Question about Philips Car Audio & Video
My philip car stereo is a coded type with SAFE on it dISplay anytime the key is inserted in the ignition of the car after learning how to find the right code i tried the first time and a second time now it has refuse to response it just displaying SAFE it is a Philip 588/71F car radio
  • Philips Master
  • 4,915 Answers
It is showing SAFE because wrong codes have been entered
To reset , leave SWITCHED ON..UNDISTURBED for as long as it takes to automatically reset itself
This could take several hours
Posted on Sep 29, 2010
Radio stuck in safe mode, holding the PSCAN and RBDS buttons doesn't display the "1000" where I am able to enter the code.
first off is it the original stereo that came factory if it is try this solution:
1:turn ignition on but do not start
2: turn on stereo
3: do not touch anything else
4: wait 5-10 with stereo on and ignition on 10 min to be sure
5: after 10 min turn of ignition only remove key exit vehicle
6: set alarm
7: wait 10 more min
8 disarm alarm
9:put key back in ignition and set to on do not run
10: stereo should now work
Nov 14, 2016 | Audi Cars & Trucks
04trailblazzer won't start driver2 comes up on display
Each key is learned. You must be using an extra key. No code is needed unless your backup key was not learned. Find driver 1 key and start the vehicle and then shut off the truck and within 5 seconds, insert the backup key and start the truck. Your backup key should now be learned.
Oct 12, 2014 | 2004 Chevrolet TrailBlazer
SAFE CODE ON VAUXHALL PHILLIPS RADIO CCRT 2008
I had issue where ccrt2008 was stuck on SAFE, after i disconnected battery. all searches to get it out of that state like AS + power or leaving it on for few hours did not help. Finally this morning I accidentally came to solution.... I inserted my key into ignition, not turning it.. the push it in more till i hear a high tone sound. the radio display then prompts for code. I then enter code using cellphone buttons then press the selector button to confirm...
Hope this helps someone having same issue.
Apr 11, 2012 | Philips Car Audio & Video
What is the code to unlock an Audi A4 stereo out of SAFE mode?
IMPORTANT NOTE: You must have the security anti-theft code for yours 1998 Audi radio from the car manufacturer!
The sequence of programming is:
1. Push simultaneous "SCAN" and "RDS" keys until on the screen will appear "1000" displayed.
2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt.
3. By the #1 key you will set up the first safe code digit.
4. By the #2 key you will set up the second safe code digit.
5. By the #3 key you will set up the third safe code digit.
6. By the #4 key you will set up the four-th safe code digit.
7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed. The radio is now ready for use!
Oct 01, 2010 | 1998 Audi A4
The stereo says SAFE and won't play music.
IMPORTANT NOTE: You must have the security anti-theft code for yours Audi Concert radio from the car manufacturer! For Audi Concert the sequence of programming is:
Aug 12, 2010 | 2000 Audi A6
My car stereo has gone to the SAFE mod and i tryed wrong cod now
Apr 08, 2010 | 2000 Audi A6
2003 Chrysler T&C Key programming
STANDARD PROCEDURE - TRANSPONDER PROGRAMMING USING A DRB III® SCAN TOOL All Sentry Keys included with the vehicle are pre-programmed to work with the Sentry Key Immobilizer System (SKIS) when it is shipped from the factory. The Sentry Key Immobilizer Module (SKIM) can be programmed to recognize up to a total of eight Sentry Keys. When programming a blank Sentry Key transponder, the key must first be cut to match the ignition lock cylinder of the vehicle for which it will be used. The vehicle's four digit PIN code will be required to complete this task since you will need it to enter the Secured Access Mode in the SKIM. The following steps must be completed using a DRB III® scan tool:
  1. Insert the blank key into the ignition and turn it to the RUN position.
  2. Using a DRB III® scan tool, select "Theft Alarm," "SKIM," "Miscellaneous," and then "Program New Key."
  3. Enter the four digit PIN code using the DRB III® scan tool. When programming is completed, the SKIM will exit Secured Access Mode and the DRB III® scan tool will display the results of your attempt to program the key. One of five distinct results may be displayed. All five are listed below:
    • "Programming Successful" is displayed if the Sentry Key programming is successful.
    • "Learned Key in Ignition" is displayed if the key in the ignition has already been programmed into that vehicle's SKIM.
