Question about LG Washing Machines
My washer has CL,what is it? - LG Washing Machines
    President:
  • 1,554 Answers
It means the Child Lock feature which locks the controls is turned on. Look for the two console buttons, usually adjacent, with the lock and child symbols between them like the one shown below. Press and hold those buttons simultaneously until the CL light turns off to unlock the controls.
Posted on Sep 29, 2010
Trying to make a load, CL comes up wont let me wash cothes, help
CL usually means that the child lock (or front panel lock) has been enabled. This is useful when you clean the exterior of the washer without starting the machine.
Without the manufacturer and model, I can't identify the exact button or pair of buttons to toggle the CL on or off. However this will be indicated on the washer in a very small font. There are two patterns for the child lock feature. In one case, there will be a button with a small padlock symbol on it. This will be below the button or on a second line on the button. Press and hold this button for 3+ seconds or until you hear a tone or see the CL removed from the LCD panel. On other washers, there will be a line between 2 buttons with either the small padlock or a picture of a child's face in the middle of the line. Press and hold the two buttons together for 3+ seconds or until you hear a tone or see the CL message disappear.
I hope this helps. For an exact solution, please add the make and model of your washer. Then I may be able to give the exact button or buttons needed to toggle off this lock.
Sep 09, 2017 | Washing Machines
Code for CL
On many washers, CL is child lock. This feature locks the most of the front panel buttons; it's useful when you clean the control panel. It also keeps small children from starting the washer with a pet (or sibling) in the unit.
Look on the control panel for a small lock icon or the words Child Lock. This will be in a much smaller font than most of the icons/text on the washer. You need to press and hold the appropriate button or pair of buttons to disable the lock. If a pair of buttons are used, the lock icon will be in the middle of a line between the buttons.
Please add a comment with the specific make/model of your washer if you would like more information about cancelling the lock. On my washer, the CL will remain on even if you unplug the washer for several minutes.
Jun 12, 2017 | Washing Machines
Lg wm2140cw washer error code cl My lg washer show cl and I couldn't use my washer
CL means that your washing machine’s CHILD LOCK is ON. You can find two buttons Temp and Options in the panel.
Turn ON the machine, press these two buttons together for 3 seconds and that’s it.
It might have a little kids face above a lock key, in between the wash and rinse buttons, hold these for 3/5 seconds and it should work.
Jul 29, 2016 | LG Washing Machines
I have a CL blinking in the display. How do I reset?
LG Washer Error Code Cl Fix - ApplianceRepairLesson.com
www.appliancerepairlesson.com/.../cl-error-on-lg-washer-repair-help-lg-t...
Jan 19, 2011 - CL means that your washing machine's CHILD LOCK is ON. You canfind ... CL popped up on my display had no idea what it was because the manual didn't say. ... I have the touch screen panel and it does not have temp or option buttons ... I've had tried to reset but won't do do I press temp and what else
How does Child Lock work on my washing machine?
www.samsung.com/au/support/skp/faq/868833
Samsung ElectronicsOct 23, 2015 - If the Child-Lock function is activated, the Child-Lock icon will blink. ...If 30 seconds have passed after opening the cover when the Child-Lock ... Step 5: To clear "CL" error on the display, close the door of the washer after ...
[PDF]Washing Machine - Home Depot
www.homedepot.com/.../d7064d64-8ea1-487d-9c35-a...
The Home DepotJan 3, 2015 - Warnings and Important Safety Instructions in this manual do not ... Donot wash or dry articles that have been previously cleaned in, washed in, soaked ......the Reset water level, "CL" is displayed on the LED display without.
Jan 19, 2016 | Washing Machines
Waht does code CL mean when trying to fill washer
Cl Average current limit Or Instantaneous current limitIf a status signal comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display either CA for average current limit trip or Cl for instantaneous current limit trip. Average current trip occurs if there is a 2 second average of current draw greater than 5.55 amps at the motor windings.
Instantaneous current trip occurs if there is a spike of 26 amps instantly at the motor windings.
This may signify problems with the drive motor, thermal protector, or motor controller. Over-loading the unit may cause this problem.
Sep 29, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Error code CL
The CL fault indicates that there was an instantaneous current spike of 26 amps at the motor windings in the washer. This could be caused by overloading the washer. It can also be caused by problems with the drive motor, thermal protector or the motor controller.
You should have been able to clear the display by pressing the STOP/CANCEL button.
If you try running the washer again and continue to get this fault code even with a small or medium load, I recommend calling a service technician to diagnose and repair the washer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 19, 2009 | Kenmore Washing Machines
CL Code
Jul 28, 2009 | Washing Machines
TROMM Washer "CL" Error Message
THE CL ERROR CODE IS CHILD LOCK, PRESS AND HOLD THE PREWASH BUTTON FOR 3 SECONDS AND IT SHOULD TURN OFF........ BUT IF THERE ARE OTHER BUTTONS TO PRESS TRY IT OUT, THE OLDER LG'S HAD TWO BUTTONS TO PRESS, SO IF YOURS ARE THE OLDER ONES TRY IT OUT..... IF THIS HELPED OUT, PLS LEAVE A FEED BACK. I DO NOT ACCEPT PAYMENTS FROM ANYONE ONLY FEED BACKS, IT MOTIVATES ME TO HELP OUT OTHERS WHO NEEDS HELP....................
Jun 24, 2009 | LG WM2688HWM TROMM SteamWasher
Lg intello washer error code cl
fault code "cl".you have your child lock function on.push the two child lock buttons together on the control panel,hold them for a few seconds till the "cl" icon dissapears
Jan 29, 2009 | LG WM-2277HW Front Load Washer
Washing Machines Logo
199 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
