Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
Small white and black rectangels on my screen
Today I turned my TV and was met with small white and black triangles, all over the screen. There was no picture but there was sound. I have had the TV since Nov, 2004 and have had no problems except for the inner mirror getting dust all the time. Prior to the triangles, I have had no warning sings that the TV was going out. Along with triangles, the green timer light continued blinking after I turned the TV off. I tried the reset button but that did not work. I unplugged my TV for a couple of hours and the green light began to blink again but then stopped after a minute. I then turned my TV on a again and the triangles were back. I have called a technician, they will come out next week.
  • Joe62725 Jun 26, 2008
    I have the same problem with black and white RECTANGLES. Tried everything you mentioned as well. Still nothing. Did your repair man figure out the problem?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 317 Answers
Weak signal??
Posted on Jun 12, 2008
Sharp tv has small black and white image in black and white and half screen pink
Sounds like your LCD Control board went bad. Very small chance it is your main board since you said you cant bring up a menu.
Apr 11, 2012 | Sharp Televison & Video
While replacing the LCD screen on a cq60, I removed two plugs from the LAN card. What are they connected to? I lost them.
These plugs are connected to a black and a white (tan) wire. These wires lead through the hinges of the screen assembly and attach to metal clips at the top of the display under the bezel. These are the wireless antenna leads. The card itself will have the words main and aux. on it along with a small triangle that is either black or white, this is color coded to the proper wire at its connection.
Sep 05, 2010 | Compaq Presario CQ60-220US PC Laptop
No picture
Seems like the bulb needs replacing.....
May 28, 2009 | InFocus ScreenPlay 61" Rear Projection...
Small rectangular b/w blocks on screen, low frequency whine.
check for filter(capacitor) problem in the video portion of the tv, and control could be dirt or finger contamination inside the remote.
May 04, 2009 | Samsung HLN437W 43" Rear Projection HDTV
Black screen displaying only Garmin and a blue triangle
to soft reset & keep data....
Slide power key to on/off, hold it for 8/10 seconds
Update from Garmin, use the web-updater. keep it updated, delete old junk and POIs.
hard reset.
Hold lower corner of screen, while turning on, keep pressing, when "clear all data appears" click yes,
sould resolve the problem
Hope this helps.
Regards.
Feb 09, 2009 | Garmin nuvi 255W GPS Receiver
Xbox
well then your tv is going out and you need a new tv
Nov 03, 2008 | Microsoft Xbox 360 Console
Black screen
Same thing happened to mine. Somebody halp us! lol
Jul 07, 2008 | Creative Labs ZEN V Plus MP3 Player
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Small bluish, black triangle at far right corner
This is the same problem as other posts have mentioned about the right side of the screen having a bluish-balck stripe down the side of the screen. Here's what's happening. There's a small light tunnel which has 4 very small mirrors located just behind the color wheel. The lamp shines light through the color wheel as it turns and the light goes through this small tunnel and is then relected off several mirrors before it is projected through the lens and onto the screen. Optoma apparently did not use a very good heat resistant expoxy glue when they assembled these mirrors and over time the mirrors drop down causing a shadow effect on the screen. It can be repaired without paying some repair shop a small fortune. Previous posts have a solution from another contributer whihc includes photos. I had to repair mine and it's worked fine since I used a decent expoxy to hold the mirrors.
Sep 28, 2007 | Optoma RD65 65" Rear Projection HDTV
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
80 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
