Question about Intel Xeon FC-MPGA4, 3.4 GHz (bx80546kg3400e)
HOW TO SOLUTION INITIALIZE OEM SPECIAL CODE IN COMPUTER P4 INTEL
Can anybody help me identify what are the memory compatible with intel p4 2.4 Ghz cpu?
No. The memory is dependant on the motherboard you are using not the processor.
Aug 02, 2013 | Intel p4 2.4 ghz cpu
Error code on boot up of: Drive 1 not found:serial ATA, SATA-2
Computer can't find your hard drive which is drive 1, it does see your CD/DVD drives.
Jun 25, 2012 | Dell Optiplex GX280 Intel Desktop PC -...
Intel base-code,PXE-2.5 (build 083)
Go into the BIOS or System Setup and make sure you have it set to boot from your Hard Drive first. This might be trying to boot from a LAN.
Turn your computer off, then turn it on and watch for which key to hit to get into the Bios or System Setup.
Apr 06, 2012 | Intel P4 System Configurator (P4SDRAM1) PC...
Have a p4 machine doesnt power on when the cpu power connector is connected
this problem is always associated with power pack, i will advice you change the power pack.
May 19, 2010 | Intel Computers: P4 3.0GHz Mid Tower...
Dell Computer Refurbished Optiplex GX260
from what I can tell you can use NORTHWOOD CPUS or POWERLEAP modified cpus on the GX260 but not prescott. as these are incompatible
http://support.dell.com/support/edocs/systems/opgx260/en/ug/specs.htm#1110653 would suggest 400 or 533 based P4s
using Powerleap's configurator http://www.powerleap.com
it appears that it is possible to use an Intel P4 3.06GHz 533MHz 478pin 512K Northwood CPU w/Hyper-threading OEM
Oct 03, 2008 | Dell Computer Refurbished OPTIPLEX SX270...
AMD 64x 4000+ 2.2GHz is equivalent to which processor in intel.
Its rated the same as an old P4 that runs at 4000MHz.
Or are you meaning what current cpu is it equivalent too in the core2duo range?
Jan 07, 2008 | AMD Athlon 64 4000+, 2.4 GHz...
Dell Dimension 4100 Mobo upgrade to a P4 based system
Well the two would not be compatible cause one is a P3 and the next is a P4 two completely different socket types so it wouldn't work but what u can do is buy a new motherboard if u want to upgrade to a P4...thats the only thing that is recommended from such a devices cause an upgrade wouldn't be possible to do .
Nov 22, 2007 | Dell (2336V) Motherboard
Intel ASUS P4 845 GL Motherboard
Hi, For an ASUS P4BGL-VM Intel 845GL Chipset Ultra ATA100 MATX CPU Type: Intel Pentium 4 478-Pin (OEM), the Asus site specifies max of 2 x 184-pin DIMM Sockets support max. 2GB PC2100 / PC1600 non-ECC DDR or SDRAM memory but not "and". Personally, I find it more practical to install 2 X 1Gb rather than a single 2Gb. Hope this gives you some idea. Kind regards.
Aug 07, 2007 | Intel ASUS P4BGL-VM 845GL Chipset Ultra...
Intel Xeon FC-MPGA4, 3.4 GHz (bx80546kg3400e) Logo
155 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
