Question about Gestetner C7526dn Laser Printer
Un message d'erreur s'affiche sc 541 appeler sav alim on off GESTETNER P 7535N
Cogz
  • 1326 Answers
SOURCE: Error SC 541
Try this... Press the Yellow reset botton then the number "1" then "0" then "8", don't hold them down, just push each botton once. Then hold down the "Stop/Clear" botton till the display changes to service mode, then turn the main Power Switch OFF then back On and see if it warm up.... If it dose not warm up you may have a problem with the fixing unit.... Good Luck
Posted on Sep 20, 2008
SOURCE: Gestetner DSm615 giving error SC:552,How do i clear it
Are you sure of the code? I don't have the exact manual for that, machine but the number seems strange. "5xx" errors are usually related to the fuser, so could be a bad lamp, thermistor, or fuse. see note to reset (if there is not a problem) as follows:
There are 2 levels of service call conditions.
Level Definition Reset Procedure
"A"
To prevent the machine from being
damaged, the SC can only be reset by a
service representative.
The copier cannot be operated at all.
Enter SP 5-810 (SC code reset) and
select “1”. Then hold down the Original
type key and the OK or ! key at the
same time (this does not require the
main switch to be turned off and on).
Posted on Feb 16, 2009
  • 525 Answers
SOURCE: Je possède un copieur Ricoh
SC 546: Unstable fusing temperature
Symptom: The fusing temperature does not rise
3 °C or more within 5 seconds after the
fusing lamp has been on over 8
seconds.
Possible Cause: • Thermistor defective
• Power supply unit defective
Posted on Feb 05, 2011
mariolands
  • 2296 Answers
SOURCE: MON IMPRIMANTE LEXMARK T640N AFFICHE UN CODE D
Service Fuser Error appears when the fuser does not warm to the required temperature. For this error on this Lexmark model T640n, the manual states you should power off the printer and power it back on, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
If the printer is out of warranty, your next option is to change the fuser which costs around $350, so I think you would be better off getting a new printer unless you find a second hand one on Ebay.
Posted on Feb 18, 2011
santosj27
  • 263 Answers
SOURCE: My Gestetner 4532 is not printing a code SC
That is a bad reading temperature of the Fuser Unit.
I will give same steps to unlock it.
Press yellow key
On the key pad press 1-0-7
Old the red key at least 3 sec
Press copy sp
Exit all the way out
Turn the machine Off / On.
This should be good. If doesn't work you have to call a technician to change some parts of the Fuser Unit like Hot Roller and thermistors.
Hope you understand.
Posted on Mar 02, 2011
Contacter le sav erreur sc 172
Il s'agit d'une erreur avec le scanner :
Scanner DA3 Abnormal/Video Processing
Error 3
Il faut probablement un technicien pour ca.
Apr 06, 2014 | Ricoh Aficio Office Equipment & Supplies
Errore code sc 541
kindly call for a change of themostat
Feb 02, 2013 | Gestetner DSc338 Copier
Errore code sc 541
Your problem is in the fusing unit.Check the thermistors and thermofuses.Reset the code :
Interrupt(yellow)key - 1 0 7 -press and hold STOP/CLEAR key more 4 seconds,enter in SP mode,open the front cover,turn OFF the main switch,wait 1 minutes,close the front cover,turn ON the copier.
Lorsque je demarre ma camera il affiche un message erreur lens
Sacrebleu!
C'est parce que le
m?canisme d?licat est endommag? et l'objectif pouvez pas d?placer ou lock en position correcte.
Jun 30, 2011 | HP Photosmart M425 Digital Camera
Lorsque j'essaye d'installer le driver de mon webcam sur aspire 5742 un message s'affiche unreconized camera et lorsque j'essaye d'ouvrir acer crystal webcam il y a un message...
salut !
je pense que le pilote ne fonctionne pas correctement
voila un site qui vous permet d'analyser votre ordinateur puis d'afficher automatiquement les diff?rents drivers compatibles.
juste lance la d?tection et suivi les instruction
http://www.touslesdrivers.com/index.php?v_page=29
merci de choisir fixya
May 22, 2011 | Acer Aspire 5742Z-4200 Notebook
Je possède un copieur Ricoh 1022 .il est en panne . il affiche SG 546 . Aussitôt j?affiche 107 en appuyant sur le bouton jaune pendant un moment .l?appareil se mit en marche pendant quelques...
seconds.
Oct 20, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
Gestetner C7526dn Laser Printer Logo
117 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
