Question about Hobart 29 in. AM15-1 Free-Standing Dishwasher
Power supply (transformer)
We dont seem to have enough voltage on the power supply input? what is the secondary voltage is suppose to be?
  • Robert Lanteigne May 25, 2008
    none of the module (timer, etc ) seem to work, i the primary voltage is there but i have 6 volt on the transformer secondary (red lead pair ), the diagram say's that i should have between 13 nd 15 volts DC?
  • Robert Lanteigne May 26, 2008
    Thank you very much for the tip, i will do that, it is a failure type of problem... my assistant try to grounded all the device of the machine and it doesn't work since....
    i think it is an AM 14 or 15, the plate is in bad shape...
    the power supply has two secondary set of wire one blue and one red on the blue i have 110V and 6V on the red as mention on the previous what is suppose to be the AC voltage of the secondary transformer?
    Scholar:
  • 68 Answers
You should have just one supply voltage on an AM type dishwasher. Find the data plate in one of these places - frame behind RH door, on the control box, under the front cover. The required voltage and phase (1 or 3) will be listed there.
What is the problem with the unit?
Posted on May 25, 2008
  • AbsoluteServ May 26, 2008
    What is the model of your DW? Is this an AM12? If so, remove the red leads and take your reading. On an AM12, a bad board can pull-down the voltage. Is this a "failure", or is this a troubled install?
    If the last thing done was working with the supply or chasis grounds, you need your helper to retrace his steps.
    Check that your transformer is grounded WITH THE PROPER connections. Do the same for any ground on the secondary side. Also, when testing a transformer, choose your test points accurately. Don't take a reading from the secondary output to ground, if ground is not part of the secondary control circuit.
    Ultimately, I think your voltage is being pulled down. So isolate and divide the circuit as you test it. In case you dropped a leg on your supply, also make SURE you have all three hots. (If 3 phase)
    As far as the actual voltage you should be seeing, I would need to at least know the model number. But if the schematic shows 15 volts, that sounds right for an older AM, like an AM12. I know that Hobart schematics are most always accurate. So if it says 15 volts, you can trust that is accurate.
Receiving Error Code 1
1) See the calibration software below the hood of your owner manuals for to help to diagnostic.
2) Adjust the speed sensor and tight the connector.
3) Main motor faulty. see the voltage 115 vac, without load.
4) Main motor controller board faulty. See the 115VAC for input coming from Transformer.
5) Test the TRANSFORMER for input voltage and secondary voltage,
6) Power supply output for +5vdc, for input and output.
7) Adjust the deck belt and drive belt.
8) Lubicate the deck belt.and
See the block diagram the I did for people like you. And diagnostic very easy. Sincerely. Merry Christmas.
ernesto cuadra
managua, nicaragua
Dec 15, 2011 | Proform Exercise & Fitness
Power supply output for Yamaha p4500 secondary output for the power supply so that i could check the voltage
Hi Joel, although we've sourced detailed schematic for this P4500 amplifier, there are no many voltage details on it for manufactures sake. Anyway, mine findings are. Secondary winding on main transformer should supply no less than 2 x 75 volts which makes after rectifying and filtration no less than 2 x 90 volts on capacitors with amplifier without input signal. Also transformer has to be very "hard" , otherwise amp will start clipping before reaching stated wattage on output.
Oct 17, 2011 | Yamaha P4500 Power Amplifier 2-Channel
Drh55cg no heat appears to be no voltage at a small transformer secondary connects to gas valve there seems to be many safe guards
Since you have confirmed that the step down transformer is open, it is imporrtant to disconnect the secondary lead to confirm . If so identify the volatage to the valve and use a simialr voltage to be connected to it. If the fault clears then you can change the failed transformer.
However it is important to check the voltage to the other input areas so that the valve is opened so as to adjust the heat.
Use a multimeter to check, use a variable power supply to be bridged across the faulty output power.
Jun 13, 2011 | Kitchen Ranges
I have a Behringer xenyx 802 audio mixer and have lost the power supply. I tried to buy a replacement, but cannot find any in stock. I'm very resourceful and thought I'd make one. The spec sheet calls for...
No, you can't just jump the pins together. The power supply in the mixer needs two separate 18-volt AC inputs because it makes two supply voltages, +15 and -15 volts.
The external supply is just a potted 36-volt transformer with a center-tapped secondary. I bought an open-box Behringer (not your model, but similar) that was missing its supply, and found this transformer which works fine. (I actually did find a couple of sources for a replacement Behringer supply, but it cost more than I paid for the mixer!) Just connect the three output leads to the appropriate places on the mixer's PC board. In mine, I removed the original input connector and soldered a pigtail with a 3-pin connector from Radio Shack to the PC lands, then attached the matching plug to the transformer leads. You'll also need to provide an enclosure of some kind to prevent contact with the line voltage input to the transformer and to protect the thing if you carry it around.
