Question about Kenwood KDC-MP335 CD Player
Chimes in my car
I have a 2000 chevy cavalier, and the chimes in my car wont work. when i leave my lights on or if i leave my keys in my car the chime wont go off. what do i have to buy to make it work?
  • Anonymous Jun 02, 2008
    Chimes in my chevy cavalier stop working.
    Problem Solver:
  • 9 Answers
Because you didn't but the right wiring harness if a wiring harness at all, the chimes got cut
Posted on Aug 26, 2010
My sister has a 2000 chevy cavalier b4 the door chime and the interior dome light worked now they both dont, we replaced the bulb and fuse to no avail and I have no clue what's wrong with the chime.
the chime actually is done with the radio. the front drivers door speaker. so if the radio works and the front left speaker works. then more then likely you have a defective door switch. located in the door jam that controls the dome light
Apr 20, 2015 | 2000 Chevrolet Cavalier
2000 chevy 2500 (new style) parking lights wont shut off
The parking lights staying on and the left turn signal not working may not be related, the turn signal is probably a burned out bulb, turn on the left signal and see if all the bulbs light up if not replace the burnt one, if they all light, the turn signal flasher may be at fault ( it can work with one side and not the other), as far as the parking lights staying on, check the door "pin" switch that controls the interior lights (are the interior lights staying on too?), since the chimes are staying on even with the keys on , I would suspect the door pin switch, probably the drivers side. I believe there may be a timer on the parking lights that turn them off after several seconds after the door is closed, this may be at fault if not the pin switch. newer cars and trucks also leave the reverse lights on for a while after the door is closed.
Dec 20, 2013 | Chevrolet Silverado Cars & Trucks
Open door chimes and keys left in in car chimes plus left on chimes not working question what operates chimes door lock ?
Door left open chime is operated by your interior light switch. It is located in a few places on different vehicles. Often in the door jam at the front or low down on the pillar at the rear of the door. You will notice a little black rubber boot and when you push it it goes in and out. That is your interior light switch.
Feb 04, 2011 | 2000 Volkswagen Golf
1988 chevy siverado chime does not work when you leave headlights on
Try to look up the following for an aftermarket buzzer that installs in the fuse box:
I think it says $8.50 plus shipping and handling to fix your problem.
The buzzer sounds like a piezoelectric buzzer rather than a chime, but it works. I put one on my 1990 Cadillac Deville that had a chime that stopped working. Usually the chime that comes with the car when it goes bad is not repairable economically except by this aftermarket solution.
Good luck on this upgrade or repair of your left lights on chime.
Dec 18, 2010 | Chevrolet Silverado 1500 Cars & Trucks
My Chevy Venture 2003 door chime on drivers side chimes without key in ignition with door open. Before this happened my dash lights acted funny and then went out. When I shut off the van and opened the...
Sometimes the ignition key does not "deactivate" when removing the key...try wiggling the washer behind where the key goes...sometimes this sticks...:)
Dec 08, 2010 | Chevrolet Venture Cars & Trucks
No sounds
check out the fuse for the chime if that good you may have to replace the chime give these websites a try its and you can stop by a GM-dealership in the parts department and they can print you out pictures and diagrams showing you where its located and what it looks like wish you the best Michigan Man.
Nov 07, 2009 | 2000 Chevrolet Cavalier
Program a keyless entry remote on a 2000 chevy malibu
Method One
Sit in driver's seat
Close all doors
Press and HOLD UNLOCK button on door lock switch.
Insert and remove ignition key twice. Do NOT turn ignition switch
Insert ignition key a third time and leave it in the ignition switch. Do NOT turn ignition switch
Release door lock switch.
A chime will sound three times indicating remote programming active
Press and HOLD the LOCK and UNLOCK buttons on each remote for 5 seconds
A chime will sound twice for each remote: indicating successful programming
Remove the key from the ignition switch to exit programming
Method Two
Remotes can be programmed using diagnostic equipment.
Jul 08, 2009 | 2000 Chevrolet Malibu
No door chime, radio won't turn off.
Did you have to splice any wires? Also could you have been sold the wrong harness, and chime modual?
Jul 01, 2009 | 2000 Chevrolet Cavalier
Need programming instructions for RKE for 2000 Mazda 626
2000 Mazda 626
Note: Make SURE the battery is new.
Instructions for programming ONE keyless remote fob.
1. Open the driver’s door & leave open.
2. Insert the key in the ignition.
3. Turn the key to the on and off position 3 times.
4. Remove the key from the ignition.
5. After door open chime stops, press the door open button 3 times.
6. After chime, press any fob key twice.
7. After second chime, press any fob key twice again.
8. After third chime, press any fob key twice again.
9. Press the door open button once.
10. The car should give another acknowledgement chime.
11. Test key fob.
This DOES work. I just programmed mine successfully today, three hours ago.
Sep 03, 2008 | 2000 Mazda 626
Kenwood KDC-MP335 CD Player Logo
140 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
