My printer is giving proper self test but not printing data from pc
    Master:
  • 635 Answers
Check whether the drivers are installed properly in device manager.
Posted on Sep 29, 2010
Printer saying recieving data and is not printing
First check the printer itself is working OK by printing a test page.
Most printers have a power-on self test (eg press feed button while pressing power on - please consult your manual). If the test print is OK, then it's the PC or connecting cable. You could try any other PC or laptop (you would have to instal your printer software first) but just try re-installing your printer software first on YOUR computer. If that doesn't work try any other PC or Laptop available as directed above.
USE A FILE THAT YOU HAVE PRINTED OK BEFORE IF POSS.
If none of the works then the cable is suspect.
Mar 31, 2014 | Brother MFC Office Equipment & Supplies
HP C6280 will not print self test diagnostic
Do you have an Anti-Virus program installed on your PC? If so, can you try and disable it before you print.
for more help visit CBR Tech Solutions
Mar 13, 2013 | HP C6280 All-in-One Printer
Hl4040cn will not print test page
Try doing a machine self test to ensure that it is working properly.
Press OK/return to "Machine Info"
Then down arrow once to "Test Print" and OK/Return.
The machine should produce a self test printout. If the machine does not give a print out, try cleaning the paper pick up rollers at the back of the paper tray cavity. Be careful, the machine is heavy.
If a full test print happens - Your printer is working fine and the problem is at the computer end.
It's possible driver installion is faulty or incomplete and you should try re-installing the printer driver. Is it also possible that your printer paper settings are either incorrect or do not match the paper in the printer. Check and match your paper settings in the printer preferences and the paper tray.
Jan 02, 2013 | Brother HL4040CN Laser Printer
In epson lq1150 /II esc/P2 how to clear data in memory. Already removed alldata in print Que .Restarted System as well as printer.
Actually, what you're doing already clean up the data in memory.
If the memory still contain data, maybe there's something wrong with the printer.
Run a self test print whether the printer is okay or not,
Turn on the printer while holding down the LF/FF button or Load/Eject button. If it start print, that mean the printer okay. Press 'Pause' and turn OFF the printer and then turn On back to stop the self test printing.
Jul 04, 2012 | Epson Office Equipment & Supplies
Uday.sourav@gmail.comMy HP DeskjetF380 all in 1 printer is not working at all. I tried millions of times but it does not start. There was no problem with the data cord. I think it is a internal problem....
check if you are having power, then if power is present after switching on does it initialize i.e ready to receive data. if yes try a self test page with the printer still disconnected from the pc. if it comes out ok connect your data cable and attempt to print a test page. if it comes out ok try a print job. if not try to change the data cable if still not working try re installing drivers. if you still dont come right try it on another pc. if nothing positive happens take it to a repair shop.
Sep 27, 2010 | HP DeskJet F380 All-In-One Printer
Printing problem
Dear sir,
install new oparating system and attach data cable in your pc then show a new hardware .
This printer is auto plug &play not driver requarments.If you are not success then change data cable with new one.
Thanks
Aug 24, 2009 | HP LaserJet P3005n Printer
Load paper
To resolve this issue pick one blank sheet and insert it in the tray and try to print self test page. If the printer prints self test page then load the paper properly and try to print. If self test page won't print then check the paper settings.
May 22, 2009 | HP Photosmart 3210 All-In-One InkJet...
HP LaserJet 1018: paper will feed, but no content can be printed
just try to print the self test of the hp 1018 printer.self pest is printed directly from the printer not by giving command from the printer. press any one of the button on the printer and hold it till the light blinks.leave the button when light starts blinking .place the paper in the tray.as soon as you leave the button .a self page will be printed..that is self test.if the self test comes out proper that means its your driver software problem.but if self test also has problem then its the clear problem of dust collected on the printer reading lens due to not using it for 2 years.so the printer needs servicing. get it serviced at local printer repair shop .
May 06, 2009 | HP LaserJet 1018 Printer
My printer will not print. c3180 all in one
try to print a self test by unplugging the data cable from the system and turn off the printr and hold the green light button and turn on the printer and then relesed it it should print the test page try uninstalling and reinstalling the drivers
Regards
Samson Ved
Dec 05, 2008 | HP Computers & Internet
Photosmart C6180 will not print in black ink. Have all HP genuine cartridges, although I have used cheaper imitations in the past. Have tried aligning print heads, cleaning, master reset (# & 6...
do not print the printout from the pc.tyr to print a test copy by pressing the menu button on the printer and in that select the option print a self test.then press OK.if the test copy from printer gives proper black colour then its the print setting problem in the pc.just adjust that setting.but if the test page does not print any black line or object that means the cartridge is out of ink and needs replacement.
Nov 29, 2008 | HP Office Equipment & Supplies
24 people viewed this question
jasbo
jasbo
