Question about Olympus SP-350 Digital Camera
In side flash not working - Olympus SP-350 Digital Camera
    Brigadier General:
  • 3,006 Answers
Unless your camera remains under warranty, repairing the flash is usually not cost-effective. Repair is not a DIY option and it must be done professionally. If you visit the Olympus website in your country and go to the service page you will often find that there is a fixed price repair menu on offer.
You may find it's cheaper to fit an external flash to the external hotshoe especially if you can buy a good used flash, but you must ensure that you either use an Olympus or Panasonic model; you may use other independent makes such as SunPak or Metz (expensive, but really worth it) but must ensure that they're suitable for digital cameras. Older flashguns designed for 35mm film cameras can pass too much voltage through your digital camera and damage it. You may also need to activate the external flash hotshoe via the menu as on most cameras it's inactive until selected. Note that an Olympus/Panasonic badged unit will give you full automatic operation, but if you use independent models then you will have to set everything yourself for "non-dedicated" models, and on more expensive "dedicated" models you may have fully automatic operation or may have to enter some settings manually. "Dedicated" flashes are those which have electronics and features tailored to particular camera brands.
Although an external flash is bulkier, the trade-off is that even lowly specified models will far exceed the output of your built-in flash. This enables you to use flash at greater distances and also provides more even illumination of the subject.
Posted on Sep 29, 2010
Right hand side of hob flashing reverse 9 or p inop on t4343 other side of hob working ok
right hand side hob not working. Flashing on and off with a sign that looks like a reverse 9 or P maybe?
Feb 28, 2011 | Neff 23 in. T4343 Electric Cooktop
FIAT DUCATO 2005 WHERE IS THE FLASHER RELAY UNIT INDICATOR ON LEFT SIDE DON'T WORK, HAZZARDS ON LEFT SIDE DON'T WORK, ITS NOT THE BULBS AS ALARM FLASHES ALL 4 INDICATORS.
2006 fiat ducato left indicator only flashes a couple of times then stops also the hazard lamps only work on right side
Sep 28, 2010 | 2006 Fiat Strada
Tail lights work on both sides. turn signal and
Sounds like you need to replace the drivers brake/tail light.
Dec 14, 2009 | 1998 GMC Sierra
Dreamland Imetec blanket.1 side controller flashes red.Swapped controllers,problem still there.Seems confined to 1 side of the bed as both controllers work fine on the 'good' side but neither work(ie. both...
I have been getting over this problem by operating the switch slider very rapidly. Sometimes it has to be done back and forwards a dozen times before the light stops flashing.
Nov 01, 2009 | Kitchen Appliances - Others
Flashing #4 on temperature display
flashing #4 is a communication error between the control board and the damper assy, usually it is the fault ogf the damper assy but if it is under mfg warranty, replace both, if you need to pay for the parts yourself get the damper first.
Oct 24, 2009 | Frigidaire GLHS36EESB Side by Side...
2006 pt cruiser on drivers side rear turn signal
The turn signals flash depends on each and every bulb working correctly. When one bulb fails, you will notice a change in the flash frequency, as you describe.
Replace or repair the bulb that is not working, and you should be good to go.
Doc
Sep 14, 2009 | 2006 Chrysler PT Cruiser
My powershot G9 built in flash is not working
There is a switch on the hot shoe to detect the external flash. When you use an external flash, the switch will be pressed down, then the unit will bypass the internal flash and won’t let it fire. If the little switch gets stuck somehow, you won’t get your internal flash on.
Check this switch on the hot shoe (either on the left side or the right side), blow some compressed air then plug/unplug an external flash several times. Hopefully you can get it back
Feb 06, 2009 | Canon PowerShot G9 Digital Camera
Canon powershot A630 blinking flash graphic
You have to unscrew the left side of the camera (if you're looking at the back of the camera, the side that is right beside the flash). Then, at the very top, with a tiny screw driver, just gently tap the black flash compartment and it should work after that. I've had the flash problem twice in the past year and both times I got it to work again by taping on it. Hope it helps!
Nov 06, 2008 | Canon PowerShot A630 Digital Camera
Ice maker not working flashing green
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
dfdf
Jul 28, 2008 | GE PSS29NHP Side by Side Refrigerator
Olympus SP-350 Digital Camera Logo
101 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
