Question about GE JBP66 Electric Kitchen Range
JBP66G W1AD Oven won't get hot enough
11 year old oven wasn't heating properly. Bottom element crumbled when I touched it. Replaced bottom element. Still wouldn't get above 200F, and takes it forever to get there.
Replaced heat sensor in oven. Didn't fix it.
Replaced electronic panel on top. Didn't fix it.
Checked breaker and power cord, both good.
Pulled panel off back of stove, started checking wires. Heat sensor checks 1097 ohms. Top element 19 ohms, bottom 24.
Found a yellow wire running from back of control panel down to where bottom element sticks through, but the yellow wire wasn't hooked to anything on the other end. I don't recall any yellow wire being attached to bottom element when I changed it.
Cannot find wiring diagram for stove.
Where does this wire go and is this my problem??
Thanks for your help
Todd
  • thebinions Jul 06, 2008
    The yellow was the oven temp sensor. Thanks.
The yellow may be the oven temp sensor?
Posted on Jul 01, 2008
Maytag oven won t heat up
the upper element only comes on when you broil or clean with selfcleaner. the bottom comes on when you are baking, it sounds like your bottom element is bad.
May 07, 2014 | Maytag Ovens
Bottom oven bottom element doesn't heat
Phil. If you do not have voltage at the element, then the Electronic Oven Control ( EOC ) has failed. Part number # 5701M403-60
In order to check for the correct voltage at the element you will need to remove power and pull the range out of its installed location and remove the back panel of the range to gain access to the wiring and element. CAUTION ! I cannot stress this enough ! There are dangerous voltages in this area!! After the panel has been removed, return power to the range,set the lower oven to bake, and check the voltage at the element. You should find 220-240 volts between the element terminals with them connected to the element. If you do not have the proper voltage then you will need to replaced the EOC.
Apr 18, 2014 | Maytag MER6772 Gemini Electric Kitchen...
GE standing electric oven range. Oven lower element will not heat up.. only gets Luke warm, can still touch it, although the upper oven element gets very hot. What could the issue be?
Sounds like the bake element - do a visual check and look for blistering or cracking. If it looks normal, unplug the oven (or flip breaker for wall oven) and then you can remove the screw holding the element and pull it forward enough to unplug it and do a continuity test with a multimeter. If it test bad, replace the element.
Apr 09, 2014 | GE Kitchen Ranges
Diplomat ADP 5520 Stainless Steel Range not getting hot enough
The circular element that the fan sits behind heats the oven. Ensure the thermocouple is back in the right place. Too near the element and the oven will stay cool.
Circular elements can be pricey and fitting should cost no more than an hours labour.
http://www.espares.co.uk/search?SearchTerm=ADP5520%20element
Jun 23, 2017 | Ovens
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 | Dacor Ovens
Frigidale 10 years old stove bottom heating
Have 10 year old fridgidare elec.oven. Model no.FEF355ASE and both bake and broiler have stopped working have power and ohm's are good. Whats next ?
Jun 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Hi i have a very old 1970? whirlpool electric single oven
It sounds like you burned out the oven heating element control board.
Jul 18, 2017 | Whirlpool Ovens
Self-clean not cleaning
I was wrong (I think).  the baking element probably was burnt out as the repairman said.  He replaced it and I thought selfclean still wasn't working.  In fact, I think I just had to give the self-clean function more time.  Also, I was judging by smell.  We have become used to a bad odor during self clean which was missing when it was broken and still missing after the repair.  Bottom line, the oven was clean after the baking element was replaced, sans smell.
Apr 19, 2008 | GE Profile JTP18 Electric Single Oven
Oven wont heat up properly
This may be the thermostat control.
I would find someone to check the resistance of the element with an ohm meter.
It should read 15 to 20 ohms.
Put the timer on manual first and try the oven, because it could be the timer.
It would be ok to just replace the bottom oven element because most of the time it is a faulty element.
Feb 12, 2008 | Ovens
GE JBP66 Electric Kitchen Range Logo
853 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
