Question about Toshiba e-Studio163 Copier
I simply need to HARD reset my Toshiba e-studio 160. Or back to factory settings.
3 Suggested Answers
  • 43 Answers
SOURCE: toshiba 160 error code
c44 = fuser error
turn copier off
hold down 0 & 8 while turning it on
then wait one min, then press 4 0 0 start
then 0 and set
turn off wait one min then turn on if this does not work it might need parts
Posted on May 08, 2008
  • 647 Answers
SOURCE: I need a way to reset admin password back to
Enter settings mode 08-263, enter your desire password (within 10 digits).Default password is "123456"
Posted on Jul 22, 2009
I need to completely reset my computer
When turn power on, press and hold "0", until it tells you what to do.
Then select the factory reset. if you select delete files, the, it deletes all in hard which means you need set up disk from toshiba.
hope this helps
user guide and support
http://cdgenp01.csd.toshiba.com/content/support/manuals/userguides/su2728212/GMAD00247011_SatA660_10Oct28.pdf
Sep 21, 2012 | Toshiba Satellite A665 Notebook
Reset factory settings for toshiba S241-504
Back up all of you data to an external drive before you begin the process
If you make a mistake during the process, your laptop may not be able to turn on or load the
operating system, so copy valuable information to media where you can retrieve it, even if your laptop malfunctions.
Turn on your system and wait for it to finish loading Windows and start-up programs.
You can tell when the operating system has loaded, and start-up programs have been initiated, by the HDD (hard disk drive) light.
It should have came with discs. Put one in and reboot the laptop
Insert the system disk when the hard disk light stops blinking, signaling that the processor has finished accessing the hard disk, and that the system is idle. Shut down your laptop after you insert the disc.
You do not have to wait for the computer to access data from the disc.
Turn on the laptop again. Keep pressing the "C" key continuously as the system boots. This will enable the laptop to boot from the disk. Once the disk is accessed, the laptop will show
the message "Loading Files;" begin the factory reset process by always selecting the default option that pops up.
You can also use the "F12" key to boot from the disk.
Highlight the CD/DVD option and press "Enter" to begin the restore process.
Follow the on-screen instructions until the process finishes
Restoring a Toshiba laptop back to factory settings may take 30 to 45 minutes.
Unless you terminate a process by pressing "Cancel," your laptop will be rolled back to factory defaults, when the operating system installs completely.
hope this helps
Jul 18, 2012 | Toshiba Satellite Computers & Internet
Factory settings for toshiba satellite laptop
Back up all your data to external media before you begin the process.
If you make a mistake during the process, your laptop may not be able to turn on or load the operating system, so copy valuable information to media where you can retrieve it, even if your laptop malfunctions.
Turn on your system and wait for it to finish loading Windows and start-up programs. You can tell when the operating system has loaded, and start-up programs have been initiated, by the HDD (hard disk drive) light.
hope this helps
Jul 17, 2012 | Toshiba Satellite Computers & Internet
Where do I find the recovery partition on my toshiba l645d laptop with windows 7?
The recovery partition is basically the same as the Toshiba restore CD if your model has one. The restore partition is located on a separate partition on the hard disk (if it has one).
If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state.6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
Feb 24, 2012 | Toshiba Satellite L645D-S4050 Notebook
I dont have the admin password toshiba e-studio 202L
202L HOW TO RESET ADMIN PASSWORD IS HOLD 08
TURN ON MACHINE YOU WILL BE IN TEST MODE THEN
PRESS 263 CLEAR OLD PASSWORD AND ENTER DEFAULT PASSWORD 123456. ENTER TUNRM OFF MACHINE THEN ON.
Jan 05, 2010 | Toshiba Office Equipment & Supplies
I have a Toshiba studio 45 with error code c44, what can I do ?
You should apply to service Toshiba.
The Possible faults in lamp of the heating, thermistor, contact of the elements of fuzer or in signal of the controller of the direct current.
C41 Fuser thermistor, or no heat C43 Fuser thermistor problem or other fuser problem, after machine goes into ready C44 Heater problem
Oct 07, 2009 | Office Equipment & Supplies
Toshiba E-Studio 160
When the message call for service is displayed
press the C key and the 8 key at the same time
an alpha numeric code will appear eg: C47 etc
Post the error code and I'll tell you what it means
Jan 19, 2008 | Toshiba E-Studio 160 All-In-One Laser...
Toshiba e-Studio163 Copier Logo
659 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
