Question about Kitchen Ranges
Wertheim w4030 Vacuum Cleaner manual - Kitchen Ranges
  • Anonymous Mar 26, 2014
    vacuum cleaner not working, no power going through the machine
I have manual for Wertheim w4030 Vacuum Cleaner here with me.
Posted on Oct 15, 2010
Wertheim sewing machine manual
The frister rossmann machine is almost identical the manual is available free to download from ISMACS
Mar 31, 2014 | Sewing Machines
Motor wertheim X5000
Hi There,
I am not sure if you are trying to source a replacement Wertheim x5000 motor but if you are you can get one here.
http://www.vacuumspot.com.au/wertheim-x5000-vacuum-cleaner-motor-33300170
As it happens we have a parts diagram for this machine too but I can't find a way to upload it on the fixya site. If you actually need a parts diagram just email us through the link on the vacuumspot.com.au contact us page.
Feb 03, 2013 | Cars & Trucks
Wertheim vacuum cleaner 2000 does not seem to be having enough suction
If you are sure the is no leaks on suction line, please check and clean the filter. The common problem on weak suction vacuum cleaner are leaks and filter clog up.
Regards
Jun 18, 2011 | Vacuums
How do you open a wertheim 2000P vacuum cleaner?
SmartAlec from NelsonVacuums.com.au here. The ET2000 has a latch that is located at the very end of the machine lid (about 6 cm in front of where hose clips in. If you sit the machine up on its back end you should see the black lever that needs to be pushed in. Now I will also say that it is possible that you have actually been pushing this but the lid still wont open, this is because every now and again the whole latch moves itself out of alignment by about a milimetre. The easy fix for this is a gentle screw drive to assist the relesing of the catch, this needs to be gently pushed in at the same time as squeezing the latch (hand at top of latch screwdriver at base kind of toward the middle of machine). You should be able to get it open like this with only light pressure. Now of course if you need bags or filters please visit us at NelsonVacuums.com.au.
Kind regards Alec
Aug 02, 2010 | Vacuums
Vaccuum cleaner with a broken hose
Is it just the corrugations of the hose broken? With most hose fittings there are two small oval shaped lugs on the side of the fitting. Grab a small screwdriver and gently (you may need a little force) push these in to ease the click ring out.
Once out, you'll find a type of screw cuff. Some hoses just unscrew, some are glued in (use boiling hot water to soften to separate).
Cut the broken piece of hose off, make sure the click ring is still on the hose in the right direction, reaffix the screw cuff, and replace the hose (with click ring) back into the hose fitting.
If it's actually the hose fitting broken, check with your local Wertheim retailer or repairer.
May 20, 2010 | Vacuums
How to open the case of a wertheim b20 vacuum cleaner
Take out all the obvious screws around the base and coloured top using the appropiate driver.   There is one screw under the flap used to hold the dust filter in place.   The flap is spring loaded and can only be removed (as I see it) once the top is taken from the base.   To remove the screw I used a pair of long nose pliers and some patience.   Once the top is clear of the base, other screws can be easily seen and removed.
My problem was a badly worn bearing at the commutator end of the motor.   There was so much movement that the brushes would not follow the commutator with a result of excessive noise and sparking.   The brushes had dug into the commutator segments and chipped etc.
The bearing is permanently pressed into the motor end and cannot be replaced.   This means a new motor which, in my part of the world, was quoted as $250.00.    My neighbour will be purchasing a new vacuum cleaner but after 15 years with the old one he hasn't done too badly!
Mar 24, 2009 | Vacuums
Kitchen Ranges Logo
1,151 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
