When we put the heating on, water drips from the overflow. we have an engineer booked for next week, but in the meantime, should we not have the heating on?
  • 455 Answers
Hello,Sounds like a defective expansion tank(extrol).If this is the case you can run heat BUT the blow off will leak EVERY time the burner is on and running.The water will (make up) automatically.Do not run this way for too long (2 weeks)& only if the water leak will not damage anything.
Posted on Sep 29, 2010
Vaillant boiler leaking only when heating switched off.
It would seem a joint has come a bit loose from the heating and cooling cycle. put a drip pan under the leaking area( the drips would evaporate quickly), then next time you shut it down go through all the joints in the area with wrenches to find the loose joint.
Oct 27, 2014 | Water Heaters
Tip
Refrigerator not cooling-freezer section icing up
Refrigerator not cooling, ice forming on back of side-by-side freezer:
Turn off unit. Empty freezer section. Remove freezer back panel (4 screws) to expose iced-over coils. Use a fan to speed up defrosting. Put a towel or a plastic drip pan in the bottom of the freezer to collect melting water (rather than letting the water collect and maybe overflowing in the drip pan underneath the refrigerator).
After defrosting, by temporarily replacing the freezer back panel and turning on the unit, the refrigerator may operate OK for about 3 weeks before the next excessive ice build up.
Possible problem- a burned out Defrost Heater.
To check: After defrosting, turn off power to or unplug the refrigerator.
Unscrew the Defrost Heater bracket (2 screws). When loose, unplug the two wires connected to the unit. Have the unit checked, or use an ohm-meter to check continuity. If unit measures "open", high resistance, replace the Defrost Heater and bracket. If the heating element shows continuity (or low resistance) the heater is probably OK and you have another problem. Now you may need to contact a repair man.
on Jul 06, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
Truck getting hot and over heating but there is no heat
You have a vapour lock. The coolant isn't flowing. The remaining water is not cooling your engine evenly so you could crack your engine block. The water that isn't circulating turns to steam. The water pump could need replacing if the impeller failed. You may need a new thermostat. Get someone knowledgeable enough to fill your radiator properly and then keep the overflow reservoir filled to half. Check that bottle at least every week.
Nov 29, 2013 | 2006 Ford Explorer
Several weeks ago I had a hose burst in the cooling system -- towards the rear of the engine of my 1997 Safari van. Afterwards I started hearing like the sound of trickling water coming from the heater...
It sounds like you still have a leak somewhere, maybe it's a hose clamp that wasn't tightened or another leak. You should check the coolant level in the radiator, not the overflow bottle. If the system has a leak it won't create a vacunm to draw in the coolant from the overflow, the radiator could be very low. The sound you were hearing was air bubbles in the heater corem maybe the coolant wasn't topped off.. If the core was leaking there would be coolant dripping on the passenger's side floor.
Mar 30, 2011 | 1997 GMC Safari
Unit ED5DHEXWQ bought 2 weeks ago Drip pan over flows- water not evaporating quickly. Company tech say I need to modify my frig by placing a heater. 2 The refrig side is not gettinG COLD ENOUGH - MY MILK...
The tech is full of beans. The heat from a normally charged refrigerator is more than enough to evaporate water in drip pan.
The indication of improper charge is that obvious. Fridge warm freezer ok would be a coil blocked with ice, however drip pan overflowing is a charge problem, Ask for a field supervisor.
Dec 24, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Drip pan is full and overflowing onto floor
If the temperture behind the compressor is not so hot the water will not evaperate. the heat from the compressor dry out the water.
Jan 03, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Excessive water dripping from Central A/C drian line
sounds like the overflow drain is picking up the water that means the main drain is clogged.you need to find the main drain pipe if lookin at the air handler in attic there should be 2 drains from unit one higher than other follow it and blow out drain they put the other overflow drain out the eve so if it stars leaking someone notices it and it doesnt damage cieling but it sound like it needs imediate attention befor it does go to the overflow pan and damage your cieling. i hope this helps and good luck
Sep 29, 2009 | Amana PTC153B35AJ Air Conditioner
Overheating and grinding noises
First thing you need to do is zero in on where the coolant is leaking out,and where oil is going. Sure sounding like a head gasket, or worse. What engine& mileage?
May 23, 2009 | 1993 Dodge Spirit
Overheating '99 Mazda 626 LX 6-cyl
Finally gave up and took to local shop where they performed a pressure test on the engine coolant system. They found a small hole in the plastic reservoir which had to be replaced. Issue now resolved – thanks!
Jul 13, 2008 | 1999 Mazda 626
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
