Question about U-Line Icemaker
U-line CLR 60 B ice maker
Water in recirculation tray. Can hear motor running when turned on but no water circulation and ice making grid warm. What's up
  • 286 Answers
It sounds like the compressor and fan is not running. What you might be hearing is the drain pump.Note that if the drain pump detected a slow drain this would shut down the unit for saftey. Check for kinks in the drain. Also check behind the back panel for drain line too.
Posted on Jun 06, 2009
U-Line's tech line is 1-800-2547. The compressor, condenser fan and circulation pump operating at the same time?
Posted on May 25, 2008
Managemylife com sears
check that the ice maker is not jammed with frozen ice
dont force the tines on the tray to turn . lightly geared clock.
can you hear the little clock motor running quietly wirrs
is the water running out the front ok
is the water frozen before the tray ,defroster issue then
hit it with a hair dryier for a few mins an see what it does when u close it .
Jul 25, 2014 | Samsung RSG307AARS - 30 cu. ft. Side by...
Ice maker runs continuosly but no water is in the cube tray
It could be the valve. If it does not let water in, it will try to make ice and none forms so the motor keeps turning waiting for ice to form.
If the motor is turning its fine. Concentrate on how the water reaches the tray, its probably not getting there.
Dec 22, 2013 | Whirlpool Refrigerators
The ice maker
see this causes and fix it. God bless you
Makes to much ice or won't shut off.
Check shutoff arm. This may be hung up on ice or food item.
Makes no ice.
Check shutoff arm. Check to make sure it is getting water, check water solenoid. Check water supply line it may be frozen or plugged up. Check freezer temperature to low of a temperature could cause the line to freeze up. Check for power at motor. You will need to remove the ice maker. Find the leads that go to the auger and connect a voltmeter. Press the dispenser lever you should have power if not replace the control board or micro switch. Check control switch or microswitch. Put icemaker in test mode. Only some are equipped.
Ice cubes to large or small.
Adjust size by removing cover and turn adjustment screw + or -. Check water solenoid. Check water supply line. Make sure it is level.
Ice tastes bad
Clean ice tray. Check supply line. Check water solenoid. Change filter. Run at least a 3 gallons of water thru the line after replacing filter this will flush all old water.
Ice is discolored.
Check water solenoid. Check supply line. Change filter. Clean ice tray. Run at least a 3 gallons of water thru the line after replacing filter this will flush all old water.
Most ice maker problems require either replacing the ice maker unit or the ice dispenser control board or micro switches.
Sep 28, 2012 | Washing Machines
Water leak on back wall of my freezer and a hell of noise from my icemaker when on
Water leak and noise are due to wrong temp setting or malfunction of defrost cycking.Keep temp setting between 3 and 5 degree centigrade. Due to over frosting, the freezer fan fan hits over the ice and working to cool fridge compartment.And also check defrost timer, and heaterworking properly to defrost in time. And if your ice maker is making sound, due to:
  • You will hear a buzzing sound when the water valve opens to fill the water reservoir for each cycle.
  • Rattling noises may come from the flow of the refrigerant or water line. Items stored on top of the ice maker can also make noises.
  • The high-efficiency compressor may make a pulsating or high-pitched sound.
  • Water running over the evaporator plate may make a splashing sound.
  • Water running from the evaporator plate to the water reservoir may make a splashing sound.
  • As each cycle ends, you may hear a gurgling sound due to the refrigerant flowing in your ice maker.
  • You may hear air being forced over the condenser by the condenser fan.
  • During the harvest cycle, you may hear a "thud" when the ice sheet slides from the evaporator onto the cutter grid.
  • When you first start the ice maker, you may hear water running continuously. The ice maker is programmed to run a rinse cycle before it begins to make ice.
Hope, it's helpful>
Feb 05, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Not making ice cubes
Fill ice maker with tap water and let freeze. If ice dumps and water does not refill tray then the water control valve is defective. If ice remains in ice maker then ice maker is the problem.
I think Amana still uses the Whirlpool made ice maker. It consits of a mold, a paddel to remove the ice, a motor to drive the paddel and a cam. The electrical part consists of mold, thermostate or sensor ( use to be thermo-disc), micro switches, 1 to hold the unit running 2nd to alow water to flow at a certain time and a mold heater. Sequence of operation: Thermostate senses mold is cold, activates motor to turn paddels and cam. As cam turns it depresses a micro switch to hold motor running. Motor cam and paddel turn, mold heater is also turned on. As mold warms the paddels scoup out the ice. Contunes to turn until a spot on the cam activates another micro switch to allow water in. Motor continues, as cam reaches a spot it releases the micro switch for water andthen the switch holding the motor on and unit shuts off ready to do it again.
Sep 09, 2010 | Amana ARB2257C Bottom Freezer Refrigerator
CLR 2060 Clear Ice Maker
just a guess but did you make sure that the fan under the unit is turning? if you don't get rid of the heat at the condensor the freeze tray can't get cold.
Aug 02, 2008 | U-Line Icemaker
NO POWER GETTING TO UNIT
realized that there was nothing wrong with the unit....It is suposed to drain out water when running and need to jump start it...so alls good thanks for getting back to us...now were chilling.E.Bates
Jul 07, 2008 | U-Line Icemaker
2003 whirlpool ice maker doesn't work
May be an issue with the cam that operates the ice maker. U can pick up a new ice maker for about 40 bucks on ebay.
Lots of things could be bogus. If the solenoid does not open, no water in tray - no ice. If tray does not get warm for fingers, fingers cannot push ice out - no ice. If freezer is not at least 10 degrees, no ice making at all. If cam motor for maker is bogus, anything could be out of whack.
Make sure that the ice maker is in "on" mode.
May 03, 2017 | Refrigerators
Samsung Ice Maker on Mdl RB215LASH
It is quite possible the water line near the ice-maker is frozen. I would try a warm hair drier to thaw it out.
Apr 21, 2008 | Samsung RB215LASH
U-Line Icemaker Logo
684 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
