Question about Maytag Microwave Ovens
Our Maytag Microwave MMB 6040 has a loose handle (RHS) on the door. Not sure how to disassemble interior of door to retighten screw/screws.
  • 1,711 Answers
To access the door handle mounting screws, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to simply pry the plastic up and work your way gradually around the perimeter of the glass. The microwave oven has grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply retighten the handle screws. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
If you have questions, please let me know. I hope you find this information helpful
Posted on Sep 29, 2010
Cannot access screw for lower part of handle blocked by interior assembly
The inside of the door must come apart. Be careful that screen inside the door is actually a choke to keep the microwave radiation in. Make sure that you replace each and every screw and everything else just as you took it apart.
Good luck
Dec 13, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Loose microwave handle
The handle screws are installed from inside the door, so it would be necessary to disassemble the door to tighten them. You have to decide whether the time and labor involved are worth it.
May 19, 2013 | Microwave Ovens
GE Microwave model JVM1650CH01. Trying to replace door handle." I have removed panel on inside of door and removed 2 screws to handle. It appears that there are screws holding the outside cover of door...
This image might help. If not it looks like you have to disassemble the door until you get to the very outer frame, as that is where the handle screws are
May 07, 2010 | GE JVM1650 1000 Watts Microwave Oven
I got the screws off for the door handle on the ACO1860AS Microwave but the handle will still not come off. Is there another mechanisme or hidden screw that needs to come out?
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
From the service manual:
Door Disassembly
1. Disconnect power to oven and remove oven door,
(see "Door Removal" procedure).
2. Pry away choke cover, by placing a tool in the upper
right corner of the door and gently prying outward on
the choke cover. Continue to work around the door
casing until choke cover is completely loose.
3. Slide latch assembly upward and to the left to
release plastic tabs from door frame. Once latch
assembly is loose the spring may be disconnected
from the door frame.
4. Remove screws securing door handle and door
frame to door panel.
5. Remove door frame by releasing tabs around entire
door panel.
Remove door handle by placing a hand on door panel
next to the top of the door handle. Twist door panel
towards the inside of door and pulling on the top
portion of the door handle in a quick jerking motion.
NOTE: When replacing door handle, the bottom portion
of the door handle must be inserted first.
You can find handy exploded views and order parts by model number here.
Apr 18, 2010 | Amana ACO1860 Microwave Oven
GE Spacemaker microwave model JVM130J - handle loose
Yes, you're right about the screws. The inner door is held by clips. Just pop it out using a butter knife or something similar. You might need to remove the door from hinges first (It's been too long after I repaired one of these, so I don't remember exactly).
Oct 14, 2009 | Microwave Ovens
Handle broke off my GE Advantium 120 microwave door (model #SCA1000DCC03). I just ordered a replacement handle (PRT #WB15X10071) but I need instructions on how to replace it. The screws are hidden inside...
You are correct. The handle screws can be accessed by simply removing the interior facing of the door, and can easily be replaced without the assistance of a repairman. This is a common problem with some microwave oven doors.
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, simply open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
NOTE: You can view some excellent exploded view diagrams of your oven at pcappliancerepair.com as reference to see how the parts are assembled.
Sep 16, 2009 | GE Advantium 120 Convection/Microwave Oven
Replace handle on adeantium sca1001fss01
you have to take the door off and pop out the plastic molding around interior of door. You can do this by sliding a screwdriver around the edge until you can get your fingers in. Be careful because there are some small plastic tabs that will break very easily. Next, remove screws on the backing of the door. There are similar tabs holding the backing on even after the screws are removed. I used a pair of insulated pliers and used the handle to pry the tabs back. Be careful because the tabs will break easily. Then the screw handle is exposed. Pretty easy huh?!!!! I just comleted this process and am looking for a handle. I am sure I will have to super glue some areas since I broke the tabs off.
Good luck
Jun 01, 2009 | GE Advantium 120 Convection/Microwave Oven
Need to Replace Door Handle for KitchenAid Over Range Microwave Hood Combo KHMS147KSS
Check out this door frame diagram, specifically number 1805. It clips on to the door frame. Remove it using a dull table knife or something similar (be careful not to scratch or break anything). You will then have access to the bottom screw.
Mar 18, 2008 | GE Advantium SCA1000H Convection /...
Microwave door handle
First, never remove the door. You will disturb the alignment which holds in the microwaves. Generally, the door can be disassembled by removing the screws on the cavity side of the door. Once inside, then you should be able to replace the handle. Often the screws are of the torx variety...also call star.
Dec 25, 2007 | GE Advantium 120 Convection/Microwave Oven
Replacing door handle
The choke cover (or door gasket on your brand) will come out similar to the diagram shown below.
Then the hidden screws should be visible.
Also, you can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Oct 20, 2007 | Maytag MMV5156AAS Microwave Oven
Microwave Ovens Logo
41 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
