Question about Garden
How can i fit a support for a single storey garage roof and a brick gable end
  • 17,130 Answers
This might need a lot of calculation depending on the load of the roof , the material of the roof , the estimated storage load.
now based on these the size or material of the support coulumn can be decided as the structural design is most important to hold eventhough you have a brick end .
Posible use of Iron girders will be good.
Posted on Sep 29, 2010
Steering Gables for a 1995 Yamaha outboard motor does it have grease fittings
gables are on a house. Cables "may" have a grease fitting. Lots do not.
Sep 05, 2014 | Boating
Are you able to advise if a RAV4 will fit under a 25 course (height) garage roof?
25 course? what unit of measurement is that. metric, or Cubits?
measure the top of garage opening
then look up rav 4 height with full tire pressure. unloaded.
with roof rack, or sun roof?
5 ft. 6.3 in.(neat no rack etc)
1684mm
168cm.
1.84 yards
Jul 08, 2014 | 2006 Toyota RAV4
I need the written instructions to set up an avid screen gazebo 13x9 model 2086 that I just bought at a yard sale. PLEASE HELP.
How To Assemble Avid Outdoors Model 2086 Screen Gazebo
Start with # 4 poles. There are 4. Attach a #3A to each, and then attach #3 to the other end of the 3A.
These are the 4 legs.
There are 6 #2 and 3 #2A. Attach a #2 to 2A, and then #2 to the other end of the 2A. These 3 are the top ridge pole and the 2 side poles.
I believe there are 4 #1 and 4#1B. Attach a 1 and 1B together. Do this 3 more times. These are the gable poles.
You have 2 connectors that say gable and gable. These are for the top pole and 2 gable poles. You have 4 connectors that say gable and leg. Put the leg poles.....in the "leg" hole, the gable pole in the.....gable hole, and the side pole in the remaining hole. That shoule do it. It's easier to put the top together first, and then get 4 people to raise it onto the leg poles. Yes, the leg poles angle out, not straight down.
Jun 26, 2013 | Garden
Pumbing problem
You have a vent on the roof that may be clogged with debris or some solid object. You toilet works when this air vent is completely. Otherwise it will function like putting your finger over the end of a straw with water in it. The water won't drain out until you take your finger off it. This is essentially what is happening. You have a partial to a complete blockage.
Feb 09, 2013 | Home
Avid outdoor screen gazebo instructions for set up #2086
Start with # 4 poles. There are 4. Attach a #A to each, and then attach #3 to the other end of the 3A. These are the 4 legs.
You have 2 connectors that say gable and gable. These are for the top pole and 2 gable poles. You have 4 connectors that say gable and leg. Put the leg poles.....in the "leg" hole, the gable pole in the.....gable hole, and the side pole in the remaining hole. That shoule do it. It's easier to put the top together first, and then get 4 people to raise it onto the leg poles. Yes, the leg poles angle out, not straight down. How's that?
Sep 17, 2011 | Garden
I lost instructions for my Avid Outdoors screen gazebo model #2086 13'x9'. Any help is appreciated
avid outdoor doesn't offer instructions...can someone please post instructions for some of these...it would really be helpful...its crazy that some of these boxes dont come with instructions?!
Jul 18, 2011 | Garden
Colman mobile home gas furnace to use in my garage/shop
generally speaking a sealed combustion system is inherently more safe than a system that draws it's combustion air from it's ambient location. however, it cannot be considered 100% safe in a potentially hazardous location. The actual system that would be used in a "code compliant" installation would be a 100% outside air unit.
That being said, you can install this in a garage, the vent that you are referring to (if it is a standard mobile home system) is generally directly above the unit and usually no longer than about five feet. It also requires a listed and labeled termination "cap" If you install 90 degree angles or extend the vent too far you will have issues with condensation in the piping that will cause the pipe/ heat exchanger to fail prematurely.
If the system is a 90+ efficeint unit then the PVC venting is generally allowed to be about 30 feet long, with a 1/4 inch per foot pitch back to the unit for condensation, also the general mfg. instructions allow either 2- 90 degree or 4 45 degree fittings in the line. hope this helps
Nov 06, 2009 | Coleman Propane Forced Air Heater...
Attic roof vent fan- brand unknown. need motor and blade
Any Blade will be ok if it will fit shaft and they all should be cosistant and of course the higher the amp the better quality.I like the Pro 3 model at Home depot but I believe the Pro 1 gable is the 12 inch blade,pro 3 is 17 inch houseing and maybe 12 inch also.
Please rate jj505 Guru
Jul 11, 2008 | Kitchen Ranges
Garden Logo
74 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
