Question about Whirlpool LHW0050PQ Front Load Washer
How do i check the filter - Whirlpool LHW0050PQ Front Load Washer
  • Whirlpool Master
  • 17,130 Answers
The front filter is at the inlet point of the water hose and the drain filter at the outlet hose of the hose.
you can remove the hose and find the dirt collection prior to the drain pump/valve.
There is also the lint filter within the drum which must be cleaned often
Posted on Sep 29, 2010
Change filter on Samsung refrigerator
Press the filter and turn. It will pop out.
Check filter housing and filter. It will show you which way to turn. Normally press and turn counter closckwise.
Check your user manual.
Check your new filter box. It may too have instructions.
Oct 26, 2017 | Samsung Refrigerators
Oil leaking above filter what comonly causes this? Have checked front seal all good
What type of vehicle? Is it external filter or internal housed filter?
Always check filters by removing and checking for a double gasket on external type. It is a flat o-ring that fits inside filter, there sh I uld only be one. On internal filters, remove the upper casing and double check the small o-ring for wear, such as cracking or kinks.
Sep 27, 2015 | Cars & Trucks
Engine old is leaking at the back of the engine where the old filter is
check that the oil filter is not leaking at the gasket. check that the filter is on tight but not over tight . check that filter is not leaking at the fold seam. check that a rocker cover gasket is not leaking oil down past the filter.
Jan 22, 2014 | Cars & Trucks
Purchased focus sport 2006 model no service manual. Mileage 43,000 kms. Need to know service intervals either time/mileage perhaps a copy of the service schedule will suffice.
These maintenance intervals come from the maintenance interval calculator
at www.autozone.com, using a starting point of 25,800 miles (43000 km), and
assuming 1000 miles (1666 km) driven per month, and "severe driving conditions," which
are actually normal usage characteristics, such as frequent short trips, urban driving, waiting in traffic, driving in hot weather, trips under 16 km in cold weather, etc.
STARTING MILEAGE: 25800 (43,000 Kilometers)
Item
Action
Service History
20000 miles or 32000 kilometers
Battery Check
Oil Filter, Engine Replace
Engine Oil Replace
Vehicle Inspect
Brakes and Traction Control Inspect
Tires Rotate
21000 miles or 33600 kilometers
Steering and Suspension Lubricate
Engine Oil Replace
24000 miles or 38400 kilometers
Engine Oil Replace
25000 miles or 40000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
27000 miles or 43200 kilometers
Engine Oil Replace
30000 miles or 48000 kilometers
Battery Check
Air Filter Element Check
Wheel Bearing Lubricate
Fuel Filter Replace
Engine Oil Replace
Fluid - A/T Replace
Cabin Air Filter Replace
Vehicle Inspect
Cooling System Inspect
Wheel Bearing Inspect
Ball Joint Inspect
Drive/Propeller Shaft Inspect
Exhaust System Inspect
Steering and Suspension Inspect
Heat Shield, Exhaust Inspect
Tires Rotate
33000 miles or 52800 kilometers
Engine Oil Replace
35000 miles or 56000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
36000 miles or 57600 kilometers
Engine Oil Replace
39000 miles or 62400 kilometers
Engine Oil Replace
40000 miles or 64000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
42000 miles or 67200 kilometers
Engine Oil Replace
45000 miles or 72000 kilometers
Battery Check
Fuel Filter Replace
Engine Oil Replace
Vehicle Inspect
Ball Joint Inspect
Tires Rotate
48000 miles or 76800 kilometers
Engine Oil Replace
50000 miles or 80000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
51000 miles or 81600 kilometers
Engine Oil Replace
54000 miles or 86400 kilometers
Engine Oil Replace
55000 miles or 88000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
57000 miles or 91200 kilometers
Engine Oil Replace
60000 miles or 96000 kilometers
Battery Check
Fuel Filter Replace
Spark Plug Replace
Fluid Filter - A/T Replace
Engine Oil Replace
Fluid - A/T Replace
Vehicle Inspect
Ball Joint Inspect
Tires Rotate
63000 miles or 100800 kilometers
Engine Oil Replace
65000 miles or 104000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
66000 miles or 105600 kilometers
Engine Oil Replace
69000 miles or 110400 kilometers
Engine Oil Replace
70000 miles or 112000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
72000 miles or 115200 kilometers
Engine Oil Replace
75000 miles or 120000 kilometers
Battery Check
Fuel Filter Replace
Engine Oil Replace
Vehicle Inspect
Ball Joint Inspect
Tires Rotate
78000 miles or 124800 kilometers
Engine Oil Replace
80000 miles or 128000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
And you can continue the pattern from there...
