Cannot get disc out of disc drive I have gone into OS and then on the drive on click eject on my computer. I have redone this in sage mode i have tried flashing BIOS to version 112 from dell website
  • 17,130 Answers
Could it be a reason for a harware fault. it will be good to remove the cd drive manually and check if the system is jammed or faulty as all other external triggers have been tried,
Also if the drivers were reinstalled then it must work, if the PC had not errors with any other program and is working fine then this can be the reason, if not you will need external booting to reinstall and proceed.
Posted on Sep 29, 2010
How do you force eject a disc from a macbook pro?
Five ways to eject a stuck CD or DVD from the optical drive
Ejecting the stuck disc can usually be done in one of the following ways:
1. Restart the computer and after the chime press and hold down the left mouse button until the disc ejects.
2. Press the Eject button on your keyboard.
3. Click on the Eject button in the menubar.
4. Press COMMAND-E.
5. If none of the above work try this: Open the Terminal application in your Utilities folder. At the prompt enter or paste the following:
/usr/bin/drutil eject
If this fails then try this:
Boot the computer into Single-user Mode. At the prompt enter the same command as used above. To restart the computer enter "reboot" at the prompt without quotes.
Regards,
Alex
Aug 14, 2014 | Apple MacBook Pro Laptop Computer with...
How do eject disc from my mac os x
Every Mac that has an optical drive has an eject key on the keyboard. Pressing the eject key will eject a CD or DVD.
The eject key has this icon on it: ?
You can also right-click on the disk icon, then choose "Eject" from the pop-up menu.
You can also click once on the disk icon, then choose "Eject" from the File menu.
You can also drag the icon to the Trash icon in the dock.
The eject key will only eject CDs and DVDs, but all of the other methods described above will also unmount other media types, like a hard drive or flash drive connected via USB, FireWire, or Thunderbolt.
Aug 13, 2014 | Apple Mac OS X Snow Leopard (10.6.8)
INTERNAL CD DRIVE WONT OPEN
There are a couple of issues that can cause the tray of an internal optical drive to stay closed when you press the drive's eject button. One: there is no power to the drive. If the drive does not show up in the list of discs in the computer, this could be your problem. (In any Windows OS, click Start > Computer (My Computer) or double left click the icon for Computer.) You will need to open the computer and check that the power cable is fully seated and oriented correctly (it won't fit the wrong way). For a desktop, an IDE drive uses a 4 pin power connector. A SATA drive uses a 15 pin power connector. If your power supply has additional power connections for the type of drive, try a different connector. If the power connector has a 4 pin to 15 pin adapter, make sure this is fully seated. (Try a new adapter.) If that doesn't help, make sure that the power supply is providing enough power for all devices. The second problem may be failure of the open/close mechanism.
I recently had an optical drive that slowly had the open/close mechanism fail. At first the eject button wouldn't work when there was no disc in the drive; using the Eject option from the OS did work. Then the OS eject stopped working consistently and it wouldn't eject with a disc in the drive. I used the Emergency ejection option (straighten a paperclip)to check for a problem with dirt in the mechanism or the belt slipping and then put a disc in the drive. Replacing the drive was my final solution. (A new CD/DVD burner is under $20; thus it wasn't worth my time to fix the mechanism on a 5+ year old optical drive.)
Some Lite-On (and related OEM) drives develop this problem early. For these drives, the problem is that the magnet that holds the optical disc in place actually blocks the drive tray. The solution that some find works, is to remove the optical drive and open the outer-case of the unit. (This should be avoided if the drive is still under warranty.) There is a circular section in the case and that is the section that you want to access. Pull out the magnet and make two circles of duct tape just slightly smaller than the magnet. Stick a nail through the center of the circles. (You need the hole to make sure that it still functions correctly. The circles are smaller than the magnet to avoid getting adhesive inside the optical drive.) Stick one of the circles to the magnet (and then put the second circle on top of that). Replace the magnet and close the case of the optical drive. Replace the drive in the computer. Plug in the data and power cables and close the computer back up. Make sure that the data cable is still firmly connected to the motherboard before closing the case. (Note: be careful to stay grounded relative to the computer case when you remove the drive and then replace it.)
The SE-S164L is an external drive, so you may not have given the correct model. Please add a comment with the model optical drive in your computer. Slot-loading drives require a different trouble-shooting routine.
I hope this helps.
May 12, 2012 | Samsung Super-WriteMaster SE-S164L DVD?RW...
Disc Drive
If the eject button is not working, assuming this is a Windows based computer, click on start icon, your start menu will display, on right side under your user icon you should see Computer or My Computer, click on it.
You will now see all drives in your computer. Right click on your dvd(optical) drive. You should see an eject option.
If this dosen't work, close to the eject button on the drive is a tiny hole that will accept a paper clip, carefully push clip into hole until drive ejects.
