Question about HP Officejet 5610 All-In-One InkJet Printer
My printer give me error when I try to change the color cartridge same as the old one Tri-colour 22 and also after cleaning the holder,what can I do ? Thanks for your help ,regards G.Conti
    Director Badge:
    Uploaded 100 video answers.
  • 1,751 Answers
Hi
try the black one
Posted on Oct 30, 2010
Printer wont print the color brown
Try cleaning nozzle with dry paper towel, cartridge should leave 3 streaks: Yellow, Cyan, Magenta.
If colours on paper seams to be tinted or mixed the cartridge needs to be reclamated, there is no other solution.
If there is an lack of one or more colours try to wipe nozzle with wetted paper towel in window cleaner. After few wipes, 3 colours sholud apper
Oct 21, 2012 | HP 60 Tri-Color Ink Cartridge
Will 27 black and 28 tri-colour cartridge work on a D1560 hp deskjet
HP 21 black and HP 22 tricolor cartridges are the cartridges compatible with HP DESKJET D1560.HP 27 and 28 won't work with your printer because they won't get recognized by the machine.It will only give you an error message like incompatible cartridges.
Jul 21, 2011 | HP D1560 Deskjet Printer InkJet
Im getting a error about the tri color cartridge. i took it out of the printer but now i cant print anything. what is the problem?
The printer will not print unless both cartridges are in place.
If it gives you an error after putting the tri-color cart back in ... replace it
Jan 23, 2011 | HP OfficeJet J4580 All-In-One Laser...
Ink cartrige problem
This is error is common after a cartridge is refilled, in most cases it's because of "bad refill" and we can also say "dead cartridge". If possible, Please try the cartridge on another printer or try your printer with another cartridge. (i hope you know what tri color mieans = the color cartridge). Make sure the cartridge is not overflowing or leaking. Clean if possible, and never touch the print head, if you ever did so there's no way to make it work again. Hope this helps. Good luck Thanks for using FixYa.
Jun 01, 2010 | HP PSC 1510 All-In-One InkJet Printer
How to change 75 tri-color ink
Turn the printer on.
Open the door covering the print-carriage.
The cartridge-holders will slide to the middle.
Push "down" and slightly towards you to "unlock" the cartridge from its mount.
Then, gently lift the "unlocked" cartridge out of its holder.
Nov 23, 2009 | HP PhotoSmart 245 InkJet Printer
Why are only black and yellow printing?
The printer has two ink-cartridges: black and tri-color.
The black cartridge has ink left.
The tri-color cartridge has run out of 2 of the 3 colours of ink.
Buy a replacement tri-color cartridge,
and responsibly recycle the "empty" cartridge.
Nov 19, 2009 | Canon i9100 InkJet Photo Printer
ORANGE LIGHT IS BLINKING AND PRINTER WILL NOT PRINT
The Amber light is designated as the "Ink Error" light. With regards to a Hewlett Packard printer, the Amber light is indicating that one of the Ink Cartridges (Tri-Color/Black) is empty, defective, unrecognizable, or just simply needs to be changed. The procedure is; lift up the front cover, look at the Black Ink Cartridge, and examine the Ink Level Window on the Cartridge, located at the center of the Cartridge. If the square window appears to be a solid Green then that means the cartridge is completely full. If it is Half Green/Half Black then it is indicating that the cartridge is half way full, and if the square window is completely Black, then the cartridge is completely empty. Also, remove and examine the Tri-Color Cartridge. If the Tri-Color Cartridge feels very light or if the Tri Colors on the bottom of the Cartridge appear to be discolored i.e. All Magenta, All Cyan, or All Yellow, then the Cartridge should immediately be changed. After replacing the Black or Tri-Color Cartridge, your printers Green Power Light will flash and allow you to continue your print job
You can also try:
Clean the cartridge and carriage contacts with a cotton swab moistened with water. If you have refilled the cartridges don't assume that they will still work. If cleaning doesn't help you may have a failed cartridge even if it is not refilled.
If you are getting a grinding noise, clean the carriage rod with alcohol and lubricate it with a few drops of Tri-Flow, available in 2 oz. squeeze bottles at cycle shops.
If I have helped please rate my post...I will always do my best to help
Sep 11, 2009 | HP Laser Jet 1320 Printer
Orange blinking light at cartridge icon
The Amber light is designated as the "Ink Error" light. With regards to a 960C Hewlett Packard or almost any inkjet printer, the Amber light is indicating that one of the Ink Cartridges (Tri-Color/Black) is empty, defective, unrecognizable, or just simply needs to be changed. The procedure is; lift up the front cover, look at the Black Ink Cartridge, and examine the Ink Level Window on the Cartridge, located at the center of the Cartridge. If the square window appears to be a solid Green then that means the cartridge is completely full. If it is Half Green/Half Black then it is indicating that the cartridge is half way full, and if the square window is completely Black, then the cartridge is completely empty. Also, remove and examine the Tri-Color Cartridge. If the Tri-Color Cartridge feels very light or if the Tri Colors on the bottom of the Cartridge appear to be discolored i.e. All Magenta, All Cyan, or All Yellow, then the Cartridge should immediately be changed. After replacing the Black or Tri-Color Cartridge, your printers Green Power Light will flash and allow you to continue your print job
You can also try:
Sep 10, 2009 | HP DeskJet 960c InkJet Printer
HP Laser Jet 1320. Orange light next to triangle symbol keeps flashing. This began after a paper jam. I cleared the paper jam but can not get the light to stop and so it wont print. I have shut it off...
You can also try:
Apr 09, 2009 | Office Equipment & Supplies
Always used hp tri-color print cartridge in in my hp psc 2355 all-in-one printer. Has stopped working. Says printer has wrong tri-color cartridge inserted
Check manual for appropriate cartridge class for tri color and use same numbers as in manual you may be using 22 cartridge for 28 for example for your printer this cartridges look the same in all aspects but some HP printers can only be used by only one of this types. Check printer manual for compatible ink cartridges. And if you have been refiling the old cartridge you need to get a new one to reset the computer cartridge memory count.
May 30, 2008 | HP Office Equipment & Supplies
HP Officejet 5610 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
