Question about Gaggia Classic Espresso Machine
My machine has stopped heating up. Taking the top off..I can see nothing obviously wrong (eg loose connection). The mains light is on ..so fuse in plug is ok.
2 Suggested Answers
SOURCE: boiler stopped working
sounds like the thermal fuse has blown on boiler. this is normally caused when boiler is run dry. needs to be serviced professionally
Posted on Aug 07, 2008
Can't control the speed on my sewing machine
you have a loose connection in the foot switch, remove from the mains power and get someone to open the box and look for obvious loose wires, better to be a professional electrician if you have no experience.
Jan 30, 2014 | Frigidaire Kenmore Washer Tub to Pump Hose...
Our Hunter Fan and Light with remote has been installed for over 1 year. It has always had the 'ghost' problem where it will randomly turn itself on or off but we have been able to live with that. Last...
Your ghost problem was probably due to a loose connection. The wire has probably come completely loose or the heat from the loose connection has damaged the relay.
Jun 20, 2010 | Hunter 52" Ceiling Fan With Light And...
Won't heat
The Breville esp8xl has a wire connector to the heat chamber that can become loose through repeated heat/cool cycles. Opening up the machine, finding this connection, which was loose, blue wire at back of heat chamber, and tightening it fixed my problem.
Aug 21, 2009 | Breville ESP8XL Espresso Machine
Have older machine always worked with no problem ....it is and FandP Intuitive top load.. today put in light load started off machined filled and stopped....now nothing is happening not even any lights....
If machine is completely dead ie no lights, then you probably have a faulty motor control module (main power board). These do not have any replaceable fuses, requires new module. Note- fault could be with another part of machine, which has caused module to fail eg faulty drain pump can blow control module. All other components need to be testedd before module is replaced, preventing a new module from blowing due to a fault elsewhere. These can be quite a complex machine, and not really easy to fix by untrained persons. Recommend calling service technician
Jul 31, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Boiler stopped working
May 30, 2008 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Espresso Machine Stopped Working
Mine stopped heating (pumped only cold water) and when I opened the top of the machine I noticed that the blue electrical cable to the thermal block assembly (probably to the thermal fuse, but I an not sure about that) corroded and was loose. I fixed the connection and since then the machine heats perfect.
May 12, 2008 | Breville ESP8XL Espresso Machine
Indesit WIE 147 - Display 'F-03' fault
Indesit washing machine error code 3 (F03) On certain Indesit washing machines, if the on off light is flashing 3 times, with a slight pause, followed by flashing a further 3 times, or if it is didplaying F03 you have an error code that is explained as follows -
NTC fault - check Thermistor and module connections.
The NTC is the thermistor, which is a modern-day thermostat. It’s inserted into a tube in the heating element and is filled with heat sensitive crystals that change their electrical resistance according to their temperature. By knowing what electrical resistance the crystals have at given temperatures they can tell the water temperature.
With this fault the NTC is either faulty, or there’s a dodgy connection to or from it or there’s a connection problem where it connects to the main PCB.
It’s not something you can easily fault find yourself unfortunately, apart from if there was an obvious broken wire.
Feb 10, 2008 | Indesit W 123 Front Load Washer
Creda 120vw washing machine fuse changed still no life
You start looking from the power plug, down to the power-cord. The power point in the wall, (plug in something else to check power), the pause switch on the machine, any lights on the machine? Did you open the door to get the clothes out?..........
Careful when the power is on & the top off.........
Dec 22, 2007 | Creda W100FW Front Load Washer
Gaggia Classic Espresso Machine Logo
16 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
