Question about Zanussi FJS1225W Front Load Washer
Program sticking and spin cycle not completing
  • Zanussi Master
  • 17,130 Answers
Could this be a fault in the program controler unit that is making the motor stop spining.
A check on the motor voltage at the time of shut down is necessary to confirm if the voltage cuts off or if the motor is getting stuck.
If so check for faulty connection , connectors or failure in the controller.
Posted on Sep 29, 2010
Water drains but spin will not spin
This can be due to problems in the program cycle as it seems to over ride the program.
This can also be due to fault in the program controller unit , please try this with a separate program, also clean the drain , check the connections to the controller, check for fault in the level sensor.
Jan 01, 2013 | Washing Machines
E04 Error
E04 is a time out on the heating phase, to confirm this run a cold cycle, if the machine completes the cycle but sticks on any program above 40 degrees, best bet it's a faulty heating element.
Nov 27, 2011 | Bosch Washing Machines
Washing machine 11 years old is jumping on the wash cycles. EG instead of taking 25 mins its taking 10 mins to complete -clothes coming out wet unless manually turn to spin again
It is possible that the program is not running to the designed settings and so the program seems to skip the cycle.
The clothes come out wet because the spin cycle is not activated in the set program. Hence the program controller needs a check.
Jan 17, 2011 | Hoover Washing Machines
My washing machine goes through the wash cycle but when it comes to the spin cycle nf appears and it will not spin. I have to manually shut off and then press the spin cycle to complete the cycle, why is...
If this is happening with all the spin cycle then the program controller has some errors.
It will be good to select all the different programs to confirm on the fault.
Tighten all the connections, the leads to the controller.
Oct 30, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Moffatt washer is washing and draining but not spinning out the clothes
All content © 2000 © 2009 Washerhelp
> Home / Repairs DIY washing machine advice (part 8) Washing machine sticks or stops mid-cycle repairs-sm.gif A very common fault on washing machines is when the program timer fails to complete the cycle and stops part way through. Many people blame the program timer for this but although it is a possible cause, there are many more likely causes for this fault. The program will stick if the heater isn't working, if the thermostat fails, if it can't fill up with cold water for the rinses, if it can't empty the water etc. There are too many possible causes of this fault to be able to give anything other than rudimentary advice. However, the common causes of a washing machine sticking that can easily be fixed are filling and emptying problems.
Check that the cold water supply is available to the washing machine, which is a common cause for sticking on rinses. If the washing machine appears to stop mid-cycle and isn't filling with water on rinses then see Washing machine won't fill with water (or no water goes into washing machine) before calling an engineer. If the washing machine can't drain the water out then it will stick on the rinses, or it will abort with an error code. If you can see water still inside the washing machine then check the following advice Washing machine won't empty water
Dec 03, 2009 | Washing Machines
I have a Frig. Gallery washer and it will fill up and drain but not spin. What could be wrong and how can I fix it??
Dec 02, 2009 | Frigidaire Affinity ATF7000E Front Load...
Washing machine will not advance through the wash cycle, machine will fill tub and begin wash cycle but will not move on to the rinse cycle. The washing machine will remain in the wash cycle and can only...
Hi, Your timer motor burnt out, or timer faulty, remove top back panel (back of timer) and check timer motor, if timer motor are built-in (electronic type) you'll have to replace timer, or if timer motor can be remove, replace it, check back of timer, (knob you turn to change cycles or programs) locate timer motor, you can check appliance store to purchase timer motor, or let mechanic check, surely it's your timer motor or timer, check let me know,
Aug 12, 2009 | Whirlpool WTW5800SW
Nec nw-891 washing machine will not complete the programmed cycle
Apparent malfunction in the timer circuits. Specific Component replacement not available.
Jun 30, 2009 | Washing Machines
Washer Dryer flooding at spin cycle
Nicola...not sure what you mean by floods. If you mean that water is coming out of the top of the machine basket as a result of either overflow or splashing, each is different from water coming out of the drain hose.
Generally, washers which are spinning are also completing a rinse cycle...the program adds a bit of water to the spinning load to drive out the last of the detergent.
If you've got a problem in spin with flooding out of the top (basket full), this is probably a timer issue (or...less likely...a sticking water valve). If the problem is splashing, you should keep the cover closed for safety. If the drain hose is overflowing, the problem is lack of capacity to take the pumpout. Clean the drain.
May 29, 2008 | Washing Machines
Zanussi FJS1225W Front Load Washer Logo
70 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
