Question about HP Officejet 6310 All-In-One InkJet Printer
Horizontal red lines when printing
Every time we attempt to print, horizontal lines appear in the document. We have put in new cartridriges, cleaned the cartridriges, aligned them over and over........ The lines keep appearing and the document then becomes faded. HELP!!!!!!
  • 38 Answers
Horizontal line is carriage axis , while moving its may give line if some dust or resdual ink may be on he carriage base
clean the caping station and cleaning wiper ( place where carriage rests )
if its not resolved please update sample images for same
Posted on Jun 06, 2008
I have a HP Office Pro L7580, model #C8187A. I am getting white horizontal lines across my documents. The white lines appear about every two to three inches. The top portion of the letters are missing
The black print head has a few blocked nozzles.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Apr 04, 2013 | HP Officejet Pro L7580 All-In-One InkJet...
My prints are coming out with Horizontal lines on them. What can I do to rectify this problem?
Please try this approach:
  1. On the printer operator panel, press Options repeatedly until Cartridges appears.
  2. Press the right arrow button until Clean appears on the display.
  3. Press Select. A nozzle page prints forcing ink through the nozzles to the clogged nozzles.
  4. Print your document again to verify that the print quality has improved. If print quality has not improved, try cleaning the print cartridge nozzles up to two more times.
Aug 21, 2011 | Lexmark X5150 All-In-One InkJet Printer
Everything is setup properly and the printer actually attempts to print, but nothing is showing on the paper---the ink carts are full, but I have not used printer in a year
It could be that the nozzles on your cartridges have clogged due to long period of non-usage. Try to follow the steps below to clean the print cartridge nozzles:
Using the computer:
  1. Load plain paper. For help, see Loading paper.
  2. Open the Lexmark Solution Center. On your computer, click Start menu > Programs / All Programs > Lexmark 4300 Series > select Lexmark Solution Center.
  3. From the Maintenance tab, click Clean to fix horizontal streaks.
  4. Click Print. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
  5. Print the document again to verify that print quality has improved. If print quality has not improved, try cleaning the print cartridge nozzles up to two more times.
Using the control panel:
  2. Press Menu. The menu appears.
  3. Press the down arrow button until you highlight Clean Cartridge. Press Select.
  4. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
Aug 15, 2011 | Lexmark P4350 All-In-One InkJet Printer
Problem printing a microsoft document
Have you tried printing documents in other programs for example in "notepad" or "wordpad?
If the lines do not occur in either of those other progrrams, then the problem may not lie in your printer...
if it does happer, however, you might wanna consider getting a new printer? if much cheaper to get a new one than to get an old one fixed.
Oct 01, 2009 | Microsoft Windows XP Professional for PC
Horizontal lines (red) on first 1 - 2 pages of initial print-out
Do you refill ink tank? Print blank pages. Is there horizontal lines appear? It might be caused bay ink leakage. Check respiratory hole at ink tank and rubber seal at bottom of ink tank. Print blank pages until no horizontal lines and try to use new ink tank.
Aug 17, 2009 | Epson Stylus Photo 1270 InkJet Printer
Red and blue lines across printouts
open printing preferences and click on maintenance. Run the print head alignment utility. Sometimes this will remove the horizontal banding. I had this same problem and had to uninstall the printer and reinstall just like it was new, running the alignment feature before it was corrected. Worked ok for a few days then started again. I assumed that the printhead is bad. To costly to repair and bought a new printer.
Jun 27, 2009 | Epson Office Equipment & Supplies
Horizontal white lines through the text
Your ink cartridge (s) is dried up, even some new ones are dried up, even tho' they're sealed.
Some self-tests don't use black.
Sep 21, 2008 | HP DeskJet 6122 InkJet Printer
HP Deskjet F380 won't print
i think the inside printer have dirt or obstacles that blocken the cartridges while printing.
try to clean manually the printer by using powerful air blower,repeatedly.
Sep 14, 2008 | HP DeskJet F380 All-In-One Printer
HP 7110 still won't print in color
Your post " prints very faint horizontal lines in color..." is indicative that indeed your color printheads are clogged and would need repetitive deep head cleaning. This is of course would require that you keep on cleaning until such time as the faint color lines have turned to legible print.
Apr 08, 2008 | HP OfficeJet 7110 All-In-One Thermal...
When printing in color a yellow line appears on document
A horizontal line U say and U don't have problems in B&W pages.... ( on the length or width af a A4 page?) the yellow line is just a line or parallel lines at the same distance?.
1-st of all try replacing the Y cartidge.
Jan 17, 2008 | HP LaserJet 2840 Printer
HP Officejet 6310 All-In-One InkJet Printer Logo
730 people viewed this question
Ben Johnson
