Question about Gateway Computers & Internet
Is there a reset button on the motherboard of a gateway m685-e laptop or fusablelink / fuse
Jjjzkjxz
Posted on Dec 15, 2011
How to replace dvd optical drive
without knowing your particular laptop.They are usually held in by 1 or 2 screws or a catch.An owners manual or youtube guide may be available.Once removed a label on the drive will give details needed for a replacement.If you get a bare drive you will need to swap all parts from the old to the new drive.Once ready installing is the reverse of removing.
Aug 29, 2014 | Gateway M685-E Notebook
I want to wipe my laptp and restart with my Window 7 disc
You don't need anything special, just insert the Genuine MS Win7 CD-Rom and have the key code handy. Reboot your PC or laptop and choose a clean install. It will erase everything on your HDD.
Jun 29, 2014 | Gateway M685-E Notebook
Where is the battery button to reset the bios on a Gateway laptop model #400SD4 located?
just pull that battery off the board for a couple minutes, the also may be a little button you will be able to push on the board
Jan 25, 2013 | Gateway 400SD4 Notebook
Ineed a power adapter for a M685-E
searching online for "Gateway M685-E power adapter" will result in numerous sources for obtaining one online.
Sep 03, 2012 | Gateway M685-E Notebook
How to fix charging problem on Gateway M685-e
  1. check you AC adator you must find 19V as output voltage.
  2. try to remove your battery and power on without it.
Jan 02, 2011 | Gateway M685-E Notebook
Install os gateway laptop doesnot see harddrive
I generally run into this problem when the laptop is running in SATA mode. Check the BIOS for any options to put the hard drive in compatibility mode or to disable SATA mode.
Apr 15, 2010 | Gateway M685-E Notebook
Spilled liquid on keyboard, need to remove keyboard to try and clean up spillage. cant remove keyboard because of the power button
if the computer is on, u cannot remove keyboard for safe purposes. u can press cpu power button for a long time till the computer shuts down. this shuts down the pc safely. after the pc shuts down remove the keyboard. u can either clean it or replace with new one.
Feb 19, 2010 | Gateway M685-E Notebook
Resolution problem
Go to where your graphics card is installed and open the control center, you should be able to set your own custom pixel by pixel resolution. If you have ATI you need to go to your program files, select the catalsty control center. If you have nividia, go to control panel and select all categorys to view everything.
Jan 03, 2010 | Gateway M685-E Notebook
No power press power button blinking red battery light
If it is not taking a charge your power adapter is loose. To confirm this press on the cord where it plugs into your laptop and continuously press the power button if it powers up thats your problem. You may need to press the cord at various angles before you get it to power up push it in and pull to the left, then the right, up, down and so forth.
If this is your issue you can temparly fix it by using duct tape once you find the right position for the cord that will work for awhile but you will need to get it soldered eventually. If you know someone who knows how to solder ask them if they will do it for if not the repair will be approx. $100
Dec 16, 2009 | Gateway M685-E Notebook
Gateway m685 freezes after it runs for awhile, then more quickly
It is probably being caused from over heating.
Are the cooling fans running? If so, get a can of air from an electronic store, and blow the cooling system out from the exhaust in to the fan. Stop the fan from turning with a paperclip or something.
Mar 20, 2009 | Gateway M685-E Notebook
Computers & Internet Logo
70 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
