Question about HP NB199UA Pavilion Notebook
Hpa pavillion dv4-1220us has very high fan nosie and overheating problem
  • 2,567 Answers
Make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
Posted on Oct 09, 2010
Hp pavavillion dv6 overheating issue
Following are the reasons for overheating, just take care of these things::
Stop Overclocking your CPU
Make sure your Heat Sink is placed properly above the processor
Clean the Processor fan, Heat Sink and other peripherals
Use High Speed fans
Use CPU Heat Sink Paste in the processor
Use Additional Cooling Units
Shut down your computer at least two hour a day
Finally i will suggest you to get system utility program like PC Fresher to maintain your system performance
Sep 15, 2013 | HP 417136-001 PAVILLION DV8000 MOTHERBOARD
My hp Pavillion Dv7 Laptop's cooling fan has stopped working and then my screen after a certain point usually half an hour or so the screen will shut off
Hello
Ok, this is an overheating preventing function of your computer. You need to get this fan fixed as soon as possible, because overheating of the CPU will cause the CPU to bun out.
You will need to order this fan, because it is not a generic fan.
Hope this can steer you in the right direction.
Kind regards
Andrea
Jun 30, 2010 | Computers & Internet
98 Custom Act Paintball Gun: i have just brought a 98 tippmann custom and it ha...
Basically speaking, air is air. Now it's the pressure that's the concern. co2 bottles use a regular valve that has a pin in it and opens to allow the gas through. High Pressure Air - HPA is the same concept but since the pressure with co2 is built up by expanding gas, HPA has to do it with pressure only. So the tank is pressurized a LOT higher than co2, but there's a regulator on the tank valve to bring the working pressure into the marker to the proper level.
So yes, you can use "air", but you need to make sure it has the right output for your marker. (i.e. not a low pressure HPA valve.).
You'll have the same problem though, getting someone to fill the bottle. Check with your local airsmith and paintball fields and stores. If they have co2 they would have HPA, but some do only deal with HPA since it's "easier" in some cases.
You may have to check around. Sometimes hardware stores have a small section in back, or you can check with the paintball places around to see if anyone in your area is equipped. Some teams have their own tanks, especially if there's not a place to get fills locally.
There's also online communities like Brigade and various paintball sites where you can check around for other players. Someone may have a co2 fill tank, a scuba tank for HPA, or a group that gets tanks together to make a run and get them filled somewhere.
Play hard, play safe, play with honor!
8^)
May 18, 2010 | Tippmann 98 Custom Act Paintball Gun
The fan on my HP Pavillion laptop is making a loud noise
It is good idea to repair it in service before burn out. Fan blockage may lead to processor overheating and burning ... so as soon as better regards Greg
Mar 08, 2010 | HP Pavilion DV9700Z notebook PC
HP Pavillion Entertainment PC overheating and turning itself off. Tried to to buy a Gear Head external fan to cool but not helping. What to do?
Mine got so hot the Motherboard burnt up and cost $300 to fix. It still gets hot and I use a cooling fan. This is REDICULOUS!!
Sep 21, 2009 | HP Pavilion dv7-1132nr Notebook PC
HP pavillion tx1000 wirless not working..........overheating
I have been updating hundreds of DV units with a new updated BIOS that changes the algorithm for how the fan operates and turns them on high more frequently to augment additional cooling. I also belive that the program "Speedfan" will allow to manually set the fan speed.
Sep 03, 2009 | HP Pavilion tx1000z Notebook
I have a HP Pavillion TX 1000. Did everyone heard
It is highly improbable that heat from the CPU can crack a LCD screen. Even if the fan was faulty the CPU would have shutdown (thermal overload) before it would affect the LCD screen. If you apply pressure to the face of the LCD screen or twist the screen or impact the screen with a hard object, any of these will cause the LCD screen to crack.
Jun 11, 2009 | HP Pavilion tx1000z Notebook
Hp dv6700 pavillion mother board bad if it has overheating issue?
it sounds more like the system is overheating to me, they are classic signs.
Have you tried to clean the system fan and the air vents with compressed air? if not try that and see if it stays on longer.
Post back please.
Good luck
Apr 22, 2009 | HP Pavilion dv6000z Notebook
Hp pavillion ze2000
Are you wirless or wired to the network?
If wireless, you just may be getting a crudy signal, try getting closer to access point ( router).
Also, Verizon sux, i hate them, personally.
Anyways.
If you show the connection is good, then it could just be you have a slow system. I need to know your specs.
1. What operating system
2. What type and how much RAM
3. What kind of processor
4. what kind of Video Card?
5. Dial up? or High speed DSL ?
6. Wired or wirless?
Get back to me and we can see whats up.
Oh, its not overheating is it. When it runs slow, is the cooling fan reving really high? Is it giving off alot of heat besides the norm when it starts acting up?
Dec 01, 2008 | HP Pavilion ze2000 Notebook
Crazy fan nosie
Noise from computer You should only expect to hear a slight hum from the CPU fan; below are some issues that may cause additional noise from your CPU fan.
Click on the above link , follow instruction, Good Luck.........Please dont for get to Vote.Thank You.
Dec 15, 2007 | E-Machines M2352 Notebook
HP NB199UA Pavilion Notebook Logo
677 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
