Question about HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer
Print Spooler Problem
Print spooler wont work, i start it everytime and my printer still cant be added or be found Tried to restart spooler. Msg. said couldn't be done. Now spooler doesn't even show on the list in services.
  • Anonymous Jun 20, 2008
    says printer spooler not on to reconnect or turn on service
  • 234 Answers
Try this:
Start the computer in safe mode then delete all the files and the folders in the following two folders: • C:\Windows\System32\Spool\Printers
• C:\Windows\System32\Spool\Drivers\w32x86
Start Registry Editor. To do this, click Start, click Run, type regedit in the Open box, and then click OK
Locate and expand the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Environments\Windows NT x86
View the list of subkeys. There should only be the following subkeys: • Drivers
• Print Processors
delete any other in this list
Locate and then expand the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Monitors
View the list of subkeys. There should only be the following subkeys for the default print monitors: • BJ Language Monitor
• Local Port
• PJL Language Monitor
• Standard TCP/IP Port
• USB Monitor
delete any other in this list then restart your computer.
Good Luck
Posted on Sep 01, 2008
I cannot print my documents, everytime I click the printer "print spooler is not running". I already restart my printer as well as my computer. And I also tried to reinstall my printer but it doesn
Click Start.
Type services.msc in the start search box and press enter.
Right click on print spooler and click on properties.
Check if the startup type is automatic. If it is not then change it to automatic.
Check if the service status is stopped.
If yes then click on the start button.
Try to add a printer and print a test page.
If you need any technical help on printer then you can reach at here
Jan 25, 2013 | Office Equipment & Supplies
Print spooler subsystem stopped
Start and stop the print spooler Windows XP
To start and stop the print spooleropen Computer Management, click Start,click Control Panel, double-click Administrative Tools,and then double-click Computer Management.In the console tree, click Component Services.
Under Console Root click Services (Local)
In the details pane, double-click Print Spooler.Do one of the following depending on the task you want todo:
Click Stop to stop the service.
Click Start to start the service.When you try to install a printer and get an error message "PrintSpooler is not running" then Print Spooler need to be configured. Open Print Spooler as detailed above and click on the Generaltab then select these items - Startup type select AutomaticService status click StartThen click OK
May 12, 2012 | Office Equipment & Supplies
Can't print. local print spool not working
Try the steps below to clear the print queue and restart your print spooler:
1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
Try to print a document again to verify that the problem is fixed.
Jan 11, 2012 | Lexmark X5495 Printer
I'm trying to print but it says the local print spooler service is not running please restart the spooler or restart the machine I followed the procedure but it did not work.
Try this approach instead:
4. Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
Sep 10, 2011 | Lexmark Z2420 Printer
PRINT SPOOLER SERVICE IS NOT RUNNING MSG DISPLAY WHILE ADD PRINTER AND COULD NOT COMPLETE THE OPERATON
You need to go into services and turn on Print Spooler.
Start Run Type services.msc Click ok Scroll down to print spooler. Right click the entry Click restart.
Check that its startup type is set to automatic as well Right click the entry for print spooler Click Properties Select Automatic in the Startup type dropdown box. Click apply Click ok.
Aug 09, 2011 | Canon LASER SHOT LBP-2900 Printer
Hello, my laser jet printer is not connecting, msg when attempting to print says "Windows cannot open add printer. The local print spooler is not running, please start the spooler or restart machine." I...
Start by removing the printer driver(s). Check several times, as some printers hide in lots of places. Once the printer/driver(s) are all gone, try a new installation.
Nov 07, 2009 | HP LaserJet 1020 Printer
Print spooler
To prevent the spooler from stopping, which is usually caused by invalid printer drivers left on a computer.
Go into "Printers and Faxes" delete all printers which no longer exist by right click --> delete
To restart the spooler :-
click start --> run
type net spooler start click ok
or
click start --> run --> services.msc --> click ok
scroll down to print spooler --> right click on it and select start
Jan 30, 2009 | HP xw6600 Workstation with 650W 80 PLUS...
Everytime i try to print it says that the print spooler isnt working. can you help?
You need to start the Print spooler service, this is in the control panel, under administrative tools, under services - then find print spooler and either start it or restart it.
Robin
Sep 16, 2008 | Office Equipment & Supplies
Spooler sub system app??
The issue occurs because of a corrupted printer driver installed and because of the Vista OS that keeps updating.
-Open up c:\windows\system32\spool\PRINTERS
-Delete the contents of the directory (not the directory).
-Restart the print spool service. (service.msc)
Jul 08, 2008 | Datacard SP55 Printer
Click on start
click on run
Type services.msc
A box will open up
Make sure all items below are set to automactic
To make the changes double click on each item
change to automatic if diabled. Then click apply when you are done.
Restart the computer and try testing your printer again.
Printer Spooler
LexBce Server
Remote Procedure CallRPC)
Hope this solves your problem
Oct 20, 2007 | HP DeskJet 670c InkJet Printer
HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer Logo
96 people viewed this question
Ben Johnson
