Dell fp1701 monitor flickers and makes a high pitch sound
  • Anonymous Nov 04, 2008
    I Have Samsung SyncMaster750s connected to a TV Tuner card and giving flickering and High Pitch sound.
  • KG John Justin
    KG John Justin May 11, 2010
    Give some m ore information
  • 37 Answers
May be a bad monitor, or possibly running the monitor at too high frequency/resolution. Try changing to something generic like 800x600 at 60Hz to test and see if it's still gdoing it. If so prob a bad monitor
Posted on May 26, 2008
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
Monitor Goes black, or flickers on and off
The high pitch sound is coming from the inverter. It is faulty and needs to be repaired or replaced. The inverter supplies high voltage to the CCFL lamp, this lamp gives the backlight to the LCD so you can see the LCD images.
Check out LCD parts for parts, service and DIY info. use this link :-
www.lcdparts.net
Aug 29, 2009 | ViewSonic OptiQuest Monitor
Dell tower desktop Dimension 5100. Tower makes whistling sound.
sounds like it could be a bearing in your hard drive. is this problem constant? If so, I would open up the tower and disconnect the hard drive and then power up the tower again. if the sound goes away--you need to get a new hard drive. If not, you could have some dust bunnies in your cooling fan.
Jun 15, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
E153fp high pitched sound when on
Sounds like the LCD or the inverter are failing. Generally cheaper to replace than to fix
Jan 21, 2009 | Dell E153FP 15" LCD Monitor
Dell E197FP - Screen turns off and on constantly
Check the video connector to make sure it is clean and tight. Look closely for broken or bent pins by GENTLY rubbing your finger across the pins.
Otherwise, it sounds like the monitor screen is failing or has faulty wiring or components inside.
Sep 03, 2008 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
CRT color moitor
The "terrable loud high pitch sound" could be the horz. oscillator.
The voltages off the crt should be (+) (-) 11v to 15v DC. Too much on Blue & Red guns will cut them off
Jun 21, 2008 | Televison & Video
Screaming acer!
sometimes if the inverter board (the part that drives the backlight) has a cold solder joint on it, it can actually generate a high pitched resonating sound (aka a screaming squeal sound)
if it's under warranty, have the manufacturer correct the problem.
if not under warranty, retouch the solder points on the inverter board, or have a repair tech fix it for you.
Jun 03, 2008 | Acer AL1916W 19" LCD Monitor
Computers & Internet Logo
872 people viewed this question
David Payne
David Payne
