Question about Boss Car Audio & Video
I have a boss bv9976 and my wires where left in my old car at a junk yard and can't get them. Is there a way I can buy a new connector or just rewire it myself. Is so how do you read the diagram for wiring, does it start up or down?
Inferno77
  • 6 Answers
SOURCE: Lose wire with 6Wires connector... need diagrams of pin out
(There are different versions of the ba-200, so I'm assuming they al use the same wiring/pinout...) if you look at the amp on the enclosure(right-side up... so the writin goes left->right): The top left pin is #1, beside it is #2, then #3. The bottom left pin is #4, beside it is #5, then #6. #1 Right speaker positive input #2 Empty #3 12 Volt Constant Power #4 Left speaker positive input #5 Remote turn on / Acc power input #6 Ground Now there's supposed to be a 15-amp fuse on pin #3 (12v constan power).
Posted on Jul 27, 2007
  • 41 Answers
SOURCE: need to rewire entire jeep
If you want to rewire the vehicle, assuming that you will not be changing any systems, you can usually find complete new wiring harnesses from both the dealer and from aftermarket selllers like Quadratec and JC Witney.  Buying the complete wiring harnesses will be alot cheaper and less time consuming than trying to make them yourself.  These wire assemblies are just a plug and play deal, you disconnect a harness and replace it with the new one.  They may even include some instructions. If you need further assistance with custom wiring or diagnosis, I would recommend getting the service manual for the vehicle from the dealer or used ones from eBay ($30- $100).  The factory service manuals have complete wiring diagrams and schematics as well as full diagnostic information.  These service manuals are NOT like the ones found at your local parts store (Chilton or Haynes).  The factory service manuals are like complete blueprints for a car.
Posted on Dec 19, 2008
SOURCE: need to rewire my 1987 jeep wrangler
I have a book with the whole electrical, haynes repair manual has the diagrams . 1987 thru 2003.I have 1987 wrangler with some issues. How would I get you infobook 50030
l
Posted on Mar 20, 2009
  • 32 Answers
SOURCE: There is a repeating pulsating song while radio is on.
It sounds like the out put from the radio amplifier is damaged on the left side . swap the rear spkr wire from the left to the right if the problem moves to the right , then the radio needs repair. also this problem of spkr wires grounding or touching the car chassis can damage radio. Run new spkr. wires I hope this helps . Please rate this answer, thanks.
Posted on Apr 10, 2009
SOURCE: Need wiring diagram of connectors for Clarion
you can usually go to the site and put in the model # and request owners manual. it is in there but you need to have adobe reader.
Posted on May 09, 2009
My BOSS bv9976 isn't getting any power! Im installing it into a 08 Ford Escape. Wont ever turn on, light up or anything. I need to know what wires go where. And if the attena wire needs to be connect
go herehttp://www.bossaudio.com/product-info/manuals/ type in bv9976 in the search field
the manual will pop up - the wiring diagram is on page 7
Dec 24, 2015 | Ford Cars & Trucks
I have a 94 explorer limited that has the amplified stereo in it . the #@%^$*& guy that I bought it from cut the speaker wire end (little black end) Off . Does any one know how to rewire the end b
If you get the wire assembly from the junkyard you will not have to splice anything. Then the connector will go to the correct speaker. Also you may as well take the whole thing because snipping off the ends ruins the rest of the wiring for the Salvage yard.
You might want to know if the rest of the original wires were patched anyway.
Jan 24, 2015 | 1994 Ford Explorer Limited
Boss bv9976 wont play videos from USB?! Anyone know??
The Boss BV9976B supports playback of JPEG/MP4 and DIVX formats. Double-check to make sure your movies are in one of these formats. Then triple-check. Download a converter to convert your movies to the proper format.
Boss BV9976B manual
Dec 04, 2014 | BOSS AUDIO SYSTEMS BV9976 Car Video Player
2001 dodge ram van transmission wiring diagram
Take the switch off the old transmission and put it on the junk yard transmission. If it's too late to do that then get a new switch or back to the junk yard to find the correct switch.
Sep 24, 2014 | Transmission & Drivetrain for Dodge Ram...
How di i rewire a fuel pump
You don't rewire it
If necessary to replace some of the wire
for any reason, you repair the oe harness
You buy the same gauge wire,any color,solder
& heat shrink the part your cutting out.
If only the ends are a problem & you have enough wire
to reach the pump, you have to get the wire terminals
& replace them & hopefully use the oe connectors
If the connectors are problem, then you source your parts
from a salvage yard & do your solder thing
If your asking about buying a fuel pump & it looks or is wired
different,it is the wrong one, take it back
You just plug in the new pump,there is NO Rewiring or the pump
is not for your application ,or it came with no instructions
May 23, 2014 | 1986 Subaru XT
My boss BV9976 dvd player touch screen is not working
It's possible that the Boss unit works with iPod and iPhone 3 and not the four. Does the unit state that it works with iPod/iPhone? Also, you may require a software upgrade
Mar 17, 2012 | BOSS AUDIO SYSTEMS BV9976 Car Video Player
The mini USB port of my new Boss BV9976 doesn't recognize my i-Phone 4, but it works fantastic with DVD's, even if the vehicle is in movement.
It's possible that the Boss unit works with iPod and iPhone 3 and not the four. Does the unit state that it works with iPod/iPhone? Also, you may require a software upgrade.
Apr 04, 2011 | BOSS AUDIO SYSTEMS BV9976 Car Video Player
Blower motor resistor connector burned resistor. Went to change resistor and found insulation on two wires melted and connector was burned. Can I replace connector or do I need new wire harness?
You'll have to get the connector from an auto salvage yard. I doubt you'll wants to spend all the money or do all the work involved in changing a wiring harness.
When you get the connector get is with as much wire as possible on it. You can then use **** connectors to splice the salvaged connector in where you cut the old one out. Do it one wire at a time and use sealing or weather proof connectors.
Jun 22, 2010 | 2001 Dodge Dakota
I would like to know where I can find the connector for purchase to my corner lights?
they don't sell them, you have to modified it. go to a junk yard and clip off the used one making sure you cut off enough wire so you can rewire with the same color code with electrical tape. btw it will save you lots off money and headache.
Jun 23, 2009 | 1991 Honda Civic
Car Audio & Video Logo
64 people viewed this question
Top Boss Car Audio & Video Experts
xxxxxx xxx
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
