Question about Electrolux EW1200i Front Load Washer / Dryer
Starts to spin then cuts out - Electrolux EW1200i Front Load Washer / Dryer
  • Electrolux Master
  • 17,130 Answers
Check the program controller for shutting off, check the motor for tripping off , possible door switch making it cut off - safety switch on the door.
If prograam controller , check for loose connections, if motor check if heating off, check capacitor .
Posted on Sep 29, 2010
Why does spin cycle cut out before hitting max RPM?
G box or timer not staying on long enough
Sep 03, 2015 | Washing Machines
Car cuts out won't start
but does it crank robustly
no car starts unless you can spin the crank shaft fast.
my car push starts. too. (m/t box) or gravity starts.too.
but if A/t? the starter motor is your life line. only.
at means automatic tranny.
Jun 24, 2015 | 2001 Peugeot 307 2.0
Washer won't go into spin cycle, stops after final rinse. When I try drain &rinse it still will not spin.
If the unit does not spin correctly, this is usually an indication that the unit can also not drain. The unit will not spin if it senses a blockage or issue with the drain lines and/or pump. Try to check the drain lines in the back of the unit for any issue, and then see if you have an access panel to get to the coin trap or drain pump itself. Often socks and debris will clog up in this area and cause your problems.
Dec 25, 2012 | Frigidaire ATF6000ES Front Load Washer
I have a 3 year old ys4500, wont start
Have you tried bypassing the cut off switch, by joining the wires together
Sep 20, 2012 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
When raising the bar to start to cut the Toro makes a terrible squeaking and the engine cuts. Help. The lawnmover will start. It is model 2622-21" rear bagger. We cut the back lawn and went to cut...
Is this a self propelled? Since it will run, blade spinning, the bar you are mentioning to start cutting is for the self propelled drive. The terrible squeaking is probably the belt slipping due to something causing the wheel to bind. Check for the ability to turn the drive wheel by hand. Then check under the cover for any binding.
I hope this helps you out.
Jul 27, 2011 | Toro Garden
Simpson 175 washing machine: spin cycle noisy and motor cuts out after short spin. Bowl feels stiff
Hi just read your posting.Now from the information on your posting the machine is noisy on spin and your motor is cutting out after a short spin.Is this correct?Now does the motor cut out during a wash cycle?If the motor only cuts out during the spin cycle , and with your machine being noisy on spin,I think the fault will be your bearings are corroded.With the bearings being corroded it puts more load on the motor causing the inbuilt thermal overload in the motor to activate and turning the motor off to save it from burning out.Please reply with additional information on, if it cuts out on wash and I am sure I can help you further.
Aug 07, 2010 | Washing Machines
Chain spins when not cutting
Sounds like a clutch issue but if the chain is spinning once you start the unit you'll need to do some adjusting to your carb.
Apr 13, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Cutting head will not stay on
If your twine cutting head spins off when started,you probably have a bad gear box (bearing went out)
Jul 11, 2009 | Garden
My amanda washing machine
My amana washing machine will not unlock
Mar 21, 2008 | Washing Machines
Electrolux EW1200i Front Load Washer / Dryer Logo
99 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
