Question about HP PSC 750 All-In-One InkJet Printer
I send printing job in printer But, Printer in document filed.....
  • HP Master
  • 1,679 Answers
Follow the link below.
http://www.fixya.com/support/r5095488-unable_print_hp_printer
* Please rate this solution with Thumbs up and comment to help us improvise in lending support
Posted on Sep 29, 2010
Memory low message on hp laserjet pro 200
see HP LaserJet Pro Printers Memory is Low message displayed on the control...
HP LaserJet Pro Printers - 'Memory is Low' message displayed on the control panel HP LaserJet Pro - Troubleshoot 20.xx (memory failure) and 21.xx (print failure) error messages (ID: emr_na-c05049204)
HP Customer Support page and ensure the printer is running the latest available firmware. Print a Configuration Report from the control panel of the printer to check the installed firmware version.
  • If the printer supports expandable memory, you can install additional memory in the form of a DIMM. Check the printer's User Guide to see if it supports additional memory.
  • Break complex print jobs into smaller jobs that contain fewer pages.
  • If the printer is an MFP, delete stored faxes to increase available memory. Go to this document for instructions: HP LaserJet Pro MFP - Delete faxes from memory (ID: emr_na-c03264743)
  • Power cycle the printer to delete stored fonts or macros. It is possible to download fonts or macros in a way that power cycling the printer will not delete them; see Appendix A - Memory Allocation.
  • Changing some software and/or print driver settings might result in a less complex print job.
  • Use a different print driver. For example, a PostScript print driver will typically result in a more complex print file. If possible, try sending the file with a PCL6 or UPD printer driver.
  • Adobe PDF files can sometimes be very complex. Go to this document if printing PDF files is slow or resulting in memory out messages: HP LaserJet - Print job is slow or hangs in the print queue when printing Adobe PDF files (ID: emr_na-c04071740)
  • If the printer is connected via a network, try sending the file connected by USB cable only. This will eliminate possible network issues that are taking printer memory.
  • Appendix A
    Memory Allocation Utilities or jobs that you download to the product sometimes include resources (for example, fonts, macros, or patterns). Resources that are internally marked as permanent remain in the product memory until you turn the product off.
    Use the following guidelines if you use the page description language (PDL) ability to mark resources as permanent. For technical details, see an appropriate PDL reference for PCL or PS.
    • Mark resources as permanent only when it is absolutely necessary that they remain in memory while the product is turned on.
    • Send permanent resources to the product only at the beginning of a print job and not while the product is printing.
    NOTE: Overusing permanent resources or downloading them while the product is printing might affect product performance or the ability to print complex pages.
    Sep 08, 2016 | HP LaserJet Office Equipment & Supplies
    'check paper size' error has come up and nothing can now be printed. If turned off and on the last print which had caused the error prints out then the error message appears again. How can i clear this
    This is usually caused by data within the print job. Microsoft Office sends paper size and job data with each job. Clear all print jobs in the computer sending the job.(Start/Printers/double click the canon printer and delete all jobs in the print que. Clear the Canon by off/on. Open a program and print a standard letter size document to test. This can be corrected by going to the page/document setup choices under "File" or the Ball in MS Office. Usually this is set to A4 or Bypass by mistake within the application.
    Thanks
    Jan 06, 2011 | Canon imageCLASS MF8180C All-In-One Laser...
    Keep printing old docoments / will not print current docoment / printing seem to be strunt
    Follow these steps to fix your problem :
    Method A :
    Press the cancel button or use the cancel menu command on the printer
    The most obvious way to cancel a print job is to find a cancel button or a cancel menu command on the printer and to press it. So, if you have not already done this, try this method first.
    If this method worked for you, you are finished with this article. However, you may want to read the "Prevention tips" section to avoid this problem in the future.
    If your printer does not have these items or if this method did not work for you, try Method B.
    Method B:
    Turn the printer off and on
    Next, try turning the printer off and then on. With certain printer models, this cancels the print job.
    If this method did not work for you, turn your printer off, and then try Method C.
    Method C:
    Use Control Panel to cancel printing
    This method is a bit fancier. We will use Control Panel to try to cancel printing.
    But what exactly are you trying to do? Are you trying to cancel printing only a single document, or are there other print jobs that you want to cancel? And are all the print job yours, or are there print jobs that other people have sent to the printer? If you have to cancel documents that other people have sent to the printer, you must have Computer Administrator status or you must have permission to cancel the print jobs. If you are using your own printer, you most likely have Computer Administrator status. If you are printing to a shared printer, you might have to ask the system administrator to cancel the print job for you.
