Question about Hotpoint FFM90 Bottom Freezer Refrigerator
My fridge-freezer (FFM90) has ice forming in the bottom of the freezer section under the last drawer. Why is that and what can I do?
  • Hotpoint Master
  • 17,130 Answers
This is due to excessive condensation and in bottom freezers due to proximity of the compressor.There is some residual water falling on to the drawers which forms the ice and this must be prevented. make sure that the frozen foods that was stocked did not loose water into the bottom till we can suspect the freezer. Also frequent opening of the freezer will allow for condensation whicj must be wiped out at intervals.
This can prevent some ice formation and also check if there is leak from the evaporator trays to the freezer during defrosting.
Posted on Sep 29, 2010
Kfcs22evms ice under freezer door and water leaks out onto floor
Check for a clogged drain line at he bottom rear.
Oct 30, 2017 | Refrigerators
Ice is forming in the bottom of the freezer compartment of my hotpoint FFM90 frost free fridge/ freezer. Please help. Many Thanks
Had exactly the same problem.
It was due to a blockage of the drain.
At the back of the freezer there is the pump and there is a small darin that lets condensation from inside the freezer spill onto the top of the (hot) pump to be evaporated. When this small drain blocks it causes issues like water leaking out of freezer and big chunks of ice at the back of the bottom compartment.
The fix is easy, if a little laborious.
Take all the stuff out of the freezer, then dismantle the internal plastic trip, don't worry, you can't really break anything and it goes back together easily, Eventually you will be left with just the bare metal insides and in the middle at the bottom back you will see the drain collection point, slightly hidden from view is the drain hole. Pour warm water onto this till it comes out onto the pump at the back.
Then use a pipe cleaner to clean.
Re-assemble - done :)
Oct 15, 2010 | Hotpoint FFM90 Bottom Freezer Refrigerator
Ice forming at base of freezer part
you need to urinate on the tray amanda it may smell but will solve the ice prob as the urine is heated
May 26, 2009 | Siemens Freezers
Hotpiont ffm90 fridge not chilling
hi if the freezer appears to work and the fridge if warm,the problem is that the freezer is over frozen and blocking the vents which send cold air into the fridge when required,and the noise is the fan hitting the the ice build up,defrost (switch off)your applinace for at least 36 hours then switch back on,you will then find after the freezer reaches -12 the fridge will then start to go cold.
Mar 09, 2009 | Hotpoint FFM90 Bottom Freezer Refrigerator
FFM90
hi The limit switch is found only on frost-free refrigerators and freezers. Its function is to keep the defrost heating element from exceeding certain set temperatures. If a refrigerator has lots of frost in the freezer compartment, the problem may be the limit switch. However, other components -- the evaporator fan, the defrost timer, and the defrost heater -- can cause the same problem. Check these for malfunctions, as detailed below. If these parts are in working condition, the problem is most likely in the limit switch. Don't try to fix the limit switch yourself; call a professional service person for replacement.
Sep 14, 2008 | Hotpoint FFM90 Bottom Freezer Refrigerator
Integrated fridge freezer growing iceberg..
problem could be one of two things.
insulation breakdown will cause an iceball to form.
if the compressor is failing, then frost line does not reach the thermostat poisition and compressor runs all time and an ice ball will also build up
in either case, not worth repair
Sep 06, 2008 | Refrigerators
Fridge is not cooling
if you found the coil iced up then there is a defrost problem check thethermodisc and defrost control board if you know the heater is ok
Jul 09, 2008 | Hotpoint FFM90 Bottom Freezer Refrigerator
Fridge on top of freezer is not chilling
if you have a french door (also known as bottom mount, freezer on bottom) and your fridge sections(cold air blows from freezer to refrig) is not cooling try this
1. ensure you hear the fan running, its it not, thats it(most likely fan motor
IF fan is running check these things
1. ensure refrig section light shuts off by holding down the switch
2. ensure door shuts
3. clean conderser coils (usually accessed from front through base grille)
4. check for icing in vents, freezer section contain them at top or back, and for a bottom mount the refrig sections vents are under your BIG drawer. if iced try a hair dryer from distance. or empty food into another fridge unplug open doors, and plug back in two days later this should defrost all ice build up
May 02, 2008 | Refrigerators
Water always inside refrigerator sometimes ice forms
Sounds like you might have a condensation problem. Is the fan in your freezer working? If not it's not circulating the cold air. If it is you might have frost on the lower rear wall of your freezer meaning its not defrosting like it should and restricting your air flow. Last but not least you have a damper door in the upper left corner of your fridge that allows the cold air from your freezer into the fridge to cool it, that might not be opening up. Any one of these things would cause your water problem and a warm fridge section
Dec 05, 2007 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Open Questions:
See all Hotpoint FFM90 Bottom Freezer Refrigerator Questions
Hotpoint FFM90 Bottom Freezer Refrigerator Logo
484 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
