Question about Smeg S201X Electric Single Oven
Microven doesn't work. - Smeg S201X Electric Single Oven
Same problem here.
I just unmounted it and checked.
Main things you'd better check (if able, otherwise contact assistance..) :
- UNPLUG POWER
- Unmount, open the top (5 screws)
- microven fuse (open the top, standing in front look right top corner, there's a small circuit with wires and a black plastic case with a 250V 8A fuse in it): check it's ok
- microven transformer: it's the big one on the rear top, you need to check primary and secondary wires for short circuit (that's why the fuse blows up in case)
- magnetron: if both previous ones are ok, check (I can't say how except for getting a new one and trying..) and eventually replace the broken one.
Hope this helps
Posted on Feb 14, 2011
I just moved into a house with a Gaggenau EB 846-6. Light and fan work. Heating element doesn't seem to work in top or bottom 'socket'. Also, neither heating indicator light illuminates
since neither light is going on, then i believe that you either have a bad thermostat, or possibly that you only have half of the voltage going to it, and gaggenau doesn't have gas units so it doesn't have a glow bar like the previous guy said.
Jul 21, 2012 | Ovens
Electrolux EOU5330X Ultrafan Electric Double Oven -
Sounds to me like the lower element shorted and tripped the breaker as it burned out. If you're handy at electrical troubleshooting that's where I'd start - comparing ohmmeter readings between the bad element and the one that works.
A wire short to the chassis would have a similar set of symptoms and be easier to find and fix.
Beyond that, you need a service tech.
Sep 03, 2017 | Electrolux EOU5330X Ultrafan Electric...
Bottom baking element doesn't work. The element itself is OK
Is it getting power from the board when you select bake? If not I would suspect the board, especially if all else works ok. Does everything else work?
Sep 08, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Oven temp will not change
Most ovens have BAKE, BROIL and yours might have CONVECTION. Turn each on independently. If all don't work its one problem if only one doesn't its another
Also is it the gas doesn't ignite or it ignites then no temp change (or electric gets to xx degrees but doesn't get hotter?
Sep 04, 2011 | Wolf Range WKGD-2 Gas Double Oven
Tecnik Range dual fuel TKC 1285 (more than 10 years old) The timer clock doesn't work so we cannot set the timer for the oven to come on later in the day + Our oven doesn't work when we...
No you can replace timer or bypass it to make it work. I can source parts for you I and fit if required. David 'The Famous Forry'
Oct 20, 2017 | Tecnik Ovens
The oven of my Chef 635 model GSC6635SLP doesn't ignite (no gas comes out in oven, yes from plates), the ignition element is working, there is electricity in terminals connected to thermo valve but it...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 13, 2011 | Ovens
Hi there Have recently moved into a house with a Belling 626 white, electric cooker and the grill doesn't seem to be working. It has a mian oven, top ovem and "dual grill". The main oven...
ISOLATE THE MAINS POWER BEFORE CHECKING THE APPLIANCE
Run your fingers along the grill element, in this model it is accessible, check for raised areas or small hole or roughness not food burnt, if visible, it should be Black Grey colour at the blemish, you can obtain parts from www.whitegoods.co.uk you will need the model and serial numbers.
The grill elements come out but when unsrewed sometimes the ceramic holders crack, remove element before ordering as you may have to replace the element holders.
Hope this has been helpful
john
May 31, 2011 | Belling Ovens
My kenmore oven doesn't work. There was a poof and cloud of smoke from the back of the stove when I turned it on and it now longer works. The stove works fine. The clock doesn't light up anymore...
ISOLATE MAINS POWER BEFORE OPENING PANELS
It sounds like you have acomponent blow, (stating the ob), what I would recommend is a visual inspection. remove panel on rear, have a good look at wiring and conponent that are visable. If no sign of black short on terminals it may be an element. The fault could be in the panel circuit but that would not produce enough smoke, a fan motor can an element and a electric switch, they use the two terminal type mounted usually on the chassis, if this appears burnt out replace with the same temp type. To go further you will need electrical knowledge, and a test meter. Let me know if you require further assistance.
John
May 20, 2011 | Kenmore Ovens
My igniter on the cooker doesn't work, it doesn't click or make any sound
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
May 17, 2011 | Ovens
Smeg S201X Electric Single Oven Logo
139 people viewed this question
Top Smeg Ovens Experts
ashburton
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