    To cancel one or more print jobs, follow these steps.
    1. Click Start, and then click Run.
    2. In the Open box, type control printers, and then click OK.
    3. Right-click the icon for your printer, and then click Open.
    * To cancel individual print jobs, right-click the print job that you want to cancel, and then click Cancel.
    * To cancel all print jobs, click Cancel All Documents on the Printer menu.
    Note If you cancel a print job that you did want to print, make sure that you send the print job to the printer again.
    If this method did not work for you, make sure that your printer is turned off, and then try Method D.
    Back to the top
    Method D: Stop the print spooler and delete all spooled files
    If you tried Methods A through C and you were not successful, Method D should work for you. If you came to Method D immediately only to delete a print job, some of what we say here might not apply to you, so please bear with us.
    Method D is somewhat more complex and will require a bit more work than the other methods, but don't worry. Method D looks much more difficult than it really is.
    First, in case that you don't know how printing works, here is a short explanation. Print jobs are sent to the printer as spooled files. This means that the files are put in a temporary location so that the printer can access a print queue and print jobs at its own speed. If you stop the spooler and its files, most of the time, you both cancel printing and delete the print job.
    Note To use this method, you must have Computer Administrator status. If you are using your own printer, you most likely have Computer Administrator status. If you are printing to a shared printer, you might have to ask the system administrator to cancel the print job for you.
    Step 1: Start Notepad
    To stop the print spooler and its files, we will have you create and run a script file that will automatically stop the service. This sounds difficult, but it really isn't. Just follow these steps carefully.
    2. In the Open box, type notepad, and then click OK. Notice that a blank Notepad document opens.
    Step 2: Copy a command script to Notepad
    Now we will have you copy and paste some commands to the Notepad document.
    1. Carefully select (highlight) all the following text:
    net stop spooler
    del %systemroot%\system32\spool\printers\*.shd
    del %systemroot%\system32\spool\printers\*.spl
    net start spooler
    2. Right-click the text that you selected, and then click Copy.
    3. In Notepad, right-click in the blank document, and then click Paste.
    4. Carefully select (highlight) all the following text:
    C:\DeletePrintJobs.cmd
    5. Right-click the text that you selected, and then click Copy.
    6. In Notepad, click Save As on the File menu.
    7. In the File Name box, right-click, and then click Paste.
    8. Click Save.
    Step 3: Run the command script file
    Now that you have created the command script file, you will run it. To run it, you will copy and paste the name of the command script file in the Run box.
    3. Click Start, and then click Run.
    4. In the Open box, right-click, and then click Paste.
    5. Click OK.
    6. Notice that the Command Prompt window opens to run the command script file that you created. Notice also that this window closes automatically when the command script file has finished running. If you do not see the Command Prompt window open, check that you saved the command script file by using the correct name and that you entered the correct command script file name in the Run box.
    If this method does not work the first time, or if you cannot print anything after you use this method, restart your computer, and then try again.
    Nov 20, 2010 | Lexmark X2500 All-In-One Printer
    How do i cancel a print job?
    Method A: Press the cancel button or use the cancel menu
    loadTOCNode(2, 'resolution');
    Method B: Turn the printer off and on
    Method C: Use Control Panel to cancel printing
    printing.
    steps.
      • To cancel individual print jobs, right-click the print job that you want to
      • To cancel all print jobs, click Cancel All
    If
    future.
    files
    us.
    it really is.
    print job.
    loadTOCNode(3, 'resolution');
      net stop spooler
      del
      del
      net start spooler
      File menu.
      then click Paste.
      Note Notice that
      this file name differs from most other file names that you might have seen. That
      is because this file is a command script file.
    8. Click Save.
      click Paste.
    5. Click OK.
      Run box.
    Note If this method does
    Oct 08, 2010 | Pitney Bowes AddressRight DA300 Printer
    I plug in the printer and it keeps feeding the tape printing "junk". I am using it with Aloha and I currently have the same model printer that is a loaner working perfectly. I don't know if this is a...
    Your last print job might have crashed, but it's still trying to send data to the printer.
    If you have a Windows system, Go to Printers from the Control Panel and double-click on the printer. If you see any print jobs listed, choose File/Cancel All Documents.
