
Lacie 500gb quadra external drive won't boot using USB cables.
Microsoft has had some issues in regard to external devices (especially after running some updates). There is a registry patch for this situation. Click below to install the patch. It should fix your external drive problem. All the best!
Greg
http://support.microsoft.com/kb/925196#fixit4me
May 19, 2009 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Hard drive motor just cant get a full head of steam going
When the motor and the heads start getting noisy, clicking and whirring, and the hard disk access time gets abnormally longer than usual, that means that the disk can fail at any time.
Better saving all your data and get a replacement drive.
If this happened on two Lacie and they did not receive any shock, then call Lacie to complain : Contact Support
Nov 22, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
External hard drive
I just worked through this same issue with LaCie tech support and they fixed it- it was a bad power supply. Fortunately I had another LaCie drive and when I plugged the power supply from that one in to the "misbehaving" drive, everything booted up fine.
Sep 20, 2008 | LaCie (300770) 250 GB Hard Drive
Lacie hard drive
The problem is just external...Hdd is fine..Just buy new external couse there is no way to repair it
Jan 12, 2008 | LaCie Design by F. A. Porsche 160 GB Hard...
Can't access my lacie external hard drive
I would first plug it in to a different PC, this will tell you if the problem is the Lacie or Windows Vista.
if it works on a different PC then remove it from Device manager or go to the Lacie website for Vista updates.
If it does not work on a different PC then there are 3 possibilities
1. the drive got cleared data lost
2. the enclosure is bad (I would bet on this)
3. the drive is bad
purchase a USB enclosure, remove the drive and install it in the new enclosure plug in and test.
Hope this helps
thanks for rating
Jan 09, 2008 | LaCie (300728U) 250 GB Hard Drive
LaCie PC
Try to put hdd in ( for whillem 74) another EXTERNAL!Or just buy new external then put hdd in new external.There is no way to repair it i think!!!
For Fiddler 51 Try hdd in external if it wont acept also then hdd is damanged!
Dec 04, 2007 | LaCie Design by F. A. Porsche 160 GB Hard...
LaCie FireWire drive
I would seek out the latest drivers for the card in addition to checking to see the firewire card is properly installed. I would test the cable with another or ports. The D2 has a various array and combination of Firewire ports on each model. Also, try bringing the drive to another computer, to eliminate all other variables. Always of course, properly eject external hardrives and wait for confirmation whenever disconnecting it from the computer, and allow the drive to spin down before turning it off.
Sep 09, 2007 | LaCie (301146U) 320 GB FireWire 400...
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
