Question about JVC AM FM CD DET FACE CAR STEREO
So I turned on my car as usual wen to put my ipod in and the player wasn't working! The only thing I could get it to do was to press eject and it would turn on eject the cd the turn off. It's only about 2-3 months old all wires are good and bonded. I'm clueless on what happened. It is in no way damaged.
If you have have a removable facia... this could be the solution
It is likely that the terminals on the back of the removable facia and on the unit need cleaning with a "contact cleaner". I suffered similar problems, all gold plated contacts looked clean, but i gave them a spray over with contact cleaner anyway and it worked.
Posted on Sep 29, 2010
My ipod has froze on connected eject before disconnecting
this is easy
press and hold center, and menu button - this resets the ipod firmware (holding play to turn the iPod "off" only puts it to sleep)
Jul 26, 2009 | Apple iPod nano
Just got my ipod g3 phone and no instructions on how to insert my
Here is how you do it: First, insert the end of the eject tool (or a paper clip if you do not have an eject tool) into the ejection hole of the sims tray. Then, press firmly and push it straight in until the tray pops out. Then, pull out the tray and put the sims card in the tray the right way (the angle on it comfirms that it can only go in one way which is the correct way.) Then, align the tray straight with the tray's slot and push it back in and it should work.
Mar 30, 2009 | Apple iPod MA446LL/A MP3 Player
Hi. I plugged in my iPod nano 4th generation to charge it. It opened iTunes as it usually does and I could see my iPod in my device list. I left it to charge as normal. I came back a while later and my...
Try doing this: Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen. Then it should work like normal. Hope this helps!
Mar 22, 2009 | Apple iPod nano
My i-pod nano chromatic 8 GB is stuck!:S
Press and hold the Menu and Centre buttons at the same time until the apple logo appears. (This usually takes between 5 and 10 seconds.)
Information from: http://ipodsurgery.com/reset-frozen-ipod
Feb 01, 2009 | Apple iPod nano MP3 Player
How do ya work this thing?
Press the SOURCE button "Bottom left of Row"
Aug 30, 2008 | Sony CDX-R3300 CD Player
Frozen 4G IPod
try pressing and holding the center and menu buttons both at once until the apple logo shows up.. thats the normal troubleshooting routine.
Jul 09, 2008 | Apple iPod nano
Ipod doesn't work when not connected to computer
After you eject if from the computer and it locks up press and hold the center button while pressing down on the menu button. This will reboot the IPod. What charger are you using? Is the charger plugged into a usb hub or does it get power from an electrical outlet?
Jun 25, 2008 | Apple iPod nano
I plugged my IPOD NANO IN TO THE COMP AND ALL **** SET LOOSE, THE IPOD ASKED FOR A RESTORE, WHICH I CARRIED OUT, I THEN EJECT AND ALLS FINE, THEN I RE ATTACH IPOD AND START INSTALLING 1 OR 2 ALBUMS TO...
Try resetting the iPod, this usually works.
As follows:
How to reset iPod To reset an iPod with a Click Wheel, including:iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation)iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation)
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds.
You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector)Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Mar 10, 2008 | Apple iPod nano
I cant delete songs on my ipod
Hey, watch this tutorial and try the things it suggest.
Id highly recommend, restarting, and returning the device into the original state.
All this is covered in the video here:
http://www.apple.com/support/ipod/tutorials/troubleshooting.html
Mar 09, 2008 | Apple iPod MA446LL/A MP3 Player
JVC AM FM CD DET FACE CAR STEREO Logo
27 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
