Question about Linksys Wireless-G WRT54G Router
Cannot get hooked up to router - Linksys Wireless-G WRT54G Router
  • Trogdor May 11, 2010
    Can you clarify by not getting hooked up to the router?
  • 48 Answers
Connect your pc to the router then check if it is getting an Ip address. if not hard reset the router by pressing the reset button on the back for 39sec then unplug it from power.
plug it back then check if you are getting an ip if there is an ip you can access it definitely
Posted on May 29, 2008
Cant hook up my ps3 to my netgear wgr614 n150
need to get ps3 component cable that can hook directly to the router,if it is a wireless router goto ps3 setup menu,then turn on network discovery on ps3,then will ask for password from router fill password in,it will hook up.
Dec 21, 2012 | NetGear WGR614 Wireless Router
With the router hooked up getting on the internet is slow. hooked to cable one direct it's o.k.
Your Wireless speed is all down to the quality of the router and wireless card, and where you are in relation to the router.
Hooking up direct is always going to be faster.
You could experiment with the position of the router in the room.
Check your speeds wired and wireless, use www.speedtest.net.
You could buy a better antenna for the router
Aug 25, 2010 | Linksys WRT160N Wireless Router
There's no place on modem to hook router
Look for Ethernet jacks. You want to hook both your computer and your daughter's laptop to the router to out ports i.e. usually on the front side. The back side of router would hook using probably another Ethernet jack to your modem.
Jul 02, 2010 | Belkin (F5D7230-4) Router (587009)
How to hook wired router to cable box. What is WAN outlet
all of your computers should get hooked up in ports 1-4 and the WAN port should be hooked up to your broad band router from your internet service provider. so if your first computer is hooked up to port 1 just plug your second into port 2 and every thing will work fine.
I hope this helped.
Thank you,
Norse
May 18, 2010 | D-Link (DVG-2001S) Router (DVG2001S)
Hooked up arris modem with lynksys G series router
You have to set seting from routers menu. To use it hold 15 second router restart button, that restore factory setings, then go browser http://192.168.1.1/ , and use username "admin" and password "admin" in default. There you can set setting by your connection.
Aug 12, 2009 | Arris Touchstone 450a (CM450) Modem
Hook up router and can't access internet from wired computer.
Sometimes the modem-computer-router not "sync" together.
Try this.
1-hook the computer to modem. Internet yes? good.
2-hook the computer to router and check you IP. If it like 192.168.1.2,
the router's DHCP is working.
3-reset router to default setting.
turn off all and turn on modem, router, computer.
keep me posted.
Jul 06, 2009 | Belkin (F5D7231-4) Wireless Router
Just moved
You need to hook up the AC power supply to your router, hook up your cable modem to your router, there should be a specific port on your router, most likely yellow in color, you'll hook the modem to the router using the supplied ethernet cable, it looks like a big phone cord.
Apr 21, 2009 | D-Link 802.11g Wireless Router WBR-1310...
No internet signal from router in other ports
Hello, Under the wireless menu on router you must give a ssid name and enable and save to turn on wireless , hoe this helps?
Mar 21, 2009 | Linksys Wireless-G WRT54G Router
Can hook through modem but not router
Is the modem plugged into the special port on the router?
Jul 06, 2008 | Linksys Wireless-G Broadband Router
Linksys Wireless-G WRT54G Router Logo
19 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
