Question about Saeco Magic Cappuccino Espresso&Cappuccino Machine
Via veneto won't make coffee
I have a saeco veneto that will drip water out for the coffee. I changed the pump but still the same. What needs to be replaced so I can get my machine to work properly.
I removed the top filter where the water comes out and cleaned it good with a pin for all the holes, then I did the same for the coffee filter. I found alot of the holes plugged which would avoid the from alowing the coffee to come out.
Now it works like new.
Posted on May 29, 2008
Where is the cutt off security switch located on Espresso Machine Saeco Via Veneto Deluxe?
Have a close look around the outside of the cabinet for a small button or hole. Inside the hole, there may be a button that can be pressed to reset. Not sure about Saeco but I doubt if you have to take the cabinet off to get to a reset button.
Apr 26, 2017 | Saeco Coffee Makers & Espresso Machines
I hear pump sound, but coffee doesn't come. please help
Check the shower screen remove the filter handle the press brew button if water flows then the grind/tamp is the problem if no water then remove shower and clean.
Oct 06, 2009 | Saeco VIA Veneto Espresso & Coffee Maker
The steamer on our Espresso machine is not working
Try using a paperclip or needle to clear out the holes on the end of the steam wand. That will usually work if when you turn on the wand it is hot to the touch and you can still get hot water from the coffee spout.
Jul 26, 2009 | Saeco VIA Veneto Espresso & Coffee Maker
Via Veneto will not prime
Yes, unfortunately the Via Veneto is a difficult machine to prime, however, I have a simple way to prime the pump if you run into this problem. Simply remove the water tank, fill a clean turkey baster with water, open the steam valve fully then mate the baster tip with the water tank flow valve on the espresso machine. Wrap a towel or paper towel around the flow valve/baster tip then inject the water (agressively, but not forcefully). It's works for me every time.
Sep 18, 2008 | Saeco VIA Veneto Espresso & Coffee Maker
I think your machine is overheated, try to replace the thermostat on the boiler.
May 25, 2007 | Saeco VIA Veneto Espresso & Coffee Maker
Soggy Pucks & Portafilter retains water Saeco Via Veneto
It sounds like you are short on water due to a blockage somewhere...either in the flowmeter or the group head. You might also have a faulty pump, and you're not getting enough pressure during the shot. If you're not getting crema, then it's most likely pressure related...shots will also have a burnt smell and very bitter taste.
Mar 14, 2017 | Saeco VIA Veneto Espresso & Coffee Maker
Saeco Magic Cappuccino Espresso&Cappuccino Machine Logo
244 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
