Question about Evenflo Aura Elite Travel System
The wheels on the rear of the stroller bow in??? i got it about 2 years, and barely used until now and this happens??? elite stroller
    Scholar:
  • 53 Answers
Sounds like it somehow got overloaded. Did anyone step on them? Single strollers are typically tested to hold up to 100 pounds, which is well above the weight of a child and their gear. Regardless of what happened, contact Evenflo directy and see if they will replace the rear axle and wheels. You can't by replacment wheels at any store.
Posted on Sep 29, 2010
Instructions on how to fold
Kindly follow the steps to below to fold the stroller:
  • Use the ball of your foot to push down on the brake lever, located near the rear wheels of the stroller. Gently push on the stroller to confirm that the brakes are set. Grip the front edge of the stroller's canopy, if present; pull the canopy back towards the rear of the stroller.
  • Push the tabs securing the ends of the harness straps to the harness buckle. Pull the straps aside and remove the child from the stroller.
  • Kneel down next to the stroller's front wheels. Locate the locking mechanism set in between both pairs of front wheels. Use the locking mechanism to disable the swivel feature on the front wheels.
  • Pull the stroller's seat back down to the lowest position; some models may feature locking mechanisms located on the sides of the stroller or built into the handlebar. Lift any latches securing the sides of the stroller in place.
  • Push the handles of the stroller downward. Push the rear section towards the front of the stroller until the device is fully folded. Clip the storage latch located on the side of the stroller to the side of the handlebar.
Apr 24, 2016 | Baby Gear
How can I fold?
Kindly follow the steps below on how to fold the stroller:
Apr 16, 2016 | Baby Gear
How do I let the stroller down?
    Kindly follow the steps below to fold the stroller:
Sep 09, 2014 | Evenflo Aura Traditions Travel System...
How to fold mia moda 3 wheeler
Step 1
Inspect the stroller's wheels and handle to identify the type of brake mechanism it has. If the device is equipped with wheel-mounted brake levers and swivel locks, use the toe of your shoe to activate these mechanisms. If your stroller is equipped with a handle-mounted brake lever, push down on the lever to engage the brakes. Some models also come equipped with a secondary-locking mechanism located on one of the rear crossbars; use the toe of your shoe to activate this feature.
Step 2
Lift the handle or press the tab securing the backrest in place, located on the upper edge of the backrest or on the crossbars securing the rear of the backrest to the frame. Grip the edges of the footrest, then lower the component by pushing it into the desired position. Pull back the stroller's canopy.
Step 3
Grip the stroller's handle and lift the device upward; if the stroller comes equipped with a safety button, press the button as you lift. Use the toe of your shoe to push on the stroller's hinges until the frame begins to fold.
Step 4
Pull the halves of the stroller's frame together until you have completely folded the device; if the stroller comes equipped with a locking latch, engage the latch to keep the halves from sliding apart.
Audi Parts
May 23, 2012 | MIA MODA Atmosferra Travel System Stroller
On my bugaboo bee 2009 model the rear wheel makes a grinding noise gets worse if on a pavement that is slightly bummpy can anyone help please?
There has been a lot of complaints about the Bee's wheels on the internet including Bugaboo's own Face Book page! Your Bugaboo is ether in or only just out of the 2 year Warranty so contact Bugaboo customer service about getting a replacement set. The rear wheels are held by Hex nuts and are easy to remove with a small hex key any hardware shop can sell you. I use Silicon grease (as used to lubricate taps) when I repair stroller wheels. I think the Bee is a neat little Stroller and my wife has one but it really is only a Shopping Mall Stroller and those little wheels won't tolerate to much rough suburban footpaths.
May 26, 2011 | Bugaboo Bee Stroller
Where is the serial number and the manufacters date on the stroller
It is engraved on the frame, on the right rear, above the right rear wheel. (City Elite Single )
It is engraved in the frame, on the right side of the stroller, on the lower side of the right folding handle, under the logo. (City Elite Double )
Dec 03, 2010 | Baby Jogger Onyx 2010 City Select Stroller
Need rear wheel for my chicco litewat stroller
Hi, With he Chicco strollers there are at least 2 mechanisms for the rear wheels. You need to check which versions you have. 1) you will find a metal ball press stud on either side Of the chassis. Take a screw driver and push that metal ball in as far as you can to clear the housing for the wheel. Then pull the wheel away from the chassis. 2) Repeat for the other side 3) if both rear wheels come away WITH two a v shaped hinged metal rod then you can simply replace the rear wheels. I have seen them on eBay. 4) if yours pulls away and the hinged bracket has a material strap to it then these are not meant to be removed or at least I would not necessarily recommend that but of course the choice is still yours. You may need to purchase a replacement chassis again can be purchased on eBay. Hope this helps. Liz.
Jul 29, 2010 | Chicco Liteway Stroller by
I need to find two rear wheels for an Evenflo stroller model number 4781277
necesito las dos ruedas traseras con la barra larga que las engrana la barra original esta doblada y las ruedas se meten hacia dentro y no pueden rodar bien.
May 15, 2010 | Evenflo Journey Elite Travel System - 3...
Stroller pulls to the right.
The following is from the instruction manual for the Expedition LX. It should be very similar to the Expedition LE.
"Stroller pulls to one side:1. The stroller is sensitive to the air pressure in the tires. If the rear tires do not have equal pressure, the stroller will feel like it is pulling to the side with the tire with the lower tire pressure. Check that the rear tires have the same pressure. Add air pressure to a maximum of 25 pounds using a bicycle style hand air pump.2. The alignment of the front wheel of the stroller can also cause the stroller to pull to one side. The stroller is designed so that the front wheel can be adjusted to correct for any alignment problem. Page 3 of the instructions
shows an expanded view of the front fork assembly. To align the front wheel, first loosen the wheel via the quick release handle as in step 2 of the instructions. Grab the front wheel directly in front of the stroller and push the wheel in the opposite direction of the pulling problem. You will notice that the axle will move within the slot on the fork. Move the wheel to the side a small amount. Retighten the quick release handle. Give the empty stroller a push across an empty smooth surface (let go of the handle) and note if the stroller now runs straight. Re-adjust the axle a small amount at a time until the stroller runs straight. Please note that a very minute
movement of the axle will affect the tracking of the stroller. Once you have aligned the front wheel, you can mark the holding plate position with a marking pen if you detach the front wheel on a regular basis. Please note that the hole in the fork is designed to allow the stroller to be adjusted to pull to the right, go straight, or pull to the left. If you continue to have difficulty with tracking, please call our customer service department at (800) 328-7363 for assistance."
Mar 30, 2007 | Baby Trend Expedition LE Jogger
Evenflo Aura Elite Travel System Logo
124 people viewed this question
Top Evenflo Baby Gear Experts
Joyce Nokleby
Colin Stickland
Colin Stickland
Vic Fkiaras
Level 1 Expert
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
