Question about Dryers
How does one go about replacing the belt on a td 260 zanussi tumble dryer
    President:
  • 3,074 Answers
You will need to remove the front panel:
1) unplug dryer
2) open door remove screws
3) with a flat tip screw driver pry gently up on the top corners it will pop
4) move front panel forward and disconnect door switch
5) sit panel aside
6) lift top lid of dryer 90 degrees it has clip/hinged on back
7) note the routing of old belt
8) replace belt
These are general directions you may have to actual remove more screws, I am not there looking at the dryer, but on all the dryers I have worked on this is how I went about repairing them. Hope this helps Tim
Posted on Sep 29, 2010
I keep asking but dont get answers help please
There is a video here on how to replace a belt on a dryer. I have done this before and most dryers are the same. You have to take them apart. It is not a real easy job. Hope this helps. Scroll down to the bottom of page to see video.
http://www.espares.co.uk/part/tumble-dryers/zanussi/td4112w/p/1088/332/0/553236/501196/tumble-dryer-drive-belt.html
Dec 02, 2011 | Zanussi TD4112W Electric Dryer
Zanussi Tumble Dryer TCE 7276W error code E50 - what shall I do? I put washing in TD and set it A and turned it on, it came up 2.05 as it always does but after some time, I come across "End" is...
Hello this is Dennis from blue hawk electronics I had the same problem with my Zanussi tumble dryer and all I did was to take out he front circuit board and reflow board and has been working fine now for 9 months and still going strong
Sep 03, 2011 | Dryers
How do i change drive belt on zanussi tumble dryer model number td 4112w
take back cover off ... place new belt bottom first then roll it round tub... WATCH YOUR FINGERS.....if no cover on rear undo two screws on lid (rear).....do as stated above but its harder.07779933829 uk
Feb 23, 2011 | Zanussi TD4100W Electric Dryer
My 20 year old Zanussi dryer model TD 260 has stopped rotating, but the heat is on. Does this mean the belt has gone and where do I get an engineer to fix this.
More than likely is belt, remove the top cover, and you should see if it is the belt.
If you are in the u/k, then go to---
WWW.SERVICEFORCE.CO.UK
You should be able to arrange for an engineer to visit, or look in yellow pages for local repair company.
Jan 26, 2011 | Zanussi Dryers
Tumble dryer TD 4112 W has power but drum does not turn - light is on and it makes humming noise but won't start.
hello the first thing to check is. the long pin on the inside of the door these sometimes snap off . if ok then check to see if the belt has come or snaped if ok then you may need to check the capacitor this next to the motor will have 2 wires coming off it these dry up good luck
regards
shaun
Jan 17, 2010 | Zanussi TD4112W Electric Dryer
How do i replace a drum belt to tumble dryer Zanussi TD 4212W
remove lid then take screws out from inside front cover/lid and slide drum out
Jan 13, 2010 | Electrolux Dryers
Zanussi Tumble Dryer - TD 4112 -Door Catch Assembly/Repair The plastic catch broke and I have bought a replacement however I can't work out how to put the pin, spring and catch back together. Any help...
Jason, I have the same problem... the catch on my Zanussi dryer has broken. I've ordered a spare part... and remembered how I took the thing apart.
I'd have to show you... it can't be put into words. LOL
Hopefully by now you've figured it out. (Just seen the date you posted this).
~ Franka ~
Aug 31, 2009 | Zanussi TD4112W Electric Dryer
The drum on the tumble dryer isnot moving, why is this?
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 18, 2009 | Zanussi TC180W Electric Portable Dryer
take it apart and you will see that the belt is probably find the belt broke
Nov 05, 2007 | Kenmore 64902 Electric Dryer
Dryers Logo
157 people viewed this question
Top Dryers Experts
