Question about Mi T M WP-2700-4MHB Pressure Washer
HI can you please tell me rv anifreeze can be used in cars or is it just for powerwashers thank you
  • 17,130 Answers
The anti freeze is to be used in cars only as when the cars are parked out in cold countries the water in the radiator, engine jackets , water pump should not freeze as it will damage the pump or the expansion in the radiator will damage the radiator , hose engine. Hence the need.
Posted on Sep 29, 2010
Can you please tell me the name of the exterior joint sealer used to seal my 2007 jayco stirling caravan.product name please or safe equivalent.
contact jayco factory and ask them for the product that they use . They will have a contact number on the net.
Jun 07, 2014 | Cars & Trucks
2001 ford escape 3.0 engine no power in cylinders 4,5,and 6
wonder if it brings a check engine light on? check your coil packs spark plugs/wires - could be a bad injector - could be a vacuum leak - could be an intake leak causing anifreeze to be introduced into the combustion chamber - same with the head gasket could be blown causing the same effect as an intake gasket most of the time if you check your spark plug they will tell you everything like oil on them would be black and oily if its been introduced to water/anifreeze could show signs
Sep 26, 2013 | 2001 Ford Escape
JVC RV-B550 Cassette/CD Boombox Hi there. Please
take off all the knobs and it should come apart
Aug 01, 2013 | JVC RV-B550 Cassette/CD Boombox
Lavor Super wash Powerwasher.Lidl. Pressure leak O ring replaced at Venturi & wrote down wiring diagram for On/Off switch as follows- Blue Red Brown, Black. Had to disconnect wiring from On/Off...
hi i have a lavor 160 superwash all off the lances work except when i put the turbo lance on it gives high pressure and then goes to low pressure like starting then stopping can anyone help me or tell me what the problem may be
Feb 28, 2011 | Kitchen Ranges
Why is it blowing cold air all the time sometimes if i turn the power down it blows a little bit warm but not much
Hi, it sounds like you flow is restricted, probably due to clogging of the heater core. You can try back-flushing the core by removing the heater hoses on the engine side and attaching a garden hose to the lower heater core port using a bit of hose and some clamps. Run the hose to flush out the core. If flow is good, replace the hoses. If not, you may need a new core. Please let us know if you have more questions, and thanks for using FixYa.
Jan 11, 2011 | 1998 Audi A4
I can't start my powerwasher. Where is the choke?
This Power washer has a 3.75 hp Briggs and Stratton Engine. It does not have a choke but does have a primer bulb. You must depress the primer bulb at least 3 times to start the engine. The primer bulb is on the side of the carb. It can be black or red. If your still unable to locate the primer bulb please provide your ENGINE model number and I will provide you a link to a diagram for the location of the primer bulb.
Thanks for using FixYa.
Kelly
May 29, 2010 | Briggs & Stratton Gas Pressure Washer...
Bissell powerwash upright deep cleaner 1690 j
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
werw
Jul 08, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
2000 ford taurus leaking anifreeze
You should try checking all of the hoses, also how long does it take for it to run out?
Jan 08, 2009 | 2000 Ford Taurus
Problem with my 2000 ford taurus water pump.
I just had that same problem with the antifreeze leaking and I thought it was my water pump but I pulled the antifreeze tank off and it was cracked all along the bottom and that was causing the antifreeze to leak out real bad so I went to a nearby junkyard and found a new tank and replaced the cracked one and now it works just fine with no leaks. I hope this works for you liked it worked for me.
Jan 07, 2009 | 2000 Ford Taurus
Mi T M WP-2700-4MHB Pressure Washer Logo
44 people viewed this question
Top Mi T M Garden Experts
andy just round the...
Level 1 Expert
Are you a Mi T M Garden Expert? Answer questions, earn points and help others
