Question about Canon DR2020U Flatbed Scanner
Release the lock switch. After releasing the lock switch, press the STOP button.
5 Suggested Answers
SOURCE: errow msg. "release lock switch and detatch the i/f cable" still will not scan.
There is a switch on the underside on the scanner. This is the lock switch. Flipping it should solve your problem.
Posted on Jun 22, 2009
old marine
  • 1973 Answers
SOURCE: It says to release the lock switch. Where is the
Look on the bottom of the unit for a sliding switch that shows an icon of an open padlock on one side, and a locked padlock on the other.
Posted on Feb 19, 2010
Testimonial: "Thank you!"
upbeatjunk
  • 231 Answers
SOURCE: Canon LiDE 110 gets error code "release the lock
Unfortunately if the scanner is unlocked and you have reinstalled the software with no luck, then the scanner is defective.
If your scanner is still under warranty you can get a free repair or replacement form Canon...your best bet would be to contact them via one of the methods listed here:
http://usa.canon.com/cusa/consumer/standard_display/contact_us_consumer
The LIDE scanners are nice, I understand your frustration.
I hope this helps! If this did help you, please give a thumbs up!
Thank you for choosing FixYa!
Posted on Jul 24, 2011
SOURCE: I just installed my new
mbrindle is great!!!! Many thanks - I was just about to take it back as I thought the scanner was defective. Would never have thought i had to do that. Thanks!!!
Posted on Dec 09, 2011
T & C 2001 REMOTE CONTROL PROGRAMMING
ATTENTION: You MUST HAVE one working remote to add one more to the system.
1. Press LOCK button 5 times at 2 second intervals to resynchronize remote.
2. Insert key into the ignition switch. Turn ignition to the RUN position (as far as you can
go without cranking engine). Wait for ignition chimes to stop.
3. Using the working remote, press and hold the UNLOCK button on the remote for 4 to 10
seconds.
4. Within the specified 4 to 10 seconds, continue pressing the UNLOCK button and then
press the PANIC button ( on the programmed remote ) for 1 second and release both
buttons. A chime will sound to indicate that the remote programming mode has been
entered ( allow 3 seconds for chime to sound ).
5. Within 30 seconds of the chime, press and release the LOCK and UNLOCK buttons
simultaneously then press and release just the UNLOCK button on the same remote.
A chime will sound indicating the remote has been programmed. Press and release
the LOCK and UNLOCK buttons simultaneously and then press the UNLOCK button on
each new remote you wish to program at this time. A chime will sound afer each
additional remote is programmed.
6. Turn the ignition OFF and remove key.
7. Test Remotes.
Sep 17, 2012 | 2001 Chrysler Town & Country
How do I program an additional remote for my 2003 Durango
  • You must have a programmed FOB to program another at home with my instructions below. If you don't have programmed one then you must get the first one programmed at the dealer.
  1. Press LOCK button 5 times at 2 second intervals to re-synchronize remote.
  3. Turn ignition to the run (no start.)
  4. Wait for ignition chimes to stop.
  5. Using the working remote, press and hold the UNLOCK button on the remote for 4 to 10
  6. seconds.
  7. Within the specified 4 to 10 seconds, continue to hold the UNLOCK button and then press the PANIC button ( on the programmed remote ) for 1 second and release both buttons. A chime will sound to indicate that the remote programming mode has been entered ( allow 3 seconds for chime to sound ).
  8. Within 30 seconds of the chime, press and release the LOCK and UNLOCK buttons simultaneously then press and release just the UNLOCK button on the same remote.
  9. A chime will sound indicating the remote has been programmed. Press and release the LOCK and UNLOCK buttons simultaneously and then press the UNLOCK button on each new remote you wish to program at this time. Locks will cycle after each additional remote is programmed.
  10. Turn the ignition OFF and remove key.
  11. Try your remote.
  • Hope this helps.
Oct 23, 2011 | 2003 Dodge Durango
P08 in LED indicators for CAnon pixma mp 258... how to solve please
To solve your problem follow the instruction step by step...
