Question about AOC Computers & Internet
When I switch on the monitor it glows white and doesn't display anything. it stays white even when you press the menu button on the screen it just remains white.
    Master:
  • 633 Answers
Your monitor needs repair.
Posted on Sep 29, 2010
Why did my computer monitor stop showing an image?
Disconnect it from computer and power. wait 15 minutes and plug only the power back in, press the power on button. The monitor may display a message that there is no signal or something like that. If that happens the problem is either the cable or the computer. If you get no message then look for the menu button and press it to see if any thing appears. If not find the manual on line and read it. Many times monitors get over-driven by computers to the point that they can't display OR they self destruct.
OR
Another way is to just unplug everything computer and monitor for 15 minutes. Plug in monitor first then plug in computer and press the power button, the display should display the booting information if the cable is good and the monitor is good.
Jul 19, 2014 | ViewSonic Computers & Internet
Monitor screen is black cannot see anything on the monitor
If the screen is black even when you press the menu button or switch to playback, than it's probably because of a defective LCD display. Anybody with basic repair skills and experience would be able to replace the lcd display with a new one. Try to find a display specifically for a L24 camera on ebay or elsewhere. There might also be a few video's on the internet how t disassembly this camera.
Jan 01, 2014 | Nikon Coolpix L24 26240 Digital Camera -...
Hi ! i have dell vostro 1510 and which is not booting up. even the bios is not showing up. Black screen appears and the loading lights blinks for 4-5 times then nothing happens. Power button is glowing...
- try to plug an external monitor on your laptop
- if you can see a screen on the external monitor, then you have a faulty LCD
- if you don't see anything on the external monitor, then you have a faulty motherboard
Jul 04, 2011 | Computers & Internet
Grandchild misplaced cd that came with new monitor and now i cannot find out how to do anything with the new monitor as how to change the color as it seems very pale and what are the buttons on the bottom...
Press one of those buttons to activate the OSD (On Screen Display).
Press the left/right buttons to switch between menu-entries on the OSD.
Press the OK button to select a specific menu-entry.
Press the left/right buttons to change the value.
Press the OK button to commit the change.
Wait 30 seconds, and the OSD will disappear.
Jun 06, 2011 | E-Machines eMachines Monitor E15T4
OSD LOCKOUT Display on my Screen HP L1940 Silver Lcd
Release the menu button (check if anything is leaning on it), and press and hold the menu button again until the message disappears (app. 10 seconds). If this doesn´t work, the button may be stuck, or there´s a problem with the hardware.
Nov 02, 2010 | HP L1940 19" LCD Monitor
Monitor does not work, powers on screen goes white or almost all white, can not get menu or anything to display, green power button stays steady.
White glowing screen means it is not getting the signal from the logic board or the logic board is not seding the 5 or12vdc to the T-CON board on the LCD panel. So check the voltages and caps.
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Sep 15, 2010 | Dell E198FP LCD Monitor
Menu stays on screen all the time and wont go off even when pressing buttons .Off On button doesn,t work either.Could cig smoke gum up buttons
Cig smoke wouldnt effect the buttons, the control board on the monitor is probably bad, this is what tells the monitor to display the menu, make changes, etc... If that has gone bad, pushing buttons would have no effect. Youre probably better off buying a new monitor.
Jan 20, 2010 | Computers & Internet
Dell E171FP Monitor goes black after 2 secs
Hi, I don't think the problem is with your monitor. Your monitor sounds like it's doing exactly what it's supposed to do. The monitor is supposed to turn off if there's no cable attached, which means there's no signal input. When the screen goes black, does the power light stay on and turn orange? or does it go off as well? I would recommend that you lower your screen resolution to 1280x1024 or lower in the Display Properties window, then remove your primary monitor, and connect the monitor to your desktop computer. You should see it light up when connected. The monitor auto-senses when there's a computer attached to the cable and when there's a signal. If it doesn't see a signal, it goes black to save power.
Jun 17, 2009 | Dell E171FP 17" Flat Panel LCD Monitor
Blank Screen
Can you see anything at on but dimly? If so thats is the backlight tube If you cannot see anything then it is a major fault eitherway a repair shop job I should think
May 30, 2007 | HP L1902 19" LCD Monitor
Computers & Internet Logo
356 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
