Question about HP Photosmart C6180 All-In-One InkJet Printer
Hp c6180 fax not working. Message: Unable to send or receive faxes, press Os to continue Despite the all possible settings and driver updates, the fax has never worked. How can I fix this?
  • HP Master
  • 1,679 Answers
Follow the steps one by one
1. Press the Setup button - Press OK
2. Scroll to Tools - Press OK
3. Press OK on Run Fax Test
4. It will list you possible causes why you are not able to send/receive fax
If you cannot solve the issue with the Fax Report, you can do a semi-full reset on printer
( do not do the semifull reset on printer if connected to wireless, If you do so, the printer will loose wireless connectivity to router and you will have to setup the printer on router again )
Disconnect the power cord from back of printer ( when printer is powered on )
Hold the # and 6 button and while holding connect the cord back
This reset will Erase fax logs, wireless connectivity any other memory stored in printer
Follow the instructions on printer screen to re-align the printer and cartridges
Try to send/receive fax and it should work.
* Please rate this solution with Thumbs up and comment to help us improvise in providing better support
Posted on Sep 29, 2010
I can't get my HP potosmart C6180 ALL IN ONE PRINTER TO SCAN/COPY OR FAX WITHOUT GETTING A SCANNER FAILURE MESSAGE SAYING UNABLE TO SCAN,COPY OR SEND A FAX
Solved! I now can scan wirelessly throughout my network. I downloaded the drivers for a friends newer HP all-in-one scanner and I can scan. Look for the driver for the 309a series of printers and install it. Complete the install and set up your existing printer. You can now scan, print, fax wirelessly. It includes updated HP apps for these functions that work with OS 10.5. I didn't upgrade to the HP 1.1 drivers through Apple. The file name is: PS_AIO_05_C309a_Net_Full_Mac_WW_102.dmg
May 24, 2011 | HP Photosmart C6180 All-In-One InkJet...
Try uninstalling and reinstalling the drivers for this printer, you can get them from the HP website
Let me know how this goes and whether you need any help doing this or if you have any questions
If this doesn't work then I have a few other ideas for what it wrong.
You could also try a system restore if the drivers don't work
Jun 04, 2008 | HP Photosmart C6180 All-In-One InkJet...
Hello, I have an HP Photosmart C6180 All-in-One Printer, Fax, Scanner and Copier. It seems that as soon as I turn it on a message comes up: "Fax Failure" Unable to Send or Receive Faxes" This message has...
try ti perform steps as ---->Disconnect the power cable from the back of the printer and then press the power on button for 3- seconds and then at the same time connect the power cable at the back of the printer and then try to turn on the printer and then try to make copy from the printer
Aug 19, 2010 | HP Photosmart C6180 All-In-One InkJet...
Unable to scan, copy or fax message on HP C6180
Please follow the steps and then let me know the results:Click Here
May 23, 2010 | HP Photosmart C6180 All-In-One InkJet...
C6180 FAX UNABLE TO SEND OR RECEIVE
check the the phone line, The fax sinal need good clear. Surely,plug the phone-line is rigth line socket. If you do that all, the broblem is still happenning,need to change "relay" on moderm fax board.
Jul 27, 2009 | HP Photosmart C6180 All-In-One InkJet...
I have two problems with my OfficeJet 6310: 1. The fax screens appear Hebrew. Similary, If I try to use the copier from the printer. This is continuously caused by HP Update 2. I can not send out a...
Use the HP Fax Test
The telephone number for this service is 1-888-HPFaxme (1-888-473-2963). The fax service receives faxes and returns faxes within 5 to 7 minutes to the number contained in the fax header. Solution two: Run a fax diagnostic test
  1. Load plain white paper into the input tray.
  2. Press the Setup button (c01669474.gif ) on the product control panel.
  3. Press the right arrow (c01669475.gif ) to select Tools , and then press OK .
  4. On the Tools menu, press the right arrow (c01669475.gif ) to select Run Fax Test , and then press OK . The fax diagnostic test prints.