    But sometimes that doesn't work - then follow these steps to get rid of all stuck print jobs:
    1. Start –> Run Type “services.msc” without quotes
    2. Find PrintSpooler and Stop the service
    3. Navigate to C:WINDOWS\SYSTEM32\SPOOL\PRINTERS and delete all files in the folder.
    4. Next Repeat Step 1 and Start the PrintSpooler Service.
    Hope that helps - Sam
    Sep 07, 2010 | Office Equipment & Supplies
    The printer prints a blank page with a line of gibberish in the upper left corner before it prints the real page.
    Can you send me a "print to file" of the failing document.
    At first blush it can be either of two things.
    1) The preceding print job did not properly clean out the printer's memory.
    2) The new print job, has data or a busted escape command in it that is being treated as printable data.
    Send the print file to don.farr@hotmail.com and I'll read through the document header to see what's going on.
    Don
    Mar 02, 2010 | Dell 1720dn Laser Printer
    Document won't delete from printer queue after printed
    Have you tried to stop the spooler service in services?
    Option 1)
    Click on start orb
    Type in search window:
    services.msc
    click ok
    Scroll down to Print spooler service and click on it in the right side window.
    On the left side click stop the service and wait forthe process to stop .Do not close the window yet. You will have to restart it here later.
    next delete the print job in the printer queue then restart the spooler service
    Resubmit your new print job.
    Option 2)
    If that doesn't clear it, the next step would be to stop the spooler
    service as stated above
    Go into windows explorer
    (Print job data is collected and stored in a spool file in the spooler folder.)
    It is located in:
    C:\WINDOWS\system32\spool\PRINTERS
    Your print job will show 2 files there Example below:
    00002.SHD
    00002.SPL
    Delete the files located in there. There may be several of them depending apon how many print jobs you submitted. You will have to resubmit your print jobs all over again.
    Next go back to services window and restart the spooler service
    That will definitely fix it.
    Aug 19, 2009 | Lexmark Office Equipment & Supplies
    I have (4) documents to print, but it won't print. It says: 4 document(s) pending owner
    To cancel a print job in Windows you can use one of the following two methods:
    CANCELLING A PRINT JOB WITH THE PROGRESS METER:
    When you send a print job to the printer, the Status Monitor will appear in the bottom right corner of your screen. Another printer icon for the PROGRESS METER will also appear in the taskbar while printing is taking place. This PROGRESS METER is there so you can manage print priorities or cancel print jobs.
    1. Highlight the print job in the PROGRESS METER box.
    2. Click on DOCUMENT and CANCEL, or, right click on the job name and left click CANCEL or DELETE.
    3. Confirm cancelling the print job.
    CANCELLING A PRINT JOB FROM THE PRINTERS WINDOW:
    If no PROGRESS METER appears, you can access the document queue in this fashion:
    1. Open START, SETTINGS, CONTROL PANEL, PRINTERS (START, CONTROL PANEL, PRINTERS and FAXES in Windows XP).
    2. Right click on your Epson printer name, left click PURGE PRINT JOBS (98,ME), or CANCEL ALL DOCUMENTS (2000,XP). (Or, double-click on the printer name to see and modify the status of documents in queue.)
    3. Confirm cancelling all documents.
    Keep in mind that once information has been sent to the printer it resides in the spooling folders within Windows. It may a while for printing to stop as this data clears the system.
    If the printer continues to print (ie multiple copies of a cancelled job, or garbled print) remove the rest of the paper from the printer and allow it to run out. Once an "out of paper" type error appears on your screen, cancel the documents. Once all print job information has deleted, reload the paper and press the paper feed button once to clear the red light and return the printer to a ready state.
    Jul 16, 2008 | Epson Printer
    Trouble with duplex printing
    I think your problem is that the 5550 supports manual duplex printing. Print every other page then feed them through again. Never tried it though. Dave Reed
    May 23, 2008 | HP LaserJet 5550 Printer
    Deleting - Printed
    I've also had this problem with an HP LaserJet 4650dtn printer. I've solved this by: - Stop the "Print Spooler" service. - Delete all the existing print spool files. (Stored in "C:\WINDOWS\system32\spool\PRINTERS" by default). - Start the "Print Spooler" service. - Right-click the printer's icon in the Printers and Faxes folder and choose Properties. - Click the Advanced tab. - Click the Print Processor... button. - Make a note of the existing "Print processor" selection on the left (in case you need to revert it.). Then change it to "WinPrint". Click OK. - Click OK on the printer's properties window. - Try sending a print job to see whether it persists in the print queue.
    May 07, 2007 | Lexmark X1150 All-In-One InkJet Printer
    HP PSC 750 All-In-One InkJet Printer Logo
    22 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