1. Turn Off printer, cable power still plug in.
2. Press Stop/Reset button, don't release the button.
3. Press Power button by holding without release and than release Stop/Reset Button.
4. Press Stop/Reset button two times (2x) now release the Power Button.
5. Wait until service mode to zero (0).
6. Turn off the Printer, cable power still plug in.
7. Press Stop/Reset button, don't release it.
8. Press Power button don't release & than release Stop/Release button.
9. Press Stop/Reset button four times (4x), wait until service mode to "1"
10. Turn off printer, and loose cable power, wait for one (1) minute.
Connect cable power, turn on printer again, now this printer ready to use
Aug 23, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
My alarm system went off due to wrong key ingnition...had to take a battery terminal off to stop the alarm, now I have the key and it wont start...is there a security reset?
Yes there is. 1. Press (LOCK) button 5 times at 2 second intervals to resynchronize transmitter. Attempt to function transmitter, if working as designed discontinue programming. 2. Turn ignition to run position. (Allow ignition chimes to stop).
3. Using any original (working) transmitter, press the [UNLOCK] button for 4 to 10 seconds.
4. Within the specified 4 to 10 seconds, continue pressing the [UNLOCK] button and press the [PANIC] button for 1 second and release both buttons (AN/DN release either button first). A chime will sound to indicate that the transmitter programming mode has been entered (allow 3 seconds for chime to sound).
5. Press [LOCK] and [UNLOCK] buttons simultaneously for 1 second and release (a short chime will sound for AN/DN).
6. Press and release any button on the same transmitter and a chime will sound after successfully programming the transmitter (locks will cycle for AN/DN).
Aug 15, 2011 | 2002 Jeep Liberty
Error 5200 or PO8?
11. Connect cable power, turn on printer again, now this printer ready to use.
Aug 12, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Printer shows alarm with p and 8 flashing
Follow this instruction step by step.
Aug 06, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
How do you re program a replacement remote for the APS997A
To program remote; ignition on, press and release programming switch 3 times, you will hear one chirp( channel 1),press the lock button, press and release the switch 1 time ( two chirps, channel 2), press the unlock button, press and release switch 1 time ( three chirps) press green remote start button,press and release switch 1 time ( 4 chirps) press option button. Turn ignition off.Test
May 27, 2011 | Car APS997A Two-Way Remote Start and...
My keyless remote for toyota highlander wont work, how can i reprogram it?
To reprogram remote:
turn ignition on
press and release programming/valet switch three times ( you will hear one chirp from system)
press and release lock button on remote ( system responds with confrimation chirp)
press and release valet switch one time ( two chirps from system)
press and release unlock button on remote (system responds with confirmation chirp)
press and release valet switch one time (three chirps from system)
press and release option button on remote (system responds with confirmation chirp)
turn igntion off
test remote
Oct 05, 2010 | APS20B Prestige Keyless Remote Alarm
5BCR07P PROGRAMMING INSTRUCTIONS
Ignition on, press and release programming switch three times,you will hear one chirp ( channel1), press lock button on remote, press and release switch 1 time ( two chirps, channel 2) press unlock button, press and release switch 1 time (3 chirps), press green remote start button, press and release switch 1 time ( 4 chirps),press option button. Turn ignition off, test.
After pressing the corresponding buttons on the remote programming sequence above ,you should hear confirming chirps from the alarm.
Sep 29, 2010 | 5BCR07P Remote Replacement Transmitter for...
I have a 5110 error
1. Switch off the printer.
2. Holding button STOP/RESET press the button ON/OFF. Do Not release the buttons.
3. Continuing hold the button ON/OFF release the button STOP/RESET. Do Not release ON/OFF.
4. Continuing hold the button ON/OFF press the button STOP/RESET 2 times and release all buttons.
5. When indicator COPY засветится GREEN - press the button STOP/RESET 4 times for unset памперса.
6. After striking 4 times buttons STOP/RESET press the button ON/OFF 2 times. Switch off the printer by button ON/OFF.
Sep 28, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Canon DR2020U Flatbed Scanner Logo
704 people viewed this question
old marine
old marine
