Question about Zebra MZ 320 Thermal Printer
I have a problem with my Zebra MZ 320 Printer feed button , each time I press feed button receipt paper running continually & stop after 10 cm ,I need to resolve that issue
3 Suggested Answers
RoryMRP
  • 111 Answers
SOURCE: Zebra Z4M continuously feeds paper and errors out.
It seems like you have a bad upper/lower media sensor or you need to adjust or clean it. If you remove your media and ribbon from the printer you will see two sensor's right behind the printhead. Printhead will need to be in the open position to see them. They should be emitting a red light. Clean and recalibrate. If that doesn't work it should the two sensors. They come in a kit. And just to be on the safe side you can call in to my technical support team to verify that is your problem. Its Free as long as parts that are needed are ordered thru us.
If you have any other questions please feel free to call.
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
708-597-4222 X240
AOL IM: RORYMRP
Posted on Jul 07, 2009
  • 185 Answers
SOURCE: Zebra TLP 2844 Desktop Printer
The printer driver should be set to Continuous or it will think it is still Gap or Black Mark. Please adjust accordingly
Posted on Dec 20, 2009
My Zebra ZDesigner LP2844 feeds a blank label after printing a label. How do I make it stop doing that?
Define your label size correctly. Measure your LABEL exactly, do not include the backing paper or the gap. Calibrate the printer. HOW?
Power off printer. Press and hold the green feed button down and power printer on. Count one, two and release green button. The printer will calibrate and move labels and then print some stuff on the label. Wait until it has comletely stopped. wait another few seconds and the press the feed key once. The printer will print "out of dump". You should now be ready to print again.
Aug 31, 2013 | Zebra LP 2844 Thermal Printer
Hi how can i reset the printer zebra lp2844 back to factory settings?
1.turn off printer
2.press and hold feed button
3.press power button
now led id blinking 3 time
4.then release both button
and single press feed button
now it will com receipt .... successfull
Let me know this helpful
Jan 06, 2011 | Zebra LP 2844 Thermal Printer
How to calibrate the label in QL320 plus zebra printer?How to make it only feed 1 label per print?
create a text file called Calibrate.txt and in the text file type this:
~JC
^XA
^JUS
^XZ
then send the file to the printer using label vista.
this will then print 3 - 4 labels and stop.
once u press the feed button it will only feed one label.
Dec 10, 2010 | Zebra QL 320 Thermal Printer
Printers lights is on but not printed properly ,i do test print but after 1 cm paper eject stop the printer in normal green light, and when i eject the paper after pressing feed button eject in 1 cm and...
You have something down in the unit or the roller carrier is broken - you must pull it apart or turn it upside down and shake it - after you will find something that will either fall out of it - like a paper clip or something of that nature or a bolt has come loose.
Best of it
Gary @ Fix Ya
Nov 26, 2010 | Zebra LP 2844 Thermal Printer
Reset mz 220
Power off, then hold down the paper feed button while you power back on. A description of this is in the full users guide.
Nov 25, 2009 | Zebra MZ 220 Thermal Printer
I have a 5110 error
1. Switch off the printer.
2. Holding button STOP/RESET press the button ON/OFF. Do Not release the buttons.
3. Continuing hold the button ON/OFF release the button STOP/RESET. Do Not release ON/OFF.
4. Continuing hold the button ON/OFF press the button STOP/RESET 2 times and release all buttons.
5. When indicator COPY засветится GREEN - press the button STOP/RESET 4 times for unset памперса.
6. After striking 4 times buttons STOP/RESET press the button ON/OFF 2 times. Switch off the printer by button ON/OFF.
Sep 28, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Zebra Printer TLP 2844-Z - Will not print from application - prints SM 10 53 4D
Hold the feed button while turning on the printer. After a config label prints, turn the printer off and then on again, and try printing again.
Also, make sure the lid is closed far enough to engage the lid sensor. If the red light comes on again, press down a bit on the lid, hit the feed button and try to print again.
Oct 23, 2008 | Zebra TLP 2844-Z Thermal Label Printer
make sure you have selected the correct media in the printer driver. The tracking mode has 3 options, (1) Web Sensing (Cut Labels), (2) Mark Sensing (Black marks on back of liner) and (3) Continuous . In your case select continuous. It sounds like the printer is in the wrong media mode and is feeding labels looking for a mark or gap and when it doesn't find one it flags a media error.
Aug 15, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Zebra MZ 320 Thermal Printer Logo
131 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