May 14, 2011 | Ford Focus Cars & Trucks
I had a honeywell hepa air purifier 50250 given to me as a gift with no owners manual! Is there somewhere I can get one? also, there is buttons on the top, one saying check filter and the other saying pre...
http://www.honeywellpurifiers.com/ssi/pdf/honeywell/50100-200-300-manual.pdf
The Intelli-Check™ Filter Monitors will indicate replacement of the pre-filter and the
HEPA filter. Depending upon your individual usage (environment and hours used),
you may need to check and replace the filters more or less frequently.
To check Expected Filter Life Usage
When the unit is turned on, quickly press the appropriate filter monitor button. The
pre-filter light will flash up to 3 times and the HEPA filter light will flash up to 4 times,
depending upon how much expected filter life has been used.
PREFILTER:
1 flash = from new, up to 1/3 expected life used up
2 flashes = between 1/3 and 2/3 expected life used up
3 flashes = between 2/3 and all of expected life used up
Remains on = time to check/replace pre-filter
HEPA FILTER:
1 flash = from new, up to 1/4 expected life used up
2 flashes = between 1/4 and 1/2 expected life used up
3 flashes = between 1/2 and 3/4 expected life used up
4 flashes = between 3/4 and all of expected life used up
Remains on = time to check/replace HEPA filter
To RESET Filter Monitor
When the filter monitor light remains on, it is time to check/replace the filter and reset
the filter monitor, if needed. With the unit powered on, press and hold the appropriate
filter monitor button down for approximately 5 seconds until the light turns off.
Page 6:
Mar 29, 2011 | Kaz Honeywell Hepa Air Cleaner (50250) Air...
My mighty lite only runs on half throttle. model #ut21506 Thanks
Check air filter if dirty clean with mild soap and water let dry apply very thin ammount of oil ( any type will do) to sponge type filter put a rag around filter squeeze excess out replace filter. Check spark plug clean if dirty, check electrode in center of the plug if rounded it should be replaced, gap check according to specifications. check ceramic filter in fuel tank if installed, if so empty fuel carefully remove filter by hlolding line and filter. Don't let line fall back into tank. find somthing to hold it so not to damage line. Or ask a friend or family for a hand clean filter with carburetor cleaner, replace filter. fill tank with proper fuel mixture. Good luck! Happy trimming!
Sep 11, 2010 | Homelite Mighty Lite Lawn Trimmer
Oil leak behind oil filter
you probably have the old gaskket still on the filter or the filter receptacle. Remove the filter and check to see if the gasket is on the filter. Then check where you screw it on there may be the other gasket stuck to that.
Dec 26, 2008 | 2004 Hyundai Elantra
Red light won't go off
To RESET the Electronic Filter Check:
When the filter check light remains on,it is time to check/clean the HEPA-Type
filters and reset the filter check,if needed. With the unit powered on,insert the tip of a ball-point pen or
paperclip into the hole next to the LED filter check light and hold for approximately 5 seconds until the
light turns off (Fig 5). Depending upon your individual usage (environment and hours used),you may need
to check and clean the filters more or less frequently. If the HEPA-Type filters are cleaned before the filter
check light turns on,the filter check should be reset at the same time.
These cleaning intervals are intended as guidelines only. Performance of any filter media is dependent
upon the concentration of contaminates going through the system. High concentrations of contaminates
such as dust,pet dander and smoking will reduce the useful performance of the filter.
NOTE:The HEPA-Type filters are not washable.
Fig.5
May 24, 2008 | Honeywell HHT-090 Air Purifier
Kaz Honeywell Tower Air filter rest light
When the filter monitor light remains on, it is time to check/clean the IFD™ filters and reset the filter
monitor, if needed. With the unit powered on, insert the tip of a ball-point pen or paperclip next to the LED
filter check light and hold for approximately 5 seconds until the light turns off (Fig. 3). Depending upon
your individual usage (environment and hours used), you may need to check and clean the filters more or
less frequently. If the IFD™ filters are cleaned before the filter monitor light turns on, the filter monitor
May 18, 2008 | Kaz Honeywell Tower Air Purifier with IFD...
Dryer keeps stopping - check filter light on
For Sgt 48 - You are not reading the original message very well - The original help question didn't say they saw check filter at the beginning or end of a dry cycle they indicated that the dryer STOPS MID DRY and says check filter - this is not a friendly reminder, it is indicating something is wrong and the filter needs to be completely cleaned out (and past the filter down in the interior of the dryer) and if that does not work then you need to also check the dryer hose for kinks, lint build up, etc. Lastly, reset the dryer by unplugging it (or flipping the breaker) for a minute or so and hold down on the start/pause button for 8 seconds while it is unplugged (this will reset the error code for check filter, among other things).
May 13, 2008 | LG DLG2525S Electric Dryer
Whirlpool LHW0050PQ Front Load Washer Logo
53 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