Mar 29, 2011 | Audio Players & Recorders
Model 27LCDB03B-simply appears to be "dead" won't power up-not the fuse
Hello Chris, Hi, your TV's power supply section is not functioning properly. If the fuse is in good shape, then the auxiliary power section of the power supply is not functioning, this section powers the switching oscillator and IC that sends the pulse to the switching element like power transistors to create a main secondary voltage. the main secondary voltage is the circuit that produces all voltage needed source by the TV. what you can do if you are up to it.
A. Visualize any bulging capacitors, replace them. B. Measure the voltage across the following section in particular order so we can find the faulty parts.
  1. the AC input on the Power supply board. (none means open switch or power cable)
  2. the AC after the line filter circuit. (none means open line filter)
  3. the DC on the filter capacitor. (none means problem on the rectifier)
  4. then the AC on the switching element or input on the main transformer. (most likely you won't have any voltage reading hear.)if you do have continue.... (none means you scratch your head, this is the hardest part) check all low value resistors, high wattage resistors open or shorted diodes.
  5. the dc on the secondary filter capacitors.
If not have this checked by a technician, its to complicated for you.
Mar 12, 2011 | Thomson Televison & Video
My transformer is burned.Now I need to know what the secundairy voltages are
Transformers USUALLY don't get burned as they are usually protected by a fuse. This one supposedly uses a 3 amp fuse which should have protected it from getting burned. If you can find a schematic or if you can find the specs on the output amp power supplies we can probably calculate the voltage of secondary. We know only that it is supposedly 120 Watts and uses an 8 ohm speaker. The RMS voltage should be about square-root 120*8 = sqrt 960 = 31V*1.4 = approx 44 volts peak... so you will need to get about +/-45 volts out of the supply for headroom... which will need approximately 34 volts AC given diode drop and droop of filter caps. These are really rough educated calculations from the tiny bit of info we have.
Finding a transformer to replace this matching these requirements will be near impossible without getting device from the original manufacturer OR having your rewound.
I would first verify the transformer is bad (only plausible cause is somebody over-fused it or a winding shorted)... Remove all the secondary loads. Put a 3 amp fuse in AND put a 60 Watt light bulb in series with teh power cord to act as a limiting device to test the transformer... Note that transformers DO have a bit of odor as they are usually impregnated with a varnish...
Jan 11, 2011 | Hartke Kickback 12 Bass Amp Warehouse...
I live in New Zealand which has 240 volt supply on the grid. The zantrex 2000 works with an input supply of 120 volts. How can I use it?
Hi, OK, there are two ways to achieve this. One. Using an external STEP DOWN Transformer, 240 V AC, to 120 V AC. The ONLY thing that matters is KVA. As long as the KVA is the same ir will work. This means as long as the Output Voltage and Current are the same, it's irrelevant whats on the Secondary. So if
The second, is to remove the existing transformer, and substitute with an exactly the same Secondary Outputs, BUT with a 240 V AC,. Input winding. Most likely it is a simple step Down transformer anyway, that steps down, whatever the external voltage is, down to say 12 -18 V AC. Therefor ANY suitable 240 V AC transformer with the SAME secondary winding(s) will work, no problems. You can even get some transformers Overwound, for 240 V AC, a very common thing, depending on transformer construction. There are a few transformer manufacturers in the "Yellow Pages" contact one of them and inquire.
As a tip, sometimes the existing transformer has TWO 120 V windings, and sometimes only ONE side is used, for US power, and for 240 V AC, you simply connect the other winding in series, and NOW you have got your 240 V AC to whatever.
Sep 01, 2010 | Inverter Xantrex MS2000 Sine Wave Charger...
What are the secondary voltages off the transformer supposed to be?
The secondary voltages of a transformer are stepped down voltages. For example a transformer might be stepping 120 volts AC down to 25 volts AC in the secondary. Which then would be rectified by a bridge rectifier in the power supply and converted to DC Voltage which would be used to bias transistors or tubes and other electronic components. The amount of voltage that is output for use is determined and calculated by the engineers designing the amplifier or pre-amp.
Aug 26, 2009 | Audio Players & Recorders
No control power
PRIMARY means INPUT(from supply side)
SECONDARY means output( to load side)
Sep 23, 2007 | Maytag M6D24E7A Air Conditioner
Hobart 29 in. AM15-1 Free-Standing Dishwasher Logo
183 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