Solution three: Check the telephone line and change the HP fax settings Step one: Test the telephone line
  1. Disconnect the telephone cord from the back of the HP fax product.
  2. Figure 1: Two-wire telephone cord c01501963.gif
  3. Pick up the handset of the telephone and check for a dial tone.
  4. On the single-line telephone, dial the fax number of the receiving fax machine.
    • If the receiving fax machine answers the call, continue with the next step.
  5. Hang up the single-line telephone.
  6. Use a second telephone line or a cellular telephone to call the telephone number assigned to the HP fax product.
Step two: Change the HP fax settings
  1. Connect phone line into line 1
  3. Press the right arrow (c01669475.gif ) to select Basic Fax Setup or Advanced Fax Setup , and then press the right arrow (c01669475.gif ) again to change the menu option settings to the settings listed in the following table. Fax menu Fax menu option Setting Basic Fax Setup Rings to Answer 1 or 2 (At least one more ring than a telephone answering machine, if an answering machine is connected.) Advanced Fax Setup Answer Ring Pattern All Rings
  4. Use the HP Fax Test Service to try to send and receive a fax.
If the HP fax product still cannot send or receive a fax, continue to the next solution. Solution four: Check VoIP digital telephone line Using a VoIP telephone service can cause faxing to fail because fax transmissions are sensitive to the timing of the signals used to transmit the fax. If using a VoIP digital line is necessary, changing the Fax Speed Adjustment setting to Medium might improve the ability to send a fax over a VoIP telephone line. Use these steps to change the fax speed adjustment to a lower speed.
  1. Press the Setup button (c01669474.gif ) on the product control panel.
  2. Press the right arrow (c01669475.gif ) to select Advanced Fax Setup , and then press OK .
  3. Press the right arrow (c01669475.gif ) to select Fax Speed , and then press OK .
  4. Press the right arrow (c01669475.gif ) to select Medium , and then press OK .
  5. Use the HP Fax Test Service to try to send and receive a fax
Jul 05, 2009 | Computers & Internet
Cannot send or receive faxes
Use the HP Fax Test
  5. Use the HP Fax Test Service to try to send and receive a fax.
Jun 23, 2009 | HP Officejet 5610 All-In-One InkJet...
When I try to send a fax the machine gives a message cannot receive or send fax. I am getting a dial tone through port 2 still. If bad modem can they be changed in this model?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi,
In order to find the solution to this issue, you need the fax number for another fax machine that is operating correctly with which to send and receive faxes. After trying each of the following solutions, try to send or receive a fax from this other fax machine to test if the issue has been resolved with your HP fax product. The other fax can be in the same building, on another telephone line, or at another location with someone who can assist. It can also be helpful to call the person or company that is sending the fax. That party can offer information about how that fax machine behaves when sending a fax. This information can be valuable in determining the nature of the issue.
There are several possible solutions to this issue. Start with the first solution and then continue with the other solutions in the order presented until the issue is resolved. When the issue is resolved, there is no need to continue troubleshooting.
Solution one: Run a fax diagnostic test
Run a fax diagnostic test to make sure that the HP fax product is set up correctly.
Load letter or A4 unused plain white paper into the input tray.
on the product control panel, press the setup button ( ).
Use the down arrow key ( ) to select Tools and then press the OK button ( ).
on the Tools menu, use the down arrow key ( ) to select Run Fax Test and then press the OK button ( ).
Review the results of the test.
If the result of the fax diagnostic test is All Pass ,
Reinitialize the fax
1. With the HP fax product turned on, disconnect the power cord from the back of the HP fax product and from the electrical outlet.
2. Connect one end of the telephone cord to the telephone jack and then connect the other end of the cord to the port labeled 1-Line on the back of the HP fax product.
3. Reconnect the power cord to the back of the HP fax product and then reconnect the power cord to the electrical outlet.
4. After the HP fax product reaches a ready state, try to send and receive a fax again.
If this works GREAT!, if not let me know....JCE
Apr 17, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
360 people viewed this question
Seeker5211
Seeker5211
