Have an AGFA DS5500, Type 5364/300, code ESKZV, FN: 14997 printer for which the installation software cd is missing. We need to reinstall it on a CT. How can I get this cd?
Please contact me if you need the supported for getting the CD
my email: voquocbao@hotmail.com
Regards
Bao
Posted on Jun 24, 2011
KODAK ESP 3200 SERIES WILL NOT SCAN
I had the same problems; missing Icon and 100-2105.
This solution on the Kodak web site solved my problem.
http://support.en.kodak.com/app/answers/detail/a_id/1276/kw/ERROR:%20100-2105/selected/true
From your computer desktop, select Start > Run.
Type %windir%, then click OK.
Double-click the twain_32 folder.
Right-click the kodak folder, then select Delete.
Insert the KODAK All-in-One Printer Software CD into the CD drive, then go to D: > printer > scanner.
NOTE: The CD is indicated by D: above. The CD drive may be a different letter on your computer.
Double-click aioscannr.msi, then follow the instructions to remove it.
Go to D: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
Start Home Center Software.
Select Scan Documents and Pictures.
Scan a document.
If the error continues using a Wi-Fi connection, make sure you select the correct printer in Home Center Software.
If the error continues using a USB connection, see the following section to reinstall the printer.
Jan 13, 2012 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have a Agfa SnapScan 1212u, but I can't find a driver to it. I have the system Windows 7
Although Agfa no longer supports their scanners with drivers and software updates, some Vista and Windows 7 users say they are still able to install the XP software and get it to run. In another thread, broccauley said: 'I got my Agfa Snapscan 1212U scanner to work fine with Windows 7. All I did was to install the XP Agfa Scanwise 2.0.0.9 software FIRST (available from Agfa website). Then I went to Devices and Printers, right-clicked on the 1212U and chose "Troubleshoot" - Windows then found and installed the driver automatically.'
Dec 15, 2010 | Agfa SnapScan 1212u Flatbed Scanner
Missing all in one program
The All-in-One software might be corrupted or not installed properly. Try to reinstall it. The software can only be installed using the installation cd. The Lexmark All-in-One software is not available for download online since it's a big file. If you don't have the cd or you lost it, I suggest you contact Lexmark Technical Support. They can send you one for free.
May 02, 2010 | Lexmark X2250 All-In-One InkJet Printer
Are there drivers for the agfa snapscan 1212u in windows 7 platform?
As far as I can tell, the driver has not been updated for either VIsta or Windows 7. If you have Windows 7 Professional or Ultimate, you have a workaround option. Install the XP mode and then install the scanner to that virtual PC.
I hope this helps.
Jan 05, 2010 | Agfa SnapScan 1212u Flatbed Scanner
AGFA Drystar 3000
System software damage, need to reinstall with the backup disk.
Dec 12, 2009 | Office Equipment & Supplies
I hooked up my printer, adn it is saying that it can't find software for printer. Printer is AGFA-ACCUSET V52.3
try using printer install wizard. in contorl panal standard agaf might run it. or have you got the disk if you have reinstall it but remove old one first and close the computer down befor re installing it.
Mar 26, 2009 | Dell A940 All-In-One InkJet Printer
Agfa drystar 3000
Dear my Friends,
oftenly there are 03 cause for this reason:
firstly the problem can cause from the Power Supply. you should check for all the led on Power supply unit is light or not. if all of them is lighted please change to next step.
secondly, maybe the hard disk can not boot because the OS of this printer have problem you need to re-install the software for this printer. regularly this cause often is the main cause for this problem because this printer will not stable if the electric is went out while printing 95% for this case must be re- install the software . this is the reason while Agfa always warning you should use a UPS for this printer.
Notice: just only this type drystar3000 have this problem. others type is ds5300 ds5302 ds5500 ds5503 ,. drystar AXYS can solve this problem by itseft.
Thirdly, the cause can be from the Main MEC + THEMIS main boards (seldom happen with this reason)
please help me to re-check again,
do let me know if you have any question.
Regards.
email to : baoagfa@vnn.vn or quocbao.vo@agfa.com
Vo Quoc Bao - Service engineer
Agfa Representative Office in Vietnam.
91 Nguyen Trong Tuyen Str, Ward 15, PhuNhuan Dist-hcmc-vietnam
Dec 03, 2008 | Office Equipment & Supplies
Agfa Snapscan e25
cant find updated drivers for agfa E20 flatbed scanner?
Jan 23, 2008 | Agfa SnapScan E25 Flatbed Scanner
66 people viewed this question
k24674