    • "Eight Keys Already Learned (At The Maximum) Programming Not Done" is displayed if eight keys have already been programmed into the SKIM. In this case, if a new key needs to be added due to a lost or defective key, the "Erase All Keys" command (which requires entering the Secured Access Mode) has to be performed. Following the "Erase All Keys" command, all keys that will be used to operate the vehicle MUST be reprogrammed to the SKIM.
    • "Programming Not Attempted" is displayed after an "Erase All Keys" function is executed.
    • "Programming Key Failed" is displayed if further diagnosis is required.
To learn additional keys, turn the ignition OFF, remove the learned key, insert the next new blank key, and repeat the steps from the beginning.
“CUSTOMER LEARN” MODE This feature is only available on domestic vehicles or those which have a U.S. country code designator. This procedure requires access to at least two valid Sentry Keys. If two valid Sentry Keys are not available, Sentry Key programming will require the use of a DRB III® scan tool.
The steps required to program Sentry Keys with two valid Sentry Keys follows:
  1. Obtain the blank Sentry Key(s) that need to be programmed. Cut the keys to match the ignition lock cylinder mechanical key codes.
  2. Insert one of the two valid Sentry Keys into the ignition switch and turn the ignition switch to the ON position.
  3. After the ignition switch has been in the ON position for longer than three seconds, but no more than fifteen seconds, cycle the ignition switch back to the OFF position. Replace the first valid Sentry Key in the ignition lock cylinder with the second valid Sentry Key and turn the ignition switch back to the ON position. The second valid Sentry Key must be inserted within 15 seconds of removing the first valid Sentry key.
  4. About ten seconds after the completion of Step 3, the indicator light will start to flash and a single audible chime tone will sound to indicate that the system has entered the "Customer Learn" programming mode.
  5. Within sixty seconds of entering the "Customer Learn" programming mode, turn the ignition switch to the OFF position, replace the valid Sentry Key with a blank Sentry Key transponder, and turn the ignition switch back to the ON position.
  6. About ten seconds after the completion of Step 5, a single audible chime tone will sound and the indicator light will stop flashing and stay on solid for three seconds and then turn off to indicate that the blank Sentry Key has been successfully programmed. The SKIS will immediately exit the "Customer Learn" programming mode and the vehicle may be started using the newly programmed Sentry Key.
These steps must be completed in their entirety for each additional Sentry Key to be programmed. If any of the above steps are not completed in the given sequence, or within the allotted time, the SKIS will exit the "Customer Learn" programming mode and the programming will be unsuccessful. The SKIS will also automatically exit the "Customer Learn" programming mode if:
  • It sees a non-blank Sentry Key when it should see a blank.
  • If it has already programmed eight (8) valid Sentry Keys.
  • If the ignition switch is turned to the OFF position for more than about fifty (50) seconds.
NOTE: If you attempt to start the vehicle while in “Customer Learn” mode (LED flashing), the vehicle will behave as though an invalid key is being used (i.e. the engine will stall after two (2) seconds of running). No faults will be logged.
NOTE: Once a Sentry Key has been programmed to a particular vehicle, it cannot be used on any other vehicle.
Oct 15, 2009 | 2003 Chrysler Town & Country
Have a philips car 400 stereo and I have the code but do not know how to enter it could you help
CAR 400 Code Entry
Press and hold the [ AS ] key and switch on.
'SAFE' will display followed by '10 - - - - '
Press preset [ 1 ] repeatedly for the first digit
Press preset [ 2 ] repeatedly for the second digit
Press preset [ 3 ] repeatedly for the third digit
Press preset [ 4 ] repeatedly for the third digit
To save the code press the [ AS ] key to accept
Oct 02, 2009 | Philips Car Audio & Video
2 before SAFE on stereo in 2001 Cabrio and won't let me enter code. I have the code.
the radio is locked out.you need to leave ignition on with radio on until it displays code.For how long ??? it can be several hours so if you can lock it on your drive with spare key with other key still in ignition and leave it.hope you get sorted
May 13, 2009 | 2001 Volkswagen Golf
Car audio 'safe'
'SAFE' Is displayed because the radio is protected by a 'CODE'
The more wrong codes you enter the longer the word 'SAFE' will remain on the display... Look through all your paper work & try to find the 4 digit 'CODE'... eg: 2456 this can then be entered by pressing the 12456 preset buttons.
Failing that you will have to go to a audi dealer they will be able to get it from a database or buy a aftermarket stereo.
Dec 19, 2007 | Rockford Fosgate 25 To LIFE Punch 150...
Car Audio & Video Logo
495 people viewed this question
Top Philips Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Philips Car Audio and Video Expert? Answer questions, earn points and help others
