Can we connect this type of printer to a Windows environment aside form AS/400? If connection to Windows is possible, can we print text file or pdf file?
  • 506 Answers
Most Printer can be connected to windows environment. You must ahve the Driver for the Windows OS version you are running. Check the Printer's Manufacture website for the latest driver.
Posted on Sep 29, 2010
WHEN TRAY EMPTY PRINTS OUT OF OTHER TRAY
The user cannot select a paper tray for a print job from within an application. It is also not possible to configure a default paper tray in the Document Defaults, Printing Preferences, Printing Defaults driver options.
This problem may be experienced with an HP PCL5e, PCL5c, or PCL6 LaserJet printer driver on any of the following Operating Systems:
  • Windows NT 4.0
  • Windows 2000
  • Windows XP/.NET
Typical symptoms of this issues include:
  • Paper tray selection grayed out.
  • Cannot select paper tray, only size and type.
  • Not possible to select tray.
SOLUTION: Perform the following steps to clear the NT Forms configuration.
  1. Go to the Printers folder by clicking Start , Settings , and Printers .
  2. Right-click the printer and go to Properties .
  3. Go to the NT Forms tab.
  4. Click the Clear All button.
  5. To save and exit, click the OK button.
SUMMARY: This is expected printer driver behavior. The NT Forms feature allows a user or system administrator to configure a so-called "form-to-tray assignment" for the printer. When this feature is enabled it is not possible to select a specific paper tray for a print job, or to set it as default, because the system is aware of the specific paper size and type loaded in the various printer trays, which makes the source selection redundant. Some applications or environments may require a "form-to-tray assignment" in order to take advantage of certain features. For instance, in an Active Directory environment, this feature has to be enabled for the operating system to be able to report the available paper sizes in the printer to the Active Directory
Nov 22, 2013 | HP LaserJet 5000 Printer
How do I share files from my computer to my iPhone for printing?
Printer able files have to be in documents format to be printed. The computer may be the only device connected to the printer. However, make an email address on the phone where documents could be emailed to the computer for printing to be achieved. Also, the iphone has a word typing area to gather document texts. Text messaging those documents to a computer that has printer connections would make possible printing.
Feb 02, 2011 | Computers & Internet
Page isnt prining out Have new ink in printer
Before you can troubleshoot the problem, determine its cause. Do the following steps in order:
1. Print another PDF, such as the first page of Acrobat Help.
  • If a separate PDF file prints correctly, the PDF that doesn't print correctly could be damaged. See "Can't print a specific PDF file" later in this document.
  • If the separate file doesn't print correctly, go to step 2.
2. Print another type of file (for example, a plain text file) from another application (such as Microsoft Word or WordPad).
  • If that other type of file prints correctly, the problem isn't system-wide--it's specific to the Adobe Reader or Acrobat product. However, the problem could come from Reader or Acrobat interacts with the system. Go to step 3 to eliminate some system-related causes of the problem.
  • If that other type of file doesn't print correctly, the problem is system-wide--it isn't specific to Acrobat or PDFs. The problem could be low system resources, insufficient memory on your printer, or a poor connection between your computer and the printer. Go to step 3 to eliminate some likely causes of the problem.
3. Restart your computer, and then print a PDF.
  • If the file prints correctly, your system may have been out of memory or resources.
  • If the file doesn't print correctly, go to step 4.
4. Turn off your printer for at least 15 seconds to flush its memory. Then turn it back on and print a PDF.
  • If the file prints correctly, the printer's memory was too full or had become corrupt.
  • If the file still doesn't print correctly, go to step 5.
5. Print from another computer.
  • If the file prints correctly from another computer, the computer you first used may be unable to connect to the printer or the network correctly. Consult your network documentation or contact your network administrator.
  • If the file still doesn't print correctly, go to step 6.
6. Print a PDF to another printer.
  • If the file prints correctly to a different printer, the computer you first used may be unable to connect to the original printer. Communication, hardware, or memory problems can cause this kind of connection problem. Make sure that the printer is turned on and connected properly. Then run a self-test on the printer to make sure that it's working correctly. Consult your printer documentation for self-test instructions or contact your network administrator.
  • If the file doesn't print correctly, see "Can't print any file from any application" later in this document.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Sep 01, 2010 | Lexmark Z611 InkJet Photo Printer
Unable to communicat to AS/400 system which is connected to ibm 3487 monitor
AS/400 printers can be tricky to connect to. Consider the following settings:
The following link has proved helpful to others connecting our ASCII Text only printer to an AS400 OutQ.
http://www-1.ibm.com/support/docview.wss?uid=nas1d6e996c964f3895286256aa10077ebdb
>an AS/400 LPR/LPD Network Output Queue:
>AS/400 OUTQ set up with the following parameters:
>Writers to autostart . . . . . . . . . : *NONE
>Remote system . . . . . . . . . . . : *INTNETADR
>Remote printer queue. . . . . . . . : text
>Connection type . . . . . . . . . . . : *IP
>Internet address . . . . . . . . . . . : 172.23.90.71 (example address)
>Destination type . . . . . . . . . . . : *OTHER
>Host print transform. . . . . . . . . : *YES
>Manufacturer type and model. . : *IBM4212 or 4214, 5256, 5225
>Print separator page. . . . . . . . : *NO
May 21, 2010 | Paxar Monarch 9830 Thermal Printer
Hello, the printer will not print out forms either from a adobe pdf file or from the internet; it leaves the page blank or just prints out the grids but no text.Please can you help?
