Question about Harley Davidson 426290 AM/FM Radio
Cd player calibration player is giving 3 beeps every few seconds says to recalibrate
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • Harley Davidson Expert
  • 281 Answers
The Country and Version codes have not been programed into the radio. Your Harley dealer can code it if the radio is in an 06 or newer. if you have the radio installed in an 05 or older, it will need to be removed and programed by Iron Cross Audio.
Posted on Sep 29, 2010
I cant remember how to recalibrate my baby lock esante ESe.I found the answer before but didn't write it down.Now it is out of calibration again and I can not find how to do it. Please someone help. I
Turn off machine. Hold in the 3 buttons above the needle. Turn machine on. Voila in screen calibration mode. Using touchpen carefully touch numbers 1-5 in order. repeat until you hear beeps. turn off machine. restart and your good to go.
Oct 01, 2014 | Sewing Machines
Treadmill incline not working
The incline system may need to be calibrated. To initiate the calibration routine follow the steps below.
Step 1
Place the key into the machine. The key's slot is located on the bottom of the console, below the start and stop buttons.
Step 2
Press any of the incline buttons and then remove the key from the machine while the incline is changing. Pause for a few seconds and then put the key back into the slot.
Step 3
Wait as the treadmill automatically shifts to the highest possible incline and then descends to the lowest level. The treadmill should now be recalibrated.
May 30, 2014 | Nordic Track NordicTrack Treadmill, A2550
Tt30 is stuck at 3% incline and will not speed up or slow down. It also beeps continually and displays SB for about 5 seconds when first turned on. I tried the recalibration procedure and it does not...
please RUN the software calibration for easy diagnostic and fix it.
go to HOOD cover motor, and follow the steps, or ready your owner manual
God bless you
Oct 15, 2013 | FreeMotion Tt30 Incline Trainer
E3 error on sole E95 elliptical
The E95 incline motor is out of calibration. Recalibrate the incline by holding the UP INCLINE button and the START button simultaneously for 5 seconds. This will put the machine into incline calibration mode. Press ENTER to start the calibration and let it run. It will take a minute or two.
Refer to page 25 (the last page) of the user manual, hidden right at the bottom.
Sep 20, 2012 | Exercise & Fitness
I have a 2004 hyundai and my cd wont go in and their is no cd in player. what is wrong
try recalibrating it,read owners manual it will tell you how to calibrate it
Aug 27, 2012 | 2004 Hyundai Santa Fe
Radio stations
There is a radio option to recalibrate your touch screen. Please press the following three hard keys simultaneously RADIO/MEDIA, SEEK UP, NAV (AUDIO on REN). Once you begin to recalibrate the touch screen you must finish. Audio confirmation prompts are provided for each of the three points of calibration, one beep for the first, two for the second and three for the third. The calibration needs to be precise as possible and a PDA stylus would be recommended. The MyGIG radio requires the user to repress each calibration point to confirm the calibration process. A green crosshair indicates proper calibration.You must not start with the "+" but with the "+1", then goto "+2" and last to "+". Repeat this until all crosses are green and exit with pushing the menue or any other key. Done
Jul 20, 2012 | 2008 Dodge Grand Caravan
My touchscreen doesnt work on my Ikasu 8gb media player for some reason anyone know how I can fix this?
If the touch screen does not work, it may be because it is out of calibration.
You can go into settings and navigate using the buttons to recalibrate the touchscreen.
Slide the on/off slider briefly. It should give you a menu.
Use the - button to scroll down to calibrate.
Push the M button
This gives the calibration screen.
Press the small square that appears in each corner, and finally in the center.
This should give you the touch screen, hopefully working.
There is a manual and other information here.
www.fascin8.co.uk/f8/ikasu/mp4-players/8gb-touch-71939#tutorial
Jan 31, 2011 | Audio Players & Recorders
Garmin 2610
Back up the unit then do a master reset.
Switch OFF, Press Page + Menu and turn on, holding the buttons for 5 seconds.
Then recalibrate. I did the recalibrate a few times before it was OK. If you use a stylus when the cross appears and hold it on the screen and move it to the corners you can see the error. Make a mental note and go halfway between the two if it does not calibrate at first go. Then when it calibrates, do it again. I recalibrate every now and again. I think it could be a firmware problem. I will try going from 4.8 to an old version
Feb 24, 2008 | Garmin StreetPilot 2610 GPS Receiver
Cannot get "Test Mode Menu" with remote
Press and hold mute and return on the player and turn the volume control clockwise, the setup menu will appear after a few seconds.Go thru the menu and do the required disc calibration.Do not mess with settings you don't understand, else you'll create more problems than you solve.Have some good single,double layer DVD ,SVCD and CD for the calibration.
Cheers,
Patrick.
Dec 21, 2007 | Sony DAV-S300 System
Motorola a1200 screen calibration
If the screen calibration is way off then it seems that you can't even click on the crosshair during screen calibration. However, tapping on the crosshair does seem to adjust the calibration a little in the right direction each time, it's just not obvious that anything happened. So the trick is just to keep trying - gently and repeatedly tap the same spot on the crosshair for several seconds - eventually the screen will calibrate.
Oct 06, 2007 | Motorola Mobility A1200
Harley Davidson 426290 AM/FM Radio Logo
205 people viewed this question
Top Harley Davidson Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Harley Davidson Audio Player and Recorder Expert? Answer questions, earn points and help others
