Question about Digital Lifestyle FA1B32Z 32 in. LCD Television
My Digital Research TV will not power on - Digital Lifestyle FA1B32Z 32 in. LCD Television
Changed caps power light turns green but no picture or sound
Hi Garry
Hard to say but I suppose if you can change the caps surely you already know about their polarity ;) but I'd double check that and look for cold soldered joints.
Best of luck
XyFinx
Dec 14, 2013 | Televison & Video
At first the tv picture would shrink then get back larger. Now the power green light is on, but the screen is black.
I had the same problem. After doing some research here I went to www.tvrepairkits.com and I ordered this kit: (TV-KIT-001-9P6031C103) Philips Magnavox 9P6031C103 Shrinking & Expanding Video Or No Video Kit. It costs about $53.00 plus about $12.00 freight.
According to the research and discussions this should fix the problem.
Jul 03, 2011 | Philips Magnavox 9P6034C 60" Rear...
We bought a new LG 32LD460 tv this morning. It switched on fine and we had it running with good picture and all. Then we left it for a while and came back to try and set up the xbox. It switched on with...
It sounds like a powere supply problem. You will need to take the back off and test the voltages that are printed on the power pcb with a digital multimeter. Need to check the power button light, if it is on then you have the 5VDC standby power and the issue might be the main board. I will do further research on this problem.
Apr 03, 2011 | LG 32LD450 32 In. LCD HDTV
I have a Digital Research LCD tv and for some reason the power does not come on anymore. I was watching it one day then turned it off. A couple hours later I went to turn it back on and nothing happened....
Try tv unplug,replug it an hour later.The tv will now resetting back to factory setting.The tv should work now.Not,than the power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacenent.
Sep 08, 2010 | Televison & Video
I have a 32 inch digital research flat screen tv that will not power back on..what do you think the problem might be?
Power supply problem, that will be the first place to look.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Jun 28, 2010 | Televison & Video
I just purchased a LG LE5500 55" TV. When using my accoustic research wireless speakers it creates an echo effect. The Geek Squad said there was nothing I could do to prevent this echo. Is there a way of...
try different ways of sending the audio to the speakers. you can go digital out from the tv into your receiver or go directly from your cable/satellite box into your receiver. I use both...from the tv for netcast and from the box for all others. assuming you are going through a receiver
May 08, 2010 | Acoustic Research 900MHz Wireless Stereo...
The screen gets black in some minutes of working, the sound continues
My LG LCD HD TV was doing the same thing. I would turn it on and within about 10 minutes the screen would go black.
After much research and troubleshooting I ended up having to send it out for servicing.
Before you do that, try these steps
  1. Is your TV plugged in to a power strip, splitter, UPS or other power sharing device? If so, plug it directly in to a wall outlet. If the TV is getting low power it can cause issues
  2. Does your TV have other video sources plugged in to it? (Example, Digital Cable, DVD Player,XBox 360) If so, try a different source and see if the problem still happens. If the problem does away, it could be the source. If the problem still happens then its still a problem :-)
Hope this helps!
Aug 14, 2009 | Polaroid TLA-04011C 40 in. LCD TV
Cannot get new digital signal to my ilo tv
I've done a little research and I don.t see where you have a ATSC tuner that receives the over the air digital signal. You have a basic Analog tuner. The only way you can receive digital is by a HD cable box by having cable or going to Satellite.
Jun 14, 2009 | iLO 3200 32 in. LCD Television
Need installation manual for acoustic research headphones
I have lost the manual of my RCAmodelnumverWHP150 how can I find another one?
Feb 23, 2009 | Acoustic Research Audio Players &...
Digital Lifestyle FA1B32Z 32 in. LCD Television Logo
419 people viewed this question
Top Digital Lifestyle Televison & Video Experts
paul
paul
Are you a Digital Lifestyle Televison and Video Expert? Answer questions, earn points and help others
