Question about Black & Decker String Trimmer Cordless 12" 18V
Black and decker trimmer
How do I put the little handle on my new black and decker cordless trimmer
  • OPDvolunteer Jun 15, 2008
    black&decker cordless 18 volt trimmer/edter, catalog number NST2018, NST2018G, NST2018L -- In the auxillary handle, there is a black bolt with a knob attached, a nut, and a strange black piece of plastic that fits between the two red bracket ends of the handle. However, we cannot find any way to screw these all together (they don't FIT) and without the screw, it is impossible to tighten the handle enough to hold the trimmer straight. The instructions or totally unhelpful--just some pictures that do not even SHOW the black pieces. Help?
  • Anonymous Mar 24, 2014
    When i went to plug in the adapter to charge my lawn hog the little connected on the handle of the trimmer is gone. Looks as if it fell inside the handle? Can I fix this?
I had the same problem and stumbled across the solution accidentally (the directions were of no help whatsoever). First, extend the trimmer to its full length. This will expose the little groove in the neck of the trimmer that the ridge in the black plastic piece is supposed to fit into. Make sure that you have snapped the handle on so that the open ends on the back expose that groove. Then, fit the black plastic piece between the open ends of the handle, fitting the ridge into the groove on the trimmer. Insert the screw from the side OPPOSITE where the nut is visible inside the handle. It should go right in.
Posted on May 25, 2009
    Champion:
  • 313 Answers
Can you specify what model
Posted on Jun 02, 2008
My Makita Petrol Strimmer won't start
If it is a gas (petrol) trimmer...then most often it is in the on/off switch on the handle. Before you go tearing anything apart...rock the on/off switch a few times to see if it helps. www.nnyparts.com
Jun 01, 2010 | Black & Decker String Trimmer Cordless 12"...
Describe your Black & Decker Grasshog
The push lock on the string feeder Is sticking. Pull it off, clean it out and put it back on.
good luck
Aug 07, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
I don't need a manual - I need a replacement handle
if your refering to the batt handle then its a obsolete item with no replacement part number. your part # is 243215-00 and your best bet is to sell it or put lots of ducktape or epoxy or keep checking ebay
Jul 09, 2009 | Black & Decker Cst2000 12 - Volt Cordless...
I want to Register my new Black & Decker GH1000 Trimmer/Edger (Grasshog)
Roy Hollandsworth june 27 2009
I Want to Register My New Black And Decker 18 Volt Cordless Trimmer model HST2018
Jun 27, 2009 | Black & Decker Power To Go Cordless AC/USB...
How do I get my Black and Decker 12"bump feed trimmer/edger out of the groom position and into the edge position? My boyfriend misplaced the instructions to our new edger and I can't figure it out.
The handle/shaft is in two parts. By grasping the upper part of the shaft with one hand, and the lower part with the other, you can move the two sections slightly apart, then twist to turn the trimming end 180-degrees.
Sep 15, 2008 | Black & Decker String Trimmer Cordless 12"...
Weedwacker wont turn off
We have a Black and Decker CST 1000 and other than the convenience of no cord, it constantly has problems. Won't hold a charge, spool holder cap broke and we can't find the part, handle cracked and finally broke. We have a black and decker blower and it won't turn off either. Fortunately it's corded so we can just unplug it. No more Black and Decker for us.
Jun 05, 2007 | Black & Decker String Trimmer Cordless 12"...
Black & Decker String Trimmer Cordless 12" 18V Logo
542 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