Feb 13, 2012 | HP Computers & Internet
My daughter put a small disc for her music in my mac computer how do i get it out
4. Press COMMAND-E.
Boot the computer into Single-user Mode. At the prompt enter the same command as used above. To restart the computer enter "reboot" at the prompt without quotes.Alternatively follow the following instructions: How do remove stuck Mini CD from the SuperDrive on Macbook Pro
Dec 29, 2010 | Apple iMac OS 9.1
My XPS 1640 is not ejecting DVDs, touch buttons does not function and firmware upgrade of OPTIARC DVD RW AD 7640s provided no relief. Any can help me.
Try going to MY COMPUTER, right click the drive, Click Eject.
If no change restart they system as sometimes software locks the drive. Also try booting in safe mode (Press F8 at boot) see if it will eject there.
If the drive still will not eject, then remove drive
http://support.dell.com/support/edocs/systems/sxl16/en/sm/optical.htm#wp1038494
remove the disc manually. reseat the drive and try it again. If still no go, replace the drive
Dec 25, 2010 | Computers & Internet
How do iget the bloody door open tp insert disc
Mac OS 9.2
  • Press the Eject key on Apple Pro Keyboard
  • To open the second optical drive on a Power Mac G4 (Mirrored Drive Doors) computer, press Option-Eject on the Apple Pro Keyboard.
  • Open the Eject application found in the Eject Extras folder. The Eject Extras folder is located in the Apple Extras folder on the CD.
  • Click the iTunes eject button (see Figure 1).
  • Hold down the mouse button when you hear the startup sound as the computer restarts.
  • Start up from Mac OS X and customize the toolbar with an eject button.
Mac OS X
  • In the Finder, Choose View > Customize Toolbar. In the window that appears, drag the Eject button to the toolbar, then click Done. Select the disc you want to eject in the Finder window, then click the Eject button in the toolbar.
  • Press the Eject key on the Apple Pro Keyboard.
  • If you have a keyboard without an eject key, press F12 (under Mac OS X 10.1 and later). Note: You must press the F12 key longer to prevent the tray from accidentally opening.
  • Click the eject button in iTunes (illustrated in Figure 1).
  • Start up from Mac OS 9.2 and follow the options in the section above.
Aug 18, 2010 | Apple eMac G4 Desktop
I need to remove a disk from a Sony NEC Optiarc AD-7640S
CD Stuck in Device
First try the normal methods to remove the disc. Drag its icon to the Trash can in the Dock or select 'Eject' from the File menu. If you are running a virtual machine, e.g. VMFusion, ensure that the CD is disconnected from the virtual machine. This will sometimes allow the CD to now show up in Mac OS X. Shut down the computer and start up whilst holding down the mouse button. This may take some time, but keep your finger on the mouse button right up until the disc comes out or the log-in screen has appeared. If you have Toast Titanium installed on your computer, choose EJECT DISC from the menubar. Sometimes you can successfully use the eject disc button in iTunes even if the disc is not visible to the Finder Open Disk Utility and choose the disc you wish to eject in the left-hand pane, then click on the Eject button. Some Macintoshes have a paperclip hole that you can insert a straightened paperclip into, manually triggering the eject mechanism. Open Terminal and type "drutil tray eject" to eject the disc/tray, and "drutil tray close" to close the tray. Restart the computer while holding down Command-Option-O-F, to enter the Open Firmware prompt. Type "eject cd" without the quotes, and press return. The disk ought to eject. To start into OS X, type "mac-boot" without the quotes. Press return, and the computer will continue with the startup. (This will not work on an Intel Mac. There is no Open Firmware on Intel Macs. ) If your computer has an eject button on the keyboard, restart the computer holding down the Option key. When the startup disk selection screen appears, let go of the option key and press the keyboard's eject button.
Dec 23, 2009 | Computers & Internet
APPLE IMAC G4 - TRYING TO INSTALL OS WITHOUT DISK EJECT BUTTON
Reastart the iMac and at the same time hold down the mouse left click button. If that does not work.
  1. Restart the computer.
  2. Immediately after the startup sound, press and hold the key combination Command-Option-O-F.
    Note: The Command key has the Apple and (commandkeysymbol.gif) icons on it.
  3. Release the keys when you see a white screen that says "Welcome to Open Firmware."
  4. At the prompt, type: eject cd
  5. Press Return, then wait a few seconds. The disc drive should eject any disc that is present, and "ok" appears behind your command when the action is complete.
  6. Type: mac-boot
  7. Press Return.
Dec 11, 2009 | Apple iMac G4 Desktop
When powered on it says os not found
Make sure that there is NO CD or DVD disc loaded in the CD/DVD drive while you are turning your laptop ON. Eject all CD/DVD discs are restart.
Nov 10, 2009 | Gateway MX3560 Notebook
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
