When trying to print, my printer says 'HP Deskjet F2200 series Verbinding verbroken (=connection broken)'. My printer seems to work fine though, since I can print of the test page.
5 Suggested Answers
xclancy
  • 82 Answers
SOURCE: no driver for hp deskjet F2200 all-in-one series?
Please find the below link for all-in-one Printer HP F2200
Choose appropriate operating system
Driver for HP F2200
all the best
Posted on Jan 04, 2009
  • 158 Answers
SOURCE: hp F4200 deskjet problem
Please follow the best option that are given :
1) Check all the cable.
2) Check you cartridge position and install it correctly.
3) Remove the old copy of your driver and try to download latest driver from http://h20180.www2.hp.com/apps/Nav?h_pagetype=s-002&h_lang=en&h_cc=us&h_product=14438&h_client=S-A-R163-1&h_page=hpcom&lang=en&cc=us and install it.
4) If cartridge condition or its refill time is over then try to use new cartridge.
Posted on Feb 22, 2009
SOURCE: hp deskjet F4180 prints wrong
I had the same problem and the solution I found was to uninstall and then reinstall the printer driver. For some reason this worked. I now get the correct colors.
Posted on Dec 20, 2009
firesnake09
  • 2923 Answers
SOURCE: Printer is offline & will not print ... not even a test page.
First, make sure that the printer is properly connected to the computer and it's turned on.
Go to Control Panel > Printers > right-click the printer icon > select "Use printer Online".
Make sure the clear the pending documents on the queue before trying to print a test page.
Thank you for using FixYa!
Posted on Jun 13, 2010
There's a document in the Hp deskjet f2200 series that i canceled cause the printer didnt print it (of course i clicked the print button) , im canceling it and then the status changed to...
disconnect the usb cable from the printer to computer then turn off the printer, restart the computer then check the pending again if it is empty connect back the printer
Aug 07, 2011 | Office Equipment & Supplies
Printer will not print
I recommend downloading the latest driver updates. You can get them here:
h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=18972
Also check your printer settings to make sure they are set on plain paper and full size. Under your writing program, make sure your settings are unicode.
Jun 02, 2009 | HP DESKJET 2200XI 14PPM 600DPI PRINTER p/n...
Can i install my hp deskjet f2200 on linux?
Hp Linux driver for the 22xx series can be had at this link...
http://hplipopensource.com/hplip-web/models/deskjet_aio/deskjet_f2200_series.html
Additional info and drivers can be had on most printers under Linux at...
http://www.openprinting.org
May 16, 2009 | HP xw4600 Workstation Linux Installer...
No driver for hp deskjet F2200 all-in-one series?
Driver for HP F2200
all the best
Jan 04, 2009 | Office Equipment & Supplies
Help get software for new printer
Greetings,
Since F2200 is a series number it is hard to get a specific driver but if you look on the lable on the back or bottom of the printer you should be able to see what the actual printer model is.
Here is a link to all of the F2200 series downloads on the HP website. Once you know what the actual model number is for your printer all you will have to do is click on the apropriate option and download the driver for your OS.
If you need any additional assistance please let me know.
Here is the link:
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-002&h_query=Deskjet+F2200+&submit.x=10&submit.y=9
Dec 30, 2008 | HP Office Equipment & Supplies
Printer disc is f2200 but printer is deskjet f2280
Don't Worry you have the right disc.
The printer you have is of Deskjet F2200 Series and F2280 Is on of them.
Although the printers are segrigated but the Printer driver and software are the same for the F2200 Series.
So you can install the same.
Good Luck
Oct 04, 2008 | HP Office Equipment & Supplies
Mac not printing to HP Deskjet F2200 series
1) First let's make sure the hardware is working. Place a document face down on the scanner glass. Press Start Copy Black. Did it scan and print?
If not, please let us know.
If it did, go to the next step.
2) Please confirm the USB cable is plugged firmly into the back of the printer and to the computer. Do not go through a hub, switch, or router.
3) Click on your Apple icon (upper left corner), System Preferences, Print and fax.
Do you have the F2210 printer listed more than once?
I am going to suggest removing the F series printer. Highlight it and press the minus button to delete. Once you have removed it, close all windows back to the desktop.
On the computer click on Hard Drive > Applications > Hewlett-Packard > Device Utilities > HP Setup Assistant. Follow the on screen directions to add the printer back to computer. Do not re-register the printer (choose skip or register later). Once your are able to click finish, try printing again.
I would suggest trying to print from Text Edit first. This will rule out any possible issues with the Word document you were trying to print. Click on Hard Drive > Applications > Text Edit. Type your name in the untitled screen. Click on File > Print. Make sure the F2200 series printer is selected. Click Print. Did it print?
Sep 24, 2008 | HP DeskJet F380 All-In-One Printer
26 people viewed this question
jasbo
jasbo