Hi. Try turning off the image sharpening in the print settings.
For Windows, open the file and go to File > Print > Preferences/Properties in the Print window> Image Enhancement tab in the Lexmark 4500 Series Printing Preferences > choose None for Image Sharpening. Hit ok. Click Apply to save settings. Hit print to start printing. For Macintosh, open the file > go to File > Print > Print Settings > Advanced Settings > Image Sharpening > adjust setting to None. Try to print. Hope this helps. Good luck!
Mar 17, 2010 | Lexmark X4580 InkJet Printer
I bought refilled catridges for my printer and it printed the test page fine. But will not print any documents from my files.All my connections are good and it even printed test pages from my computer what...
most of these issue are caused by either corrupt printer driver or busy print spooler.
You can try these steps:
1.Check if the firewall is blocking any printer services 2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode 3.Disable all the firewalls 4.Uninstall the printer driver and software 5.Delete any items under the ff keys: HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2 HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3 HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2 HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3 Optional*** 6.Delete any non default items under the ff keys: Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED HKLM\System\CurrentControlSet\Control\Print\Monitors HKLM\System\CurrentControlSet001\Control\Print\Monitors Default items are as follows: AppleTalk Printing Devices BJ Language Monitor Local Port PJL Language Monitor Standard TCP/IP Port USB Monitor Windows NT FAx Monitor ***** 7.Delete any items under the ff keys: HKLM\System\CurrentControlSet\Control\Print\Printers HKLM\System\CurrentControlSet001\Control\Print\Printers 8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista) Ensure there are no documents in queue. Disconnect printer’s USB cable. Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility. From the start search box type spool and press . The spool folder located at c:\windows\system32\spool opens. Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup. Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup. 9.Restart the computer. 10.Check th services status Start-Run- Type Services.msc and Click on Open You will see long list of services You need to make sure following 4 Services are set to Automatically start Remote Procedure Call RPC Remote Procedure Call RPC Locater LexBce Server Print Spooler 11.Reinstall the latest printer driver
have a great day :)
Sep 30, 2009 | Dell 924 All-in-One InkJet Printer
Help me with Zebra TLP 2844
The printer only understands EPL code. (Eltron Programming Language) If you are trying to print text from DOS it wont understand (interpret) the txt codes.
To verify that the printer is working.
Open a DOS box, start the dos editor. Type Edit. Dos editor will open.
Type a single capital letter U. and print. Send to printer. The printer will print a configuration label.
EPL code to reset printer is
^default.
If you want to print a text file. use the Zebra Universal Driver. Zebra TLP2844. Open any windows application. E,G, Notepad. type text and send it to printer. Print as normal.
Jul 24, 2008 | Zebra LP 2844 Thermal Printer
HP photosmart C7180 all in one not printing properly.
As explained by you it seems to be an issue with the printer drivers.you can follow the following steps .
steps ...
1. Open a Command Prompt window
key the commands
net stop spooler
2. In the run (Start Search for Vista) type : c:/windows/system32/spool/drivers…look for w32x86 folder.
3. Inside w32x86, there will be folders with the names 2 and 3 .
delete all of the files and sub-folders in each of the 2 and 3 folders, but not the folders themselves.
4 Start > run > type > regedit .
Navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers
There might be two entries names Version-2 and Version-3 under drivers: click the plus sign against them and remove everything under them.
4. In the run (Start Search for Vista) type : c:/windows/system32/spool/printers: delete any files there.
5. Open a Command Prompt window
key the commands
1. sc config spooler depend= RPCSS
2. net start spooler
Then follow these >>>>
> browse the disc n go to folder util > ccc > there you wud find some uninstall files > run uninstall _L1.bat.
make sure the printer should be unplugged while you perform the steps .
> then insert the disc and click on add a device .
follow the instructions and connect the us cable when prompted .
Hope this helps .
Take care
May 19, 2008 | HP Photosmart C7180 All-In-One InkJet...
Printing problem on Windows 2003 Standard (with SP2 R3)
Hi, FRND,
Let me tell u one thing that the PDF driver not gives you print on the printer !!! PDF driver gives print on the file no on the printer ...
which printer u are using.....
if you are not using any printer just want to see the print preview... then use the IBM pro printer....
The drivers are in build....
Or the problem for handling the PDF print then remove it & you better know that the which version of the PDF u are using on Win 2003 Std ok..
Best Luck....
Feb 27, 2008 | Microsoft Windows Server Standard 2003 for...
Printing from Dos Prompt
1. Save your text file (.txt).
2. On the command prompt navigate to that directory
3.Type "Lpr -S 192.168.1.200 -P lp text.txt"
Substitute 192.168.1.200 for your copier's ip
Substitute text.txt to filename.
Or you can: to print from MS-DOS apps.
1. Share the printer on a networked windows computer. Make sure you make the name MS-DOS compatible.
2. At a DOS prompt, type the following command:
"net use lpt1: \\servername\printer_share/persistent:yes"
NOTE Servername=computer name
printer_share=printers share name
Sep 28, 2007 | Office Equipment & Supplies
24 people viewed this question
k24674
